Trouble reading from CompactFlash card
jfoucher
Post by jfoucher »
Hi everyone,
I was not sure whether to post this here or in Programming, but here goes.
I am trying ( and so far failing) to reliably read data from a CF card.
I built a circuit which seems to work, but I am getting some missed bytes, or sometimes added bytes.
Here is a schematic of the circuit, but note I am using a CF to IDE adapter on my prototype board (to my understanding they are just passive adapters, am I wrong?)
Finally, here is the code snippet I use to read a sector from the card (adapted from this code)
cf_wait:
wait_loop:
    lda CF_ADDRESS + 7
    and #$80
    bne wait_loop
    rts
cf_read:
    phy
    lda #<FAT_BUFFER
    sta CF_BUF_PTR
    lda #>FAT_BUFFER
    sta CF_BUF_PTR + 1
    ldy #0
loop:
    jsr cf_wait
    lda CF_ADDRESS + 7
    and #$08
    beq exit
    lda CF_ADDRESS
    sta (CF_BUF_PTR), y
    iny
    bne loop
    inc CF_BUF_PTR + 1
    bra loop
exit:
    ply
    rts
where FAT_BUFFER is a 512 byte buffer, CF_BUF_PTR is a ZP pointer and CF_ADDRESS is the base address of the CF card.
There is some more code which sets the LBA sector to read, please ask if seeing would be helpful.
And finally here is an example of what I am reading
EB 3C 90 42 53 44 20 20 34 2E 34 00 02 08 01 00 02 00 02 00 00 F8 F5 00 20 00 20 00 3F 00 00 00
A5 A7 07 00 80 00 29 EB 1A 4C 02 50 4C 41 4E 43 4B 36 35 30 32 20 46 41 54 31 36 20 20 20 FA 31
C0 8E D0 BC 00 7C 8E FB 8E D8 E8 00 00 5E 83 C6 19 BB 07 00 FC AC 84 C0 74 06 B4 0E CD 10 EB F5
30 E4 CD 16 CD 19 0D 0A 4E 6F 6E 2D 73 79 73 74 65 6D 20 64 69 73 6B 0D 0A 50 72 65 73 73 20 61
6E 79 20 6B 65 79 20 74 6F 20 72 65 62 6F 6F 74 0D 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
And what I should be reading
C0 8E D0 BC 00 7C FB 8E D8 E8 00 00 5E 83 C6 19 BB 07 00 FC AC 84 C0 74 06 B4 0E CD 10 EB F5 30
E4 CD 16 CD 19 0D 0A 4E 6F 6E 2D 73 79 73 74 65 6D 20 64 69 73 6B 0D 0A 50 72 65 73 73 20 61 6E
79 20 6B 65 79 20 74 6F 20 72 65 62 6F 6F 74 0D 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA
As you can see, on line 3 for example I am reading
8E FB 8E
instead of
FB 8E
Can anybody see where I am going wrong? The card works perfectly when plugged in my laptop.
Thank you very much for any advice!
Edited to add:
My code seems to work fine, because I can reliably read the card information with ATA command $EC.
I does not seem to be a timing issue either because I get the same types of errors whether I run the computer at 1, 6 or 12 MHz...
Jonathan Foucher
Take a look at the Planck 6502 computer.
floobydust
Re: Trouble reading from CompactFlash card
Post by floobydust »
I think you might be having an issue with your hardware setup. The schematic is a bit confusing... as you show a 52-pin connector and compact flash is a 50-pin connector. You noted you're using an adapter, but all of the ones I've used over the years are setup for either a 40-pin IDE interface (with separate power connector) or a 44-pin 2.5-inch IDE connector (integrated power). In any case, these are basically passive, but would have the correct wiring to put the CF Card into IDE mode. Also note that there are two power pins on the CF Card: pins 13 and 38. You have pin 13 to +5V and pin 38 via a 1K resistor to +5V. You also have the /CS0 select tied low and are using a bunch of gates decoding the read and write lines to the CF Card. This might create some timing problems, but maybe not. You show pin 50 as floating, but the SanDisk specification shows pin 50 as Ground.
