Dragon 65c816 SBC
GamerFox
Dragon 65c816 SBC
Post by GamerFox »
So, from the design thread in the newbie forum, I refined (mostly by removing things that would only increase complexity for a first-time board) the design. The Dragon v1.0 runs at a 4 MHz clock speed and has:
  • One 65C22 VIA to provide an SPI bus and GPIO
  • DS1305 real-time clock
  • FRAM to hold data not needed in the system ROM (preferences et al)
  • Serial port provided by a MAX3100 and MAX3223
  • MicroSD card slot
The power will be provided by a DC converter board of my own design, mostly so I can use the power supply again and again with later projects.
Future plans include replacing the glue logic ICs with CPLDs and maybe adding a CPLD blitter for display purposes (either a TFT screen or VGA output, haven't decided yet)
pcb.pdf
PCB layout
(397.63 KiB) Downloaded 80 times
65816-comp.pdf
Schematic
(266.94 KiB) Downloaded 101 times
Re: Dragon 65c816 SBC
Let me recommend running the planes between each pair of pads, for much better AC performance, so signals' ground return current doesn't have to veer away from the signal line and go clear around the end of the IC. There's plenty of room to get it between pads.
GamerFox
Post by GamerFox »
On both the power and ground planes? (power on page 2, ground on page 3)
At least the ground plane. Since you have traces on layer 4 that cannot "see" the ground plane, and thus are using the power plane as the ground plane, hopefully you have the power plane bypassed to ground at every power pin. Ideally you'd also have it bypassed also everywhere there's a via from layer 1 to layer 4, to keep the return path continuous next to its signal trace; but I've never seen hobbyist boards go to that extent. 74HC logic definitely won't need it. It's easy to run it between pin pads though. See this post: viewtopic.php?f=12&t=6818&p=87925#p87925
GamerFox
Post by GamerFox »
Is this different from decoupling caps?
same thing, going from power to ground
floobydust
Post by floobydust »
Unless I can't find it... I don't see a Reset circuit for the CPU...
GamerFox
Post by GamerFox »
The reset circuit's on the power board
power.pdf
(27 KiB) Downloaded 63 times
GamerFox
Post by GamerFox »
Here's a new version of the PCB.
boardwork.pdf
(362.34 KiB) Downloaded 71 times
