Fleet Forth design considerations
Re: Fleet Forth design considerations
Surely I'm not the only one to write an indirect threaded code (ITC) implementation of Forth on this forum, or am I?
Blazin' Forth handles the transition from cold start to high level Forth by storing the address of the Forth thread in IP and jumping to the body of a primitive which would have been in the Forth thread.
If I didn't have >FORTH in Fleet Forth, I would push the address of the Forth thread onto the return stack and jump to the body of EXIT .
Here are three examples showing these techniques.
Using >FORTH to transition to high level Forth thread.
WARM SPLIT SWAP
# LDA $300 STA \ store address of warm-start routine
# LDA $301 STA \ at $300
(WARM) JSR
>FORTH
EMPTY 0 DRIVE CONFIGURE
12 SPACES
[ HERE 18 + >A ]
." C64 FLEET FORTH COPYRIGHT (C) 1995-2022 BY JAMES BOYD "
[ HERE 1- >A ]
INITIAL QUIT -; \ don't compile EXIT
$D A> C! $D0D A> ! \ replace some blanks in startup message string with CR.
Pushing the address of the Forth thread onto the return stack and jumping to the body of EXIT .
LABEL COLD.THREAD
] EMPTY 0 DRIVE CONFIGURE
12 SPACES
[ HERE 18 + >A ]
[ HERE 1- >A ]
INITIAL QUIT [
WARM SPLIT SWAP
(WARM) JSR
COLD.THREAD SPLIT \ push address of Forth thread
# LDA PHA \ onto return stack
# LDA PHA
' EXIT @ JMP
END-CODE
Storing the address of the Forth thread in IP and jumping to the body of 0
LABEL COLD.THREAD
] EMPTY DRIVE CONFIGURE \ zero will already be on data stack
12 SPACES
[ HERE 18 + >A ]
[ HERE 1- >A ]
INITIAL QUIT [
WARM SPLIT SWAP
(WARM) JSR
COLD.THREAD SPLIT
# LDA IP 1+ STA
# LDA IP STA
' 0 @ JMP \ 0 is not a constant in Fleet Forth.
END-CODE \ CFA of 0 points to code which
\ places a zero on the data stack.
In the first example the compiler security provided by colon and semicolon (or dash semicolon) is available. In the other two examples, it is not.
- GARTHWILSON
- Forum Moderator
Some years after I was heavily into that, I started writing my 65816 Forth from scratch. It has been operational for 25 years, but only one person has used it much, and that was a technician in the Pratt & Whitney turbine-engine plant in Canada. He used it on the Mensch computer of the 1990's with a 65265 microcontroller. I've hardly used this Forth myself, for a couple of reasons. I let it collect dust for a couple of years at a time, then spend a little time further developing it until another big work project comes along, and then it goes back into mothballs for a couple more years or more. It runs two to three times the speed of my '02 Forth at a given clock rate. My only operation of it has been on my workbench computer than has a 65802 on it, meaning it only has access to bank 0, the first 64KB. I've written words for long accesses, but have not had any hardware to prove them on. At the moment, I am very slowly working on a PCB for a new workbench computer with far more of everything—a real 65816, 768 times as much RAM, hopefully 20MHz (or more if I can get it) (which would mean 40-60 times the Forth execution speed of a C64), more I/O of every kind, etc.—and then I can finish up the '816 Forth and publish it. It is intended for all code to run in bank 0 (which I find is plenty), and the rest of memory is for data, all contiguous, so for example you could have a multi-megabyte array with no interruptions for I/O or anything else.
Both my '02 and '816 Forths are ITC. The '816 Forth has hundreds of primitives (ie, words defined in assembly language), far more than the '02 Forth has. Since the '02 doesn't handle 16-bit quantities nearly as efficiently as the '816 does, many of words were just too impractical to have as primitives (ie, defined in assembly language) on the '02. They just take too many instructions, too much memory. The '816 OTOH makes it practical to have far more as primitives. Besides the obvious advantages of more compact code and faster execution, there were many cases on the '816 where it was actually easier to write words as primitives than as secondaries.