Attached is the schematic for my compact flash adapter. It's different as I'm also using an 8-bit latch for the upper 8-bits to provide 16-bit data transfers, but the full wiring of the CF Card socket is show with signals grounded, pull-up resistors and such. It might be helpful... but maybe not.
My decode logic is via the ATF16V8 PLD. Note that the chip selects are done via address lines only and not qualified by any clock signals. I also have CLK2 qualified read and write signals that are driving the CF Card read and write lines.
As for the software, you're using 8-bit data mode, so that has to be set first as the default is for 16-bit transfers, which you're probably already doing. My BIOS code (github page) sets up the CF Card and uses interrupt driven transfers. It might be helpful to take a look at it.
Also, Bill (Plasmo on the forum) has a compact flash setup he uses in 8-bit polled mode, so his looking at his CRC65 hardware and software might be helpful as well.
Hmm, I'm forced to guess some details. Is CLK the same as PHI2? And is SLOT_SEL the output of an address decoder?
Altering the clock speed isn't 100% proof you DON'T have a timing issue. But if CLK is indeed PHI2 then your circuit looks reasonably good to me. You could try replacing the 'HC00 with 'AHC00...
And, is there a transcription error? See below. It looks to me as if the code is calling itself! But I'm still on my first cup of coffee of the day... :) :roll:
plasmo
Post by plasmo »
A picture is helpful. CF interface is as much as about electrical interface as physical interface. How you physically manage power/ground and fast switching parallel data bus are important. Modern CF is dangerously fast and a great noise maker. High speed is not your friend.
* you should have 3 controls: chip select, read strobe and write strobe. Timing wise, read strobe or write strobe need to be asserted last and negated first. Think of chip select as one of the addresses.
* CF operates at 16-bit data mode natively. There is a "set feature" command to switch it to 8-bit data mode. You should do 8-bit mode to reduce switching noise
* If you found that more '1' you have in your data stream, the more likely it became corrupted, then it is a sure indication of system noise problem. If you lower the voltage (CF is designed to run to 3.3V) and thing starts to work better, it is also an indication of system noise.
* keep it short, keep it simple. I generally don't worry about signal integrity with retro computing but I do with the CF interface.
jfoucher
Post by jfoucher »
Hi, and thanks for the quick responses.
I'll try and clarify some things that were not very clear in my first post:
Pins 51 and 52 are the little tabs that hold the connector down on the board. This is the footprint I am using
The schematic is not the exact circuit I am using at the moment. It's a design for a board I am planning to make once I have this prototype working. I can see now that it is wrong in a few places. I can draw and post the prototype's schematic if that would be helpful. I used the same decode logic, but I have CE1 (pin 37 on the CF card) tied to the chip select out of the memory decoding. CE0 (pin 38) is tied to ground. Thank you floobydust for your keen eye, I'll make sure to fix these mistakes on the schematic before having the board fabricated. Your schematic will definitely be helpful. Could you also maybe point me to your PLD code so that I could check my own logic against yours ?
Yes to both
There is an "rts" on the line above "cf_read" that maybe escaped your coffee deprived brain :D
Chip select is tied directly to the output of the address decoding.
The read and write strobes are mostly the same, but incorporating the RW signal gated and by the PHI2. Is that enough?
Yes I am using 8 bit mode (or so I think) by calling this routine before any CF card operation:
cf_init:
    lda #$4
    sta CF_ADDRESS + 7
    jsr cf_wait
    lda #$E0
    sta CF_ADDRESS + 6
    lda #$1
    sta CF_ADDRESS + 1
    lda #$EF
    sta CF_ADDRESS + 7
    jsr cf_wait
    jsr cf_err
    rts
Does that seem right ?
Very interesting, I'll give that a try right now!
