It is currently Sat Nov 23, 2024 3:56 am
 Post subject: Dragon 65c816 SBC
PostPosted: Wed Dec 29, 2021 11:39 pm
So, from the design thread in the newbie forum, I refined (mostly by removing things that would only increase complexity for a first-time board) the design. The Dragon v1.0 runs at a 4 MHz clock speed and has:
  • One 65C22 VIA to provide an SPI bus and GPIO
  • DS1305 real-time clock
  • FRAM to hold data not needed in the system ROM (preferences et al)
  • Serial port provided by a MAX3100 and MAX3223
  • MicroSD card slot
The power will be provided by a DC converter board of my own design, mostly so I can use the power supply again and again with later projects.
Future plans include replacing the glue logic ICs with CPLDs and maybe adding a CPLD blitter for display purposes (either a TFT screen or VGA output, haven't decided yet)
File comment: PCB layout
pcb.pdf [397.63 KiB]
Downloaded 68 times
File comment: Schematic
65816-comp.pdf [266.94 KiB]
Downloaded 89 times
 Post subject: Re: Dragon 65c816 SBC
PostPosted: Thu Dec 30, 2021 12:23 am
Let me recommend running the planes between each pair of pads, for much better AC performance, so signals' ground return current doesn't have to veer away from the signal line and go clear around the end of the IC. There's plenty of room to get it between pads.
PostPosted: Thu Dec 30, 2021 5:31 am
On both the power and ground planes? (power on page 2, ground on page 3)
PostPosted: Thu Dec 30, 2021 5:47 am
At least the ground plane. Since you have traces on layer 4 that cannot "see" the ground plane, and thus are using the power plane as the ground plane, hopefully you have the power plane bypassed to ground at every power pin. Ideally you'd also have it bypassed also everywhere there's a via from layer 1 to layer 4, to keep the return path continuous next to its signal trace; but I've never seen hobbyist boards go to that extent. 74HC logic definitely won't need it. It's easy to run it between pin pads though. See this post: viewtopic.php?f=12&t=6818&p=87925#p87925
PostPosted: Thu Dec 30, 2021 6:53 am
Is this different from decoupling caps?
PostPosted: Thu Dec 30, 2021 7:14 am
same thing, going from power to ground
PostPosted: Thu Dec 30, 2021 2:04 pm
Unless I can't find it... I don't see a Reset circuit for the CPU...
PostPosted: Thu Dec 30, 2021 5:16 pm
The reset circuit's on the power board
power.pdf [27 KiB]
Downloaded 49 times
PostPosted: Wed Jan 19, 2022 7:24 pm
Here's a new version of the PCB.
boardwork.pdf [362.34 KiB]
Downloaded 61 times
Users browsing this forum: Google [Bot] and 39 guests
