W6502SBC, a simple 6502 sbc
An old topic has been bothering me for a long time. Assembler and 6502. My C64 has been mothballed for a long time, the VC20 is selling. Nevertheless, I find the 6502 very interesting in terms of assembly language. What you could do with 1MHz and 64kb RAM. This year (2022) the time had come. I decided to build a 6502 SBC. There are many, many posts and suggestions here and on the Internet about this. Unfortunately, there is no version that you could easily rebuild and that meets my expectations of a 6502 workbench computer. Here are my requirements in brief:
- WDC65C02 CPU with 4MHz
- WDC65C22 VIA with 4MHz
- 6551 ASIC for the serial port (R65C51)
- 32Kb or 64KB SRAM (both were available)
- EEPROM or Flash as Kernal/Basic ROM
- NMI and IRQ assignable
- Variable memory allocation, possibly also modifiable from the outside
- Plug-in card system or system bus, preferably with corner edge connectors, as in the C64, VC20, a suitable backplane would be nice
- no video, audio or anything
- SPI over 6522, so you can connect a display/keyboard
- CPLD for something
- opt. LC display
Follow the steps to learn:
- CLPD
- build a simple system on breadboard with 1MHz or with a simple pcb
At the end of the first section there should be a CPU card with a working 6502 system. Incl. BASIC via terminal. VTL-2 and Basl (my own small language) would be considered as further languages. And of course a version of the TPS.
More information and project logs are here:
https://github.com/willie68/w6502sbc
For the latest progress check out my Hackaday page. However, the build log is in German.
https://hackaday.io/project/186414/logs
But I'll try to keep you posted here as well. (in english, of course)
- opt. LC display
- CLPD
don't count on me, i'm engineer (Animotion)
my arduino pages: http://rcarduino.de
Re: W6502SBC, a simple 6502 sbc
to describe the current status,
here is the circuit diagram, a 3d version of the board. And here I have the current status of address decoding,
header:
Name adr_simple ;
PartNo 01 ;
Date 24.07.2022 ;
Revision 03 ;
Designer wkla ;
Company nn ;
Assembly None ;
Location ;
Device G16V8 ;
pld:
PIN [1..8] = [A15..A8];
PIN 9 = PHI2;
PIN 12 = CSRAM;
PIN 13 = CSHIROM;
PIN 14 = CSEXTROM;
PIN 15 = CSIO;
PIN 16 = CSIO3;
PIN 17 = CSIO2;
PIN 18 = CSIO1;
PIN 19 = CSIO0;
/* *************** LOGIC *********************/
FIELD Addr = [A15..A8];
CSRAM_EQU = Addr:[0000..7FFF]; // 32KB
IOPORT_EQU = Addr:[B000..BFFF]; // 4KB
VIAPORT_EQU = Addr:[B000..B0FF];
ACIAPORT_EQU = Addr:[B100..B1FF];
CSIO2PORT_EQU = Addr:[B200..B2FF];
CSIO3PORT_EQU = Addr:[B300..B3FF];
CSEXTROM_EQU = Addr:[8000..AFFF]; // 12KB
CSROM_EQU = Addr:[C000..FFFF]; // 16KB
/* ZP */
CSEXTROM = !CSEXTROM_EQU;
/* RAM */
CSRAM = !CSRAM_EQU # !PHI2;
/* 8kb of ROM */
CSHIROM = !CSROM_EQU;
/* IO */
CSIO= !IOPORT_EQU;
CSIO0 = !VIAPORT_EQU;
CSIO1 = !ACIAPORT_EQU;
CSIO2 = !CSIO2PORT_EQU;
CSIO3 = !CSIO3PORT_EQU;
simulator:
ORDER: A15, A14, A13, A12, A11, A10, A9, A8, PHI2, CSEXTROM, CSRAM, CSHIROM, CSIO, CSIO0, CSIO1, CSIO2, CSIO3;
VECTORS:
/* internal RAM */
0 X X X X X X X 0 H H H H H H H H
0 X X X X X X X 1 H L H H H H H H
/* 8000-AFFF external Rom */
1 0 0 0 X X X X X L H H H H H H H
1 0 0 1 X X X X X L H H H H H H H
1 0 1 0 X X X X X L H H H H H H H
/* IO */
/* CSIO0 */
1 0 1 1 0 0 0 0 X H H H L L H H H
/* CSIO1 */
1 0 1 1 0 0 0 1 X H H H L H L H H
/* CSIO2 */
1 0 1 1 0 0 1 0 X H H H L H H L H
/* CSIO3 */
1 0 1 1 0 0 1 1 X H H H L H H H L
/* nicht direkt benutzt */
1 0 1 1 0 1 X X X H H H L H H H H
1 0 1 1 1 X X X X H H H L H H H H
/* ROM */
1 1 X X X X X X X H H L H H H H H
- akohlbecker
Welcome! Thanks for sharing your project. Eager to see the final result!
