It is currently Mon Sep 23, 2024 9:56 am
Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 Post subject: Re: 65SPI
PostPosted: Tue Jan 19, 2021 5:00 pm
jockm wrote:
do I pick which I want to use, or is it something completely else.
The device is selected only when CS1 is high and /CS2 is low. All other combinations cause it to be de-selected.
In a simple scenario you might choose not to use CS1 (permanently tying it high instead), and drive /CS2 from a suitable address decoder. Or, you might tie /CS2 low, and drive CS1 from a suitable decoder. In other scenarios you might wish to actively use both, as Garth suggests.
One good use of that is to use CS1 for Phi2, and /CS2 for a chip select that is directly derived from the address lines without clock
(sorry if SPI65 has phi2 already there, can't remember right now... :-)
André
PostPosted: Tue Jan 19, 2021 5:17 pm
Additional note:
- the Micro-PET has a very simple SPI interface included (but that only runs in mode 0 and fixed clock), it has a nice feature that reading the data register triggers another byte transfer, so while you store the byte just read, the next byte is already read from the SPI. Only if you read the "peek" register you get the data without triggering another transfer. See here https://github.com/fachat/MicroPET/blob ... LD/SPI.vhd and associated documentation https://github.com/fachat/MicroPET/blob ... PLD/SPI.md
- the Micro-PET boots from SPI, with a very simple schematics: on "ipl='1'" the IPL code shifts out the Flash read command and address zero, then counts 256x8 bits to be shifted in. During shift-in, the address lines are set to high (A8-18), or fed from the IPL counter (A0-7), and set to write, while the shift register output is directly fed to the databus. So the top 256 bytes are loaded into the top of RAM - from where the CPU then boots! See basically the last 60 lines of https://github.com/fachat/MicroPET/blob ... LD/Top.vhd
So, if I have a CPLD on a board, I'll never use a parallel ROM ever again ;-)
Edit: sorry if I'm kind of (inadvertently trying to) capturing the thread, but saw this popping up when I was enthusiastic that I managed to get my boot-from-SPI working
PostPosted: Tue Jan 19, 2021 5:50 pm
hello Bill,
It looks like you captured all the logic accurately. For the clock circuit of the SO[0..7], the following can be used. I may have had problems with an XOR in the logic, so I worked around it the long way. I'm not sure which is more efficient for Altera.
It does appear that the preset and reset of the flipflops are active low, so your added inversion also looks correct.
Please report back your results when you are able to test the functions in circuit.
PostPosted: Tue Jan 19, 2021 6:28 pm
Hi Daryl,
Thank you for looking over the schematic. I'm please to know it is correct. Altera Quartus software will minimize the logic automatically so the gates drawn in the schematic are not necessarily implemented as is.
I do have SPI based Ethernet as well as and SD card. I'll let you know how the schematically based CPLD worked out. Using Atmel's pof2jed program I can also convert Altera's .pof file to jed file to program your ATF1504 so you can also check it out on your hardware setup.
Attached is the Quartus design files of the 65SPI that you've looked over.
65SPI_altera_proof_read.zip [59.06 KiB]
Downloaded 87 times
PostPosted: Thu Jan 28, 2021 6:53 pm
I ordered a few SPI EEPROM, 25LC080, from Mouser and built a CPLD protoboard so I can use CRC65 SBC to test the 65SPI designed in Altera schematic. The CPLD prototype board already have existing pin assignment so I removed a few pins from 65SPI so they will fit. The pins removed are MRD, MWR, CS2, and 5 slave selects. It compiled OK with 75% macrocell utilization. I'm ready to write the software to test the SPI.
PostPosted: Thu Jan 28, 2021 10:24 pm
Awesome! I look forward to the results.
Good luck!
PostPosted: Fri Jan 29, 2021 1:42 pm
Powered up the board and no smoke!
25LC080 is a relatively slow SPI device, so instead of using external clock, I just slow down 6502 to 7.37MHz. Fixed a couple simple mistakes and I'm able to talk to 25LC080, but there is a problem: writing to SPI control is causing soft reset even though the software reset bit is 0. I believe the problem is due to data bit 7 not valid until near the falling edge of PHI2 clock. While data bit 7 is changing, it can generate glitch on the asynchronous preset of flip flop. I redesigned the SRES logic so data is latched in on the falling edge of clock and cleared on the next falling edge of clock. In attached schematic, the bottom flip flop was the original SRES logic. The top flip flop is the modified logic (note: nCLK is inverted PHI2).
With that mod, I can now change the SPI control without spurious reset. I have more tests to do...
SRES_logic.pdf [19.82 KiB]
Downloaded 83 times
PostPosted: Fri Jan 29, 2021 3:59 pm
That's good news. I added the soft reset in the move from Zilinx to Atmel. it was not really tested thoroughly. I'll have to go back and see if the Atmel version has any issues. I believe 1 person has it working in hardware.