I would like to publish my work on that one as an assembly-language source code, but I would still need to remove some material the metacompiler supplier might be able to claim a copyright on, meaning there would definitely be some work to do on it. It's not a high priority.
I'm not asking you to show any code. I am curious, when your computer goes from the reset/cold start routine to Forth's QUIT loop (or high level Forth which leads to the QUIT loop), is it by one of the three methods I presented or something else?
Would any other implementer of an ITC Forth like to mention which method is used to transition from the reset/cold start routine to high level Forth?
- GARTHWILSON
- Forum Moderator
The reset routine includes loading NEXT into ZP so I can use self-modifying code to eliminate some indirection and make NEXT faster, and putting the PFA of COLD into IP and then jumping to NEXT. COLD sets up some things in Forth, then ends with ABORT, and ABORT ends with QUIT.
I don't have anything called WARM, but I have COLD ask in the LCD, "New/Old/Init Ap?" corresponding to three keys. "New" does the usual thing, re-initializing everything including the dictionary pointer. "Old" leaves the dictionary pointer alone but does all the same stuff about initializing interrupt vectors, alarms, key-repeat speed, the delay before key-repeat starts, and other such things. "Init-Ap" does like "Old" but then also calls the word whose CFA is stored in the INIT-AP variable. These allow a very fast recovery from a crash, since most crashes don't go writing garbage all over memory but are instead the result of some loop exit condition never being met, and I usually realize right away what I did and can fix it immediately.
I hadn't thought of jumping to NEXT . Scott Ballantyne's Blazin' Forth puts the PFA of the high level part of its cold start routine in IP then jumps to RP!
My Fleet Forth clears the return stack in the low level portion of COLD before calling a few Commodore 64 kernal routines before using >FORTH to transition to high level. The high level portion ends with QUIT . The data stack and auxiliary stack are cleared by a subroutine called by the low level portion of COLD .
Fleet Forth does not have a word called WARM . It is a label used by the metacompiler.
Since Fleet Forth is for the C64, it is loaded from disk. It has one line of BASIC, a BASIC fuse to launch the cold start routine.
10 SYS XXXX
XXXX is the address of the cold start routine. The address of the warm start routine is stored at address $300 so it will run whenever the RUN/STOP and RESTORE keys are pressed at the same time. This is handy if I accidentally start an infinite loop, for example. The warm start routine leaves the dictionary and block buffers (and their tables) alone. It acts like an ABORT after initializing a few things such as setting base to DECIMAL , turning off multitasking, and storing the indirect jump opcode $6C at W-1.
Here is a breakdown of Fleet Forth's FORGET . For the sake of clarity, every double slash (used by Fleet Forth for an end of line comment) was converted to a backslash.
: FORGET ( -- )
NAME CURRENT @ DUP CONTEXT !
VFIND ?HUH >LINK
NAME parses the text stream for a blank delimited string and manages the case since Fleet Forth is case insensitive. The string is stored as a counted string at HERE .
The CONTEXT VOCABULARY is set equal to the CURRENT VOCABULARY and VFIND is used to perform the search. VFIND is a primitive without a body with a code field which points one byte into the body of (FIND) . Unlike (FIND) , VFIND will NOT search parent vocabularies. ?HUH aborts with the message "WHAT?" if the name was not found. >LINK takes the CFA of the word and returns the LFA , the link field address, which is the word's first field.
LABEL (FORGET)
SINGLE
DUP>R FENCE @
LIT
LABEL KERNEL-FENCE
[ 0 , ] \ WILL BE PATCHED
UMAX U<
ABORT" PROTECTED"
The word EMPTY branches to the address at the LABEL (FORGET) . SINGLE switches off multitasking by setting the deferred word PAUSE to the no-op NOOP . A copy of the address is saved to the return stack and tested against FENCE and FORGET's internal fence. If it is less than either, FORGET aborts with the message "PROTECTED".