Jonathan Foucher
floobydust
Here's the SanDISK technical document I referenced when I was working on the CF Card interface:
SanDisk CompactFlash Memory.pdf
(8.59 MiB) Downloaded 124 times
My GitHub page has the PLD code as well:
https://github.com/floobydust/CF-Card-R ... RTC-CFcard
I use the adapter with my C02 Pocket SBC, full details here:
https://github.com/floobydust/C02-Pocket-SBC
I also have an updated DOS/65 that runs on this configuration:
https://github.com/floobydust/DOS-65-V3.03-ROM
There's also a detailed explanation of the 8-bit latch and PLD code on the forum, albeit a slightly modified interface, as I switched to a 35-pin PATA Microdrive:
viewtopic.php?f=4&t=6825#p96395
Hope this helps...
jfoucher
Post by jfoucher »
Would you mind clarifying how the /MRD and /MRW signals are generated? They only appear as inputs on the schematic and in the PLD code.
Jonathan Foucher
floobydust
Yes, those are CLK2 qualified lines from the C02 Pocket SBC. The C02 Pocket uses an ATF22V10C PLD as a single glue logic device. All I/O selects, RAM, ROM and /MRD /MWR are generated. Inputs are CLK, R/W and Address lines A15 - A5.
Note that I use page $FE for all I/O. There are 5- selects, each at 32-bytes wide. Using the ATF16V8, I can use a single I/O select to decode for the two selects for the CF-Card (IDE mode), the DS15x1 RTC and the latches. My adapter and BIOS also use interrupts, which requires the INT line from the IDE interface to be inverted.
Here's the basic logic on the PLD:
Name     Glue3 ;
PartNo   01 ;
Date     10/31/2017 ;
Revision 01 ;
Designer KM ;
Company  Analogue Technologies ;
Assembly SBC2 ;
Location  ;
Device   g22v10 ;
PIN 1    = CLK                       ; /*                                 */
PIN 2    = A15                       ; /*                                 */
PIN 3    = A14                       ; /*                                 */
PIN 4    = A13                       ; /*                                 */
PIN 5    = A12                       ; /*                                 */
PIN 6    = A11                       ; /*                                 */
PIN 7    = A10                       ; /*                                 */
PIN 8    = A9                        ; /*                                 */
PIN 9    = A8                        ; /*                                 */
PIN 10   = A7                        ; /*                                 */
PIN 11   = A6                        ; /*                                 */
PIN 13   = A5                        ; /*                                 */
PIN 23   = RW                        ; /*                                 */
PIN 14   = !IO1                      ; /*                                 */
PIN 15   = !IO2                      ; /*                                 */
PIN 16   = !IO3                      ; /*                                 */
PIN 17   = !IO4                      ; /*                                 */
PIN 18   = !IO5                      ; /*                                 */
PIN 19   = !ROM                      ; /*                                 */
PIN 20   = !RAM                      ; /*                                 */
PIN 21   = !MWR                      ; /*                                 */
PIN 22   = !MRD                      ; /*                                 */
/** Declarations and Intermediate Variable Definitions  **/
FIELD ADDRESS = [A15..0];
RAM = ADDRESS:['h'0000..7FFF];
IO1 = ADDRESS:['h'FE00..FE1F];
IO2 = ADDRESS:['h'FE20..FE3F];
IO3 = ADDRESS:['h'FE40..FE5F];
IO4 = ADDRESS:['h'FE60..FE7F];
IO5 = ADDRESS:['h'FE80..FE9F];
ROM = ADDRESS:['h'8000..FDFF]
        # ADDRESS:['h'FEA0..FFFF];
/** Logic Equations **/
MWR = (CLK & !RW);
MRD = (CLK & RW);
jfoucher
Post by jfoucher »
Oh ok, that's really helpful thanks. In your design the chip select only depends on the memory decoding, and the CF card read and write lines only depend on the state of PHI2 and RW, whereas I have the same for the CF card chip select, but my IORD and IOWR signals are "gated" by the chip select, which is not necessary at all.