- floobydust
First, Welcome and thanks for posting info on your SBC plans. Not sure where you are in Germany, but I used to travel there extensively during the 90's and 2000's... and lived for a couple years in Reutlingen.
So, I've looked at your schematic and browsed your PLD code... here's come comments in no particular order:
- Power supply: as you're using an input diode for blocking reverse voltage, why not replace it with a full-wave bridge? This would allow any polarity on the input and always power the SBC.
- 16V8 PLD: I would recommend using the 22V10 instead. It has more lines and would be a better glue chip. I used one in my C02 Pocket SBC and my Github page has the schematic and code for it.
- R65C51: This is a very old design, really for modems. Note that the older Rockwell parts are not easily found, much less in the higher 4MHz versions. Also note that the recent WDC W65C02 part has a defect with the transmit bit in the status register - there's a long post on the forum here that covers that in gory detail. Using a newer UART/DUART would be a better choice. I (and several others) have switched to NXP chips, mostly the SC28L92 DUART which has two serial ports and a counter/timer.
Also, when coding the PLD, it's best to keep the chip select lines decoded only using the address lines from the CPU. You do need to qualify the Write (and Read) signals for memory and other device to Ph2 clock. Using the 22V10, you can have qualified Read and Write signals, RAM and ROM select lines and 5- I/O selects that are 32-bytes wide.
Note: If you switch to a NXP DUART, you will need an inverted Reset line for that chip. I used a TL7705 which generates both Reset and /Reset and use a DS1813 as an NMI trigger with a momentary switch to trigger a Panic routine.
If you use a larger RAM chip, you can easily change your memory map (just recode the PLD) to get more contiguous RAM memory if needed. Also, where you decode your I/O can make a difference in how you can manage your memory mapping. I always use Page $FE for hardware I/O. This allows a more flexible memory map for contiguous memory.
FInally, best of luck on getting your SBC up and running... there's lots of expertise out here... just ask if you have any questions... and have FUN!
(Great! And thanks for linking your sources and logs.)
i had a some R65xxx already in stock, so i would like to use them.
All the /CS lines there are qualified with Phi2. I simply put this in CPLD code.
...use a DS1813 as an NMI trigger with a momentary switch to trigger a Panic routine.
- GARTHWILSON
- Forum Moderator
willie68 wrote:
I had a some R65xxx already in stock, so I would like to use them.
I got the idea from Garth's 6502 primer. http://wilsonminesco.com/6502primer/addr_decoding.html
Make sure the 65xx I/O ICs' chip-select lines are not qualified by Φ2, and that whichever way you do the RAM, you cannot write to it while Φ2 is down.
Unless you already have something to plug into your expansion port, let me recommend distributing the power and ground connections along the length, for better AC performance, so any given signal's return current path is closer, rather than having to go clear to the end of the connector. The even distribution is all benefits, no disadvantages. I'll put a diagram about that in the 6502 primer. It's also good to arrange the power and ground connections such that if a board gets plugged in backwards, the power and ground still come out correctly so you're less likely to damage things.
I'm planning on using the SPI-interfaced MAX3100 UART for one I'm slowly working on now. I mention it since you're planning on having an SPI anyway for possible use with keyboard and display. There are tons of ICs on the market that use SPI and I²C.
For the other Bus i like the Idea of using edge card connector, like in the C64, with an asymetrical spacer in. The PCBs than only have a small slot milling on the "socket". But that's for later. Now the first prototype has to be up and running. Had to rewire all the address lines on the breadboard yesterday because a few lines were broken.
BTW.: I was thinking about another option to implement an UART.
