It is currently Wed Sep 25, 2024 9:21 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Jan 24, 2021 5:09 pm
I tried to build, but didn't quite make it. I've contacted the owner of a fork on their Github issue. (Tragically, Andrew passed away earlier this month, so we will need third-party assistance. It would be great to have this project of his available as a runnable release.)
PostPosted: Sun Jan 24, 2021 5:27 pm
Oh my goodness, that's terrible. I had no idea. I've benefitted considerably from his work in both hardware and software, which he gave to the public so generously.
My condolences to his family and friends. A really sad loss to all of those who interacted with him here.
PostPosted: Wed Mar 10, 2021 10:47 pm
Oh-Two wrote:
I've downloaded Andrew Jacob's Dev65 assembler...But I can't figure out how to run it!
This is entirely unrelated to the topic of this thread, so perhaps you could repost your query as the start of a new thread? (I suggest copying the contents of your post here to a new post and editing the one here to point to it.)
I don't mind helping out with some answers, but there's likely to be a lot of back-and-forth that will not be of any interest at all to many readers of this thread.
PostPosted: Sat Aug 21, 2021 6:08 am
I'm the owner of the fork. I will create a buildable version and a runnable release. Sorry to hear about Andrew. That is a terrible loss.
PostPosted: Sat Aug 21, 2021 5:40 pm
Not sure it's something everyone should be using, but personally i added some alternative instruction mnemonics to make them more readable.
specifically for INC, DEC, CL*, SE*, PH*, and PL*
examples:
PHA
PLP
CLC
INX
DEY
SEI
etc
can be turned into:
PSH A
PLL P
CLR C
INC X
DEC Y
SET I
etc
it's especially noticable with the NotePad++ highlighting i'm using for Assembly:
I also got the good old "ADD" and "SUB" Pseudo Instructions which assemble into "CLC ADC" and "SEC SBC" respectively.
and just for fun, and becuase i often hear people compare the Zeropage to a RISC CPU's Register File i added a bunch of RISC-like instructions that actually use the Zeropage as it's Register file. it also predefines some constants so you can use R0-R255 to refer to decimal 0-255, making the RISC Experience even more immersive!
maybe one day i'll make a 65C02 FPGA Core around this idea.
PostPosted: Sat Aug 21, 2021 10:02 pm
Agumander wrote:
One assembler feature I've been wondering exists anywhere is using "{" as label to the next instance of "}", with the ability to nest them.
(It could be some other pair of demarcating characters, those are just the first I think of as a C guy)
This would save me from having to come up with unique label names, or avoid bugs that happen if i miscount bytes when writing BEQ *+n
Had this happen on my current project when I forgot that one of my named memory locations wasn't actually zero page. Oops!
You mean like the .( and .) Block pseudo opcodes of xa65? Ca65 has similar functionality just can't remember right now the names
PostPosted: Sun Aug 22, 2021 1:59 am
If your assembler does not supply them, define the following aliases:
BLO for BCC
BHS for LCS
    cmp     #Value
    blo     Label
is more obvious than
    cmp     #Value
    bcc     Label
PostPosted: Sun Aug 22, 2021 2:30 am
I guess I need some interpretation. BLO looks like "below;" but then BHS should be something like "Same as or above," but it doesn't look anything like that. Whatever it is, it's certainly not obvious. And what is LCS? I can't think of what that might be. Again, definitely not obvious. The aliases I've seen are BLT (branch if less than) for BCC, and BGE (branch if greater than or equal).
Edit, addition: In my program flow-control structure macros, what I would do for the CMP #value, BCC <label> is something like:
        CMP  #value
        IF_GE             ; If it was greater than or equal to the value,
            <do_stuff>    ; do this stuff.
            <do_stuff>
        END_IF
and the IF_GE assembles the BCC down to the END_IF. It leaves a dummy byte for the branch distance, and that byte gets filled in by the END_IF later when it is encountered during assembly. No label is needed. These are nestable too, with more structures of the same or different kind.
PostPosted: Sun Aug 22, 2021 2:35 am
These are from the Motorola instruction sets.
BLT, BLE, BGT, BGE are for use after signed comparision.
BLO (LOwer), BLS (Lower or Same), BHI (Higher) and BHS (Higher or Same) are the unsigned counterparts.
MOS may not have adopted those out of "copyright" concerns.
PostPosted: Sun Aug 22, 2021 2:44 am
Ah, that makes sense, although require a small amount of learning if one has not come from the other processors. I added to my post above while you were posting.
PostPosted: Sun Aug 22, 2021 2:58 am
        CMP  #value
            <do_stuff>
        END_IF
and the IF_GE assembles the BCC down to the END_IF. It leaves a dummy byte for the branch distance, and that byte gets filled in by the END_IF later when it is encountered during assembly. No label is needed. These are nestable too, with more structures of the same or different kind.[/color]
You still have the signed vs unsigned conundrum. Is GE signed or unsigned?
You can choose different phrases or add a suffix: GES and GEU
PostPosted: Sun Aug 22, 2021 3:29 am
For that, I think your signed comparison with the EOR #$80's would come before the IF, like the CMP above comes before the IF. I don't think I have ever done signed for 8-bit numbers though, only 16 or more.
PostPosted: Sun Aug 22, 2021 4:23 am
More likely, they didn't adopt them because the 6502 didn't have a direct equivalent for any of them. As part of the cost reduction done by Chuck Peddle and company, instructions were removed that could be synthesized with short sequences of other instructions.
I personally have never had a need for instruction aliases. To me, it's just more junk to learn. :D
PostPosted: Sun Aug 22, 2021 4:53 am
Getting back on topic, a macro I use a lot in 65C816 programming is one that generates a stack frame when given a list of parameters:
;   generate stack frame from words...
pushparm .macro ...            ;accepts an arbitrary number of parameters
         .if %0                ;if at least 1 parameter...
.i           .set 0            ;initialize parameter index
             .rept %0          ;repeat for number of parameters
.i               .= .i+1
                 pea #%.i      ;push parameter as a word
             .endr             ;end of repeated block
             pea #.i           ;push number of words in frame
         .else
             .error "error: macro syntax: "+%0$+" param1[,param2[,param3]] ..."
         .endif
         .endm
The above is for the Kowalski assembler. The leftmost parameter in the macro invocation will be at the top of the stack frame. The lowest word on the stack, that is, the word at SP+1, will be a count of the total words in the frame, not including the count itself.
The %0$ variable is the macro's name. Should the macro be invoked without any parameters, the message...
    error: macro syntax: pushparm param1[,param2[,param3]] ...
...will be displayed and assembly will halt.
I've found in 65C816 programming that "long" addresses are better handled as 32-bit quantities instead of 24 bits, especially if pointer arithmetic will be involved. The problem is how to push a 32-bit pointer given a 16- or 24-bit address. In the Kowalski assembler, that's easy. For example, to push two 32-bit pointers, the macro would be invoked as follows:
         pushparm ptr1 >> 16, ptr1 & $FFFF, ptr2 >> 16, ptr2 & $FFFF
The >> 16 notation is a 16-bit right-shift and & $FFFF is a logical AND that masks bits 16-31.
PostPosted: Wed Aug 25, 2021 3:28 am
I have created a release of the dev65 assembler that includes an installable binary. I've made it as easy as possible to install on Linux, Mac, and Windows. I wanted to support my Mac G4 but unfortunately this version requires Java 1.6 or greater. The current version of Java is Java 11. If you have that, you're good. Yes, Java version numbering is stupid. If you're still using Java 8, like so many companies are today, it's time to move on.
Download installer
If you have trouble, open an issue and I'll fix it.