And Plasmo, I tried running on 3.3V, my CF/IDE adapter has a jumper to set 3.3V or 5V, which I set to 3.3V, but it does not work at all. Any call to the CF card address hangs the whole computer... It was worth a shot anyway.
Jonathan Foucher
jfoucher
Post by jfoucher »
So, what I ended up doing was not trying to read a FAT or other filesystem, and instead just use the block storage that Taliforth expects, since this is what I am using on my machine. After a bit a fiddling, it turns out that reading and writing blocks works perfectly fine there. (I also changed the IORD / IOWR logic to be the simpler one that you use in your PLD, Floobydust). That saves one NAND chip.
For now I have just tried reading / writing ascii data, which works fine. I'll have to try and see what happens with binary data. I think what may be happening is that since ascii data is more "regular", signal integrity is less of an issue and that's why it works fine, whereas with binary data, it's more "random" and signal integrity becomes more of an issue. Is that even possible?
Anyway, I'm calling this solved for now, and thanks for the help!
Jonathan Foucher
jfoucher
Post by jfoucher »
Final (I hope) update. I finally managed to read random binary data on the CF card by changing my reading code to the code below:
cf_read:
    phy
    ldy #0
@loop:
    lda CF_ADDRESS
    sta (io_buffer_ptr), y
    iny
    bne @loop
    inc io_buffer_ptr + 1
    jsr cf_wait
@loop2:
    lda CF_ADDRESS
    iny
    bne @loop2
    dec io_buffer_ptr + 1
@loop3:
    jsr cf_wait
    lda CF_ADDRESS + 7
    and #$08
    beq @exit
    lda CF_ADDRESS
    iny
    bne @loop3
@exit:
    ply
    rts
There is only one call to the cf_wait routine (that calls register 7 to see if the card is ready) when changing from one page to the next, and not at every byte like the previous one.
Also, there no more check for the end of the sector while reading bytes, but that has been moved to the end of the routine. It's a few more bytes, and I don't have a clue why it works, but hey, if it proves ok in the long run, I'm happy!
Jonathan Foucher
floobydust
When reading or writing to the CF card (or any IDE device), the DRQ bit in the status register is what confirms that data is ready to be transferred. In general, it's unlikely any 6502 based system will be able to grab data faster than the device can output it. I use the routine below, which is part of the ISR that handles the IDE interface. While there is the alternate read from the high-byte latch (D8-D15), the code is simple enough:
INTERUPT1                               ;Interrupt 1 (IDE)
                LDA     IDE_ALT_STATUS  ;Get Alternate Status Register (4)
                BMI     REGEXT01        ;If Busy bit active, just exit (2/3)
; - Check for Data Request (DRQ), as the Read LBA operation is the main function
;   of the ISR, which will handle the data transfer from the IDE controller to store the
;   data into memory. This ISR will handle single and multiple block transfers.
                LDA     IDE_STATUS      ;Get Status (resets IRQ) (4)
                AND     #%00001000      ;Check for DRQ (2)
                BNE     IDE_READ_BLK    ;Branch if active (2/3)
; - If no DRQ is sensed, the other possibilities are:
; 1- A LBA Write has occurred and the interrupt was generated after the transfer.
; 2- A Verify operation has occurred and the interrupt was generated after the verify.
; So we check for these two options and branch accordingly.
                BBS2    MATCH,IDE_WRIT_BLK      ;If Bit 2 set, Write operation (5,6)
                BBS1    MATCH,IDE_VRFY_BLK      ;If Bit 1 set, Verify operation (5,6)
                BRA     REGEXT01                ;Exit ISR handler (3)
IDE_READ_BLK                            ;IDE Read a Block of data
;Note: Arrival here means that the DRQ bit in the status register is active.
; This implies that:
;  1- A LBA Block Read is in progress. If so, the data transfer will be handled below.