VOC-LINK R@ TRIM
VOC-LINK @
BEGIN
DUP 2- 2- R@ TRIM
@ ?DUP 0=
UNTIL
A Fleet Forth VOCABULARY has three cells in its parameter field. The first cell points to the link field of the latest word defined in this VOCABULARY, the second cell points to the parent of this VOCABULARY , and the third cell is part of the VOC-LINK chain of all vocabularies.
The VOC-LINK chain is trimmed to remove all vocabularies which are defined after the forget point, then each of the remaining vocabularies are trimmed to remove all words which are defined after the forget point.
R> DUP DP ! [ 'THERE ] LITERAL @
UMIN [ 'THERE ] LITERAL !
The dictionary pointer DP is set to the forget point and the empty point is set to the lesser of the previous empty point and the forget point.
\ RESET ANY SYSTEM DEFERRED WORD
\ WITH CFA ABOVE HERE
HERE [ END.FORGET ] LITERAL
\ BRANCH INTO IORESET
BRANCH [ (IORESET) , ] -;
Each deferred word in the kernel has its PFA and default vector stored in a table of deferred words. This last section of FORGET pushes HERE and the ending address of the table onto the data stack and branches to IORESET . Any deferred word with a vector defined after the new HERE will be reset to its default vector.
This is the last line of source for Fleet Forth's kernel. It patches FORGET's internal fence, protecting all kernel words.
HERE KERNEL-FENCE !
To be clear, the last thing the metacompiler does is execute FINISH-FORTH , but that's in block #1.
Fleet Forth's FORGET does exactly what I want and it works great; however, if I've forgotten anything or if anyone has a suggestion for an improvement, please let me know.
SEE FORGET
FORGET
10666 7700 NAME
10668 2603 CURRENT
10670 3549 @
10672 5002 DUP
10674 2589 CONTEXT
10676 3587 !
10678 7718 VFIND
10680 8033 ?HUH
10682 6627 >LINK
10684 8616 SINGLE
10686 4753 DUP>R
10688 2530 FENCE
10690 3549 @
10692 2497 LIT 12017
10696 5926 UMAX
10698 4390 U<
10700 7825 (ABORT") PROTECTED
10712 2674 VOC-LINK
10714 4726 R@
10716 8824 TRIM
10718 2674 VOC-LINK
10720 3549 @
10722 5002 DUP
10724 4789 2-
10726 4789 2-
10728 4726 R@
10730 8824 TRIM
10732 3549 @
10734 4981 ?DUP
10736 4597 0=
10738 2259 ?BRANCH 10722
10742 4658 R>
10744 5002 DUP
10746 2846 DP
10748 3587 !
10750 2497 LIT 2077
10754 3549 @
10756 5905 UMIN
10758 2497 LIT 2077
10762 3587 !
10764 7357 HERE
10766 2497 LIT 3054
10770 2489 BRANCH 9703 ' IORESET >BODY 6 +
108
OK
SEE uses the current BASE , which was DECIMAL , to display numbers.
There is an interesting property of Fleet Forth's DO LOOP's. Detailed information is provided on Fleet Forth's DO LOOP's here.
Consider the word used to remove trailing blanks from the count of a string's address count pair, -TRAILING
: -TRAILING ( ADR CNT1 -- ADR CNT2 )
DUP 0
?DO
2DUP + 1- C@ BL <> ?LEAVE
1-
LOOP ;
Here is what gets compiled:
SEE -TRAILING
-TRAILING
6748 5002 DUP
6750 3293 0
6752 2358 (?DO) 6776
6756 5284 2DUP
6758 4884 +
6760 4815 1-
6762 3576 C@
6764 2709 BL
6766 4474 <>
6768 2128 ?LEAVE
6770 4815 1-
6772 2149 (LOOP) 6756
6776 2469 EXIT
30
OK
If the count is zero (?DO) will branch to the address which is stored in the cell which follows. This address (address 6776) is also present when (DO) is compiled. It is the address which is pushed on the return stack for any LEAVE or ?LEAVE . It is also the address used by (LOOP) if the DO LOOP runs to completion. If a different address is stored in the cell after (?DO) , the EXIT at address 6776 will not be reached.