Using an arduino pro micro. As interface between micro and SBC SPI will work. pro micro, because the USB Interface is already implement, too. And its available in a small formfactor. (And i have some here
(I've a feeling qualifying the RAM's write enable with phi2 might be preferable. But if so, maybe only when pushing the clock speed, and to do that you need also fast peripheral chips, so it might be out of scope.)
At the moment i'm at 1 MHz. Possible going to 2Mhz.
But what you mean is, /CS for RAM without Phi2 involved and the R/W is with Phi2 or should i combine /OE with Phi2 (only for the RAM)?
So, you mean something like this?
header:
Name W6502SBC_16 ;
PartNo 01 ;
Date 05.08.2022 ;
Revision 01 ;
Designer wkla ;
Company nn ;
Assembly None ;
Location ;
Device G22V10 ;
pld:
PIN 1 = PHI2;
PIN 2 = A15;
PIN 3 = A14;
PIN 4 = A13;
PIN 5 = A12;
PIN 6 = A11;
PIN 7 = A10;
PIN 8 = A9;
PIN 9 = A8;
//PIN 10 = nn;
PIN 11 = RW;
//PIN 13 = nn;
PIN 23 = CSRAM;
PIN 22 = CSHIROM;
PIN 21 = CSEXTROM;
PIN 20 = CSIO;
PIN 19 = CSIO0;
PIN 18 = CSIO1;
PIN 17 = CSIO2;
PIN 16 = CSIO3;
PIN 15 = MWR; // /WR only for RAM
PIN 14 = MRD; // goes to all /OE of ROM and RAM
CSRAM = ! (Addr:[0000..7FFF]); // 32KB
CSIO = ! (Addr:[B000..BFFF]); // 4KB
CSIO0 = ! (Addr:[B000..B0FF]);
CSIO1 = ! (Addr:[B100..B1FF]);
CSIO2 = ! (Addr:[B200..B2FF]);
CSIO3 = ! (Addr:[B300..B3FF]);
CSEXTROM = ! (Addr:[8000..AFFF]); // 12KB
CSROM = ! (Addr:[C000..FFFF]); // 16KB
MWR = ! (PHI2 & !RW);
MRD = ! (PHI2 & RW);
simulator:
ORDER: A15, A14, A13, A12, A11, A10, A9, A8, RW, PHI2, CSRAM, CSIO, CSIO0, CSIO1, CSIO2, CSIO3, CSEXTROM, CSHIROM, MWR, MRD;
VECTORS:
/* RAM */
0 X X X X X X X 0 0 L H H H H H H H H H
0 X X X X X X X 0 1 L H H H H H H H L H
/* IO */
1 0 1 1 0 0 0 0 X X H L L H H H H H X X
1 0 1 1 0 0 0 1 X X H L H L H H H H X X
1 0 1 1 0 0 1 0 X X H L H H L H H H X X
1 0 1 1 0 0 1 1 X X H L H H H L H H X X
1 0 1 1 0 1 X X X X H L H H H H H H X X
1 0 1 1 1 X X X X X H L H H H H H H X X
1 0 0 0 X X X X X X H H H H H H L H X X
1 0 0 1 X X X X X X H H H H H H L H X X
1 0 1 0 X X X X X X H H H H H H L H X X
/* ROM */
1 1 X X X X X X 1 0 H H H H H H H L H H
1 1 X X X X X X 1 1 H H H H H H H L H L
1 1 X X X X X X 0 0 H H H H H H H L H H
1 1 X X X X X X 0 1 H H H H H H H L L H
The number one rule, already mentioned by Garth, is that writes to memory must not occur while Phi2 is low. And it's also good (though less desperately important) if reads from memory cannot occur while Phi2 is low.
You have a choice regarding how to proceed. If you qualify the memories' Chip Select inputs with Phi2 then you will automatically satisfy both of the considerations mentioned above (because the chip can neither read nor write when CS is withheld). Qualifying the memories' Chip Selects with Phi2 may result in a very slight speed penalty, but speed is not a concern in your case!
The other way to proceed is to qualify the memories' /WR inputs (and preferably also the /RD aka /OE inputs) with Phi2.
Reminder: these remarks pertain to memory devices. 65xx I/O devices must never have their CS inputs qualified by Phi2 (as Garth already said).
ps- I see you've posted while I was typing. Do your equations conform to what we've been saying? Forgive me if I don't take the time to check!
Thanks all of you. I'll try the new pld on breadboard, if this ever works...