;     This also handles multiple LBA Reads and manages the pointers and such. It also
;     clears the LBA Read bit in the MATCH Flag when completed.
;  2- A LBA Block Write with multilpe blocks is in progress. If so, the actual data
;     transfer is handled via the IDE WRITE Block routine. An interrupt is generated
;     at the end of each LBA transfer, so that is monitored here and the LBA Write bit
;     in the MATCH Flag is cleared when there are no more blocks to transfer.
;Also realize that this ISR will be executed every time the DUART generates an interrupt.
; This will happen every 10ms for the Jiffy-Clock timer and for character transmit and receive.
                BBR3    MATCH,REGEXT01  ;If Bit 3 clear, IDE Write (5,6)
LBA_XFER        LDA     IDE_ALT_STATUS  ;Get Status  (4)
                BEQ     IDE_RD_DONE     ;If not active, done, exit (2/3)
IDE_RD_RBLK
                LDA     IDE_DATA        ;Read low byte (high byte in latch) (4)
                STA     (BIOS_XFERL)    ;Store low byte (5)
                INC     BIOS_XFERL      ;Increment pointers (5)
                BNE     IDE_RD_BLK1     ; (2/3)
                INC     BIOS_XFERH      ; (5)
IDE_RD_BLK1
                LDA     IDE_16_READ     ;Read high byte from latch (4)
                STA     (BIOS_XFERL)    ;Store high byte (5)
                BNE     LBA_XFER        ;Loop back to Xfer, saves 3 clock cycles (2/3)
IDE_RD_BLK2
                BRA     LBA_XFER        ;Loop back till no more DRQs (3)
IDE_RD_DONE     DEC     BIOS_XFERC      ;Decrement Block Count to transfer (5)
                BNE     IDE_ALL_DONE    ;Branch around Flag Reset until all blocks moved (2/3)
                RMB3    MATCH           ;Clear Read Block flag (5)
IDE_ALL_DONE    LDA     IDE_ALT_STATUS  ;Get Alternate Status Register (4)
                STA     IDE_STATUS_RAM  ;Save it to RAM location (3)
REGEXT01        JMP     (VECINSRT0)     ;Exit ISR handler (6)
IDE_WRIT_BLK                            ;IDE Write a Block of data
                LDA     BIOS_XFERC      ;Check Block Count to transfer (3)
                BNE     IDE_ALL_DONE    ;Branch to exit if more blocks need to be moved (2/3)
                RMB2    MATCH           ;Clear Write Block flag (5)
                BRA     IDE_ALL_DONE    ;Branch and finish ISR (3)
IDE_VRFY_BLK                            ;IDE Verify a Block of data
                RMB1    MATCH           ;Clear Verify Block flag (5)
Note that I use the alternate status register for transfers.... as this is a clone of the main status register, with the exception that reading it will not reset the interrupt. Also, by using some of the CMOS instructions and addressing modes, you can make the code a bit smaller for the transfer loop and don't need to preserve the Y reg. I know many folks just prefer to use polled mode here, but I still prefer an interrupt-driven support for hardware devices.
In any case, seems like you've sorted out the hardware and have some routines running to make it go, and as always, you can't argue with success.
jfoucher
Post by jfoucher »
Thank you floobydust for the code listing. it helped me a great deal when trying different things. I still had some trouble getting reliable reads from the CF card, even after trying probably everything that was offered here.
I then realized that plasmo's comment about signal integrity was probably on the money, so I had a board fabricated according to the schematic I posted in my first post, modified to take into account everyone's remarks.
Here is the current version.
And it turns out that when on a proper PCB, this design works flawlessly! I had a bit of trouble soldering the socket, but apart from that I am very happy with it. I can now use the Taliforth block read and write facilities, and have even played with a very small boot rom (about 200 bytes) that only copies the code from CF to RAM and jumps to it, it's great!
So again, thank you everyone for your help!!
Jonathan Foucher