Here is the word SPACE
: SPACE ( -- ) BL EMIT ;
Simple and to the point, it emits one space character.
SEE SPACE
SPACE
6661 2709 BL
6663 2931 EMIT
6665 2469 EXIT
6
OK
Notice that address 6665 in SPACE also has the word EXIT . If the address after the (?DO) in -TRAILING is replaced with this address, -TRAILING will work exactly as before. The only difference is the EXIT at the end of -TRAILING will not be reached. Not by (?DO) if the count of the string is zero, not by ?LEAVE if there are no more blanks in the string, and not by (LOOP) if the loop runs to completion. They will all branch to address 6665.
The following modification to the source will result in that change.
DUP 0
?DO
1-
LOOP -;
' SPACE >BODY 4 + HERE 2- @ 2- !
Dash semicolon -; finishes the definition without compiling EXIT . The phrase
' SPACE >BODY 4 +
returns the address where there is an EXIT , address 6665 in this case.
HERE 2- @ 2-
backs up to the address of the branch used by (LOOP) and follows it then backs up to the address of the branch used by (?DO) .
Finally, store ! changes the address to 6665.
SEE -TRAILING
-TRAILING
6748 5002 DUP
6750 3293 0
6752 2358 (?DO) 6665
6756 5284 2DUP
6758 4884 +
6760 4815 1-
6762 3576 C@
6764 2709 BL
6766 4474 <>
6768 2128 ?LEAVE
6770 4815 1-
28
OK
Okay, a minor savings of two bytes; however, there is no cost in performance. Here is another example. Fleet Forth's ID. TYPE and QTYPE . QTYPE is used by LIST since a BLOCK might not contain a screen of source. It could be virtual memory or some other type of data.
: ID. ( NFA -- )
1+
BEGIN
COUNT $7F 2DUP AND QEMIT >
UNTIL
DROP PAUSE ;
: TYPE ( ADR CNT -- )
0
?DO
COUNT EMIT
LOOP
DROP PAUSE ;
: QTYPE ( ADR CNT -- )
0
?DO
COUNT QEMIT
LOOP
DROP PAUSE ;
The following modification shaves six bytes off of TYPE and six bytes off of QTYPE .
: ID. ( NFA -- )
1+
BEGIN
UNTIL
[ HERE >A ]
DROP PAUSE ;
0
?DO
COUNT EMIT
LOOP -;
A@ HERE 2- @ 2- !
0
?DO
COUNT QEMIT
LOOP -;
A> HERE 2- @ 2- !
Since this technique is the epitome of highly non portable code, I will most likely confine its use to Fleet Forth's kernel and system loader.
To be clear, this type of DO LOOP places three parameters on the return stack: The address in the cell following (?DO) or (DO) , the loop limit, and the loop index (actually modified versions of the limit and index).
The loop words (?DO) LEAVE ?LEAVE (LOOP) and (+LOOP) all leave the loop by way of this address. (?DO) uses that address to avoid the loop entirely if the limit and initial index are identical.
If this type of DO LOOP were the norm, it would be interesting to see what other creative use could be made of it.
- GARTHWILSON
- Forum Moderator
(I would call that hyphen though, as a dash is longer ( — versus - ). On typewriters, since they were usually monospaced, we used to do a dash with two hyphens in a row.)
Fleet Forth now has a slightly smaller version of NUMBER? with the same functionality.
This is the previous version.
: NUMBER? ( ADR -- D FLAG )
RB
DUP 1+ C@ ASCII # - DUP 3 U<
IF
BASE.TABLE + C@ BASE !
1+ DUP
THEN
DROP
DPL ON 0 0 ROT
1+
COUNT ASCII - <> DUP>R +
COUNT DIGIT NIP >R
2-
BEGIN
CONVERT DUP C@ VALID?
WHILE
DPL OFF
DUP 1+ C@ VALID?
UNTIL
THEN
C@ BL = R> AND
R> ?EXIT
>R DNEGATE R> ;
It takes the address of a counted string and returns a double number and a flag. The flag is true if conversion was successful.