PostPosted: Fri Jan 29, 2021 6:35 pm
I am able to write and read verify 25LC080 serial EEPROM with 7.37MHz 6502 CPU clock. I change 6502 CPU clock back to 14.7MHz and run the same test again. In this case SPI clock is 7.37MHz, twice the SPI speed rating of 25LC080, but it all works just fine. I guess 25LC080 SPI spec is conservative.
The reason I changed the CPU clock back to the original 14.7MHz is because I want to check whether 65SPI will run at 14.7MHz and whether the external clock feature works So I divided the 14.7MHz clock by 4 and used it as the external clock input; enable the ECE bit of the SPI Control; verify the clocking is 1.84MHz and do EEPROM write followed by read verify. All works perfectly. Yep, it is all good and I'm satisfied. Please let me know if there are anything you want me to test.
PostPosted: Fri Jan 29, 2021 6:46 pm
If I ever run out of projects (unlikely), I can work on this: QVGA over SPI. I have at least 3 projects ahead of it.
PostPosted: Sun Aug 01, 2021 8:53 pm
sorry to just burst into here like this...
but recently i've been thinking about using SPI as an expansion bus (similar to PCIe) to save on Pins required for an expansion connector. though controlling multiple /SS lines with a single SPI Master seems complicated.
anyways, the idea made me wonder how one would go about hooking up a regular 8 bit parallel device (like a Video Controller, Sound chip, etc) to an SPI Bus as a slave.
I don't know if someone else has already thought about this or even tried it...
but in my search i came across these SPI 8/16 bit GPIO Expanders. the MCP23S08 and MCP23S18. they come in a DIP package and run at 1.8V to 5V, though their SPI speed is limited to 10MHz. (maybe overclockable?)
the 8 bit version seems a bit more useful since you can put 4 of them in parallel using the same /SS line from the SPI Master, while the 16 bit one only has that option for the I2C version of the chip.
i was also thinking that the 8 bit chip could be replicated using a CPLD, allowing for potentially higher Clock Speeds and more specific features around connecting to 8 bit devices. though that would obviously drive up the total cost of the interface.
either way, any thoughts on this?
PostPosted: Sun Aug 01, 2021 10:21 pm
Nowaday I'm leaning more toward serial expansion as well. This is lesson-learned from overclocking of W65C02 which can easily run twice the manufacturer's max frequency of 14MHz PROVIDED the number of core devices is small to keep down the bus loads and minimize bus interconnections. Conceptually the core devices are CPU, CPLD, RAM, and dual-port RAM (video); everything else (keyboard, boot serial EPROM, GPIO, serial, I2C, SPI) are connected to CPLD serially. My feeling is a full featured W65C02 can operate at 30+Mhz in such configuration. I'm looking at Olimex's UEXT which supports I2C, SPI, and serial in a 2x5 header.
PostPosted: Mon Aug 02, 2021 12:00 am
Bill, before committing, do consider also our SPI-10 hobbyist-friendly connector. From the "Expansion buses and interfaces" page of the 6502 primer:
    In this forum post in the topic "Standardizing an SPI module pinout: SPI-10," we have finalized (as of Oct 31, 2016) a hobbyist-friendly connector and pinout for small SPI modules, called "SPI-10." It is partially compatible with UEXT which also has asynchronous serial and I²C and already has quite a few modules available but lacks 5V support, interrupts, reset, an auxiliary line, and keying for keeping non-IDC connectors from getting plugged in backwards—all needs which are met by SPI-10.
For I²C, there's also our I2C-6 hobbyist-friendly connector which also has the IRQ\ line which will be needed for I²C devices like a keyboard scanner IC which could interrupt when a key is pressed, or a real-time clock IC that would interrupt when an alarm comes due.
PostPosted: Mon Aug 02, 2021 7:52 am
why not combine both into a single 12 pin connector?
it would mean that both I2C and SPI Devices could share the same connector for Computers that support both SPI and I2C.
PostPosted: Mon Aug 02, 2021 8:07 am
12-pin is not a standard size, so you couldn't get a shrouded header like you can for 10 or 14; otherwise I suppose you could combine them, but I don't see any need to. They're small and you'd probably want at least a couple of each on a computer, for example to have a couple of tiny SPI flash modules to copy files from one to another while having an I²C one for a RTC and maybe one for something else. On the SPI ones, you might want at least two for the different voltages too (3.3V and 5V), keyed so you can't mix them up and damage a 3.3V device in the 5V port. (Every I²C device I've seen can handle 5V, so it's not a concern there.) The I²C ones I've made for myself are narrower than a 10- or 14-pin header.