DIGIT ( CHAR -- N TRUE )
( CHAR -- CHAR FALSE )
CONVERT ( D1 ADR1 -- D2 ADR2 )
CONVERT returns the address of the first unconvertible character. This is exactly what I want. It takes the address one byte prior to the first character it will attempt to convert, so I replaced CONVERT with the phrase 1- CONVERT and bumped the address up one byte.
Instead of just testing the first character to see if it is a valid digit, also make it the first digit by placing a copy of the flag to the return stack and replacing
0 0 ROT with AND 0 ROT
Since the loop starts with 1- CONVERT , I was able to make the rest of the loop more efficient.
RB
1+ DUP C@ ASCII # - DUP 3 U<
IF
COUNT
THEN
DROP
DPL ON
COUNT DIGIT DUP>R AND 0
ROT
BEGIN
1- CONVERT COUNT VALID?
WHILE
DPL OFF
DUP C@ VALID?
UNTIL
THEN
1- C@ BL = R> AND
R> ?EXIT
>R DNEGATE R> ;
This version of NUMBER? accepts the same numeric strings as valid, but it is 8 bytes smaller.
I was also able to reduce the size of EVALUATE .
The original EVALUATE .
: EVALUATE ( ADR N -- )
BLK 2@ 2>R
TIB #TIB @ 2>R
#TIB ! (IS) TIB
BLK OFF >IN OFF
INTERPRET
2R> #TIB ! (IS) TIB
2R> BLK 2! ;
Which compiles to this:
SEE EVALUATE
EVALUATE
16274 2540 BLK
16276 4940 2@
16278 4688 2>R
16280 2762 TIB
16282 2624 #TIB
16284 3561 @
16286 4688 2>R
16288 2624 #TIB
16290 3599 !
16292 7783 (IS)
16294 2762 TIB
16296 2540 BLK
16298 5160 OFF
16300 2552 >IN
16302 5160 OFF
16304 8573 INTERPRET
16306 4711 2R>
16308 2624 #TIB
16310 3599 !
16312 7783 (IS)
16314 2762 TIB
16316 4711 2R>
16318 2540 BLK
16320 4965 2!
16322 2469 EXIT
50
OK
The new EVALUATE .
: EVALUATE ( ADR CNT -- )
TIB #TIB @ 2>R
LIT [ >MARK ] ENTER
0 0 LIT
[ ' LINELOAD >BODY DUP 100
" LOAD 0" COUNT MATCH DROP
+ 4 + , ]
ENTER
2R>
[ >RESOLVE ]
#TIB ! (IS) TIB ;
which compiles to this:
SEE EVALUATE
EVALUATE
16290 2762 TIB
16292 2624 #TIB
16294 3561 @
16296 4688 2>R
16298 2497 LIT 16316
16302 13885 ENTER
16304 3293 0
16306 3293 0
16308 2497 LIT 11072
16312 13885 ENTER
16314 4711 2R>
16316 2624 #TIB
16318 3599 !
16320 7783 (IS)
16322 2762 TIB
16324 2469 EXIT
36
OK
Address 11072 (decimal) is in LINELOAD
SEE LINELOAD
LINELOAD
11049 5013 DUP
11051 4608 0=
11053 7854 (ABORT") CAN'T LOAD 0
11068 6936 RB
11070 6966 DECIMAL
11072 2540 BLK
11074 4940 2@
11076 4688 2>R
11078 2540 BLK
11080 3599 !
11082 2719 C/L
11084 5874 *
11086 2552 >IN
11088 3599 !
11090 8573 INTERPRET
11092 4711 2R>
11094 2489 BRANCH 8628 ' QUERY >BODY 27 +
49
OK
8628 :DIS
8628 2540 BLK
8630 4965 2!
8632 2469 EXIT
6
OK
This version of EVALUATE is fourteen bytes smaller.
It uses a minimal ITC, no keep IP and W, all references at return stack.
feel free to comment
(Welcome, agsb!)
agsb wrote:
Please, take a look at https://github.com/agsb/immu/
Have you considered starting a new thread to discuss your Forth and your design goals?
