I've got a WDC 65c02 paired with an AT28C256 EEPROM that I've programmed entirely with $ea as a means of testing. I'm using a TL866ii+ and I've written/read from the 3 different EEPROMs using both the OEM Windows software and David Griffith's "minipro" software. The chips all check out ok - the reads and writes are successful.
The problem, however, is that once the EEPROM is in my circuit, the 6502 always reads $fffc as $00. Each of the three AT28C256's behave the same.
$fffd reads properly as $ea, thus my starting address is always $ea00 instead of $eaea.
The clock is manual right now and based on 555 timers - built following Ben Eater's project on YouTube.
Monitoring the address and data pins with an Arduino, the output below is consistent. I have disassembled and rebuilt the circuit 3 times, double/triple checking my wiring, components, continuity, and voltages.
|-address pins-| |data pins|
1111111111111111 11101010 ffff r ea
0000000000000000 11101010 0000 r ea
0000000100000000 11101010 0100 r ea
0000000111111111 11101010 01ff r ea
0000000111111110 11101010 01fe r ea
1111111111111100 00000000 fffc r 00
1111111111111101 11101010 fffd r ea
1110101000000000 00000000 ea00 r 00
1110101000000001 11101010 ea01 r ea
0000000111111101 11101010 01fd W ea
0000000111111100 00000010 01fc W 02
0000000111111011 00110100 01fb W 34
1111111111111110 00000000 fffe r 00
With the EEPROM programmed for all $ea ... I'm only expecting the 6502 to go to $eaea after initialization and proceed counting up from that address with a series of NOP instructions.
I've also replaced the 65c02 thinking perhaps my chip was the culprit - but same behavior on the other 65c02 as well.
Someone had suggested I try programming the EEPROMs with something other than $ea - and since it always wants to jump to $ea00, put the instructions there. I've done this, but unfortunately I'm still quite early in learning about the 6502 and I'm not able to make much sense of this.
I programmed one of the AT28C256's with the following:
rom[0x6a00] = 0x08
rom[0x6a01] = 0x18
rom[0x6a02] = 0x28
rom[0x6a03] = 0x38
rom[0x6a04] = 0x48
rom[0x6a05] = 0x58
rom[0x6a06] = 0x68
rom[0x6a07] = 0x78
rom[0x6a08] = 0x88
rom[0x6a09] = 0x98
rom[0x6a0a] = 0xa8
rom[0x6a0b] = 0xb8
rom[0x6a0c] = 0xc8
rom[0x6a0d] = 0xd8
rom[0x6a0e] = 0xe8
rom[0x6a0f] = 0xf8
rom[0x6a10] = 0x20
rom[0x6a11] = 0x00
rom[0x6a12] = 0xea
11101010 0000 r ea
11101010 0000 r ea
11101010 0000 r ea
11101010 0000 r ea
11101010 0000 r ea
11101010 0000 r ea
00000000 0000 r 00 <- $fffc
11101010 0000 r ea
00001000 0000 r 08 <- $ea00 ($6a00 on the eeprom)
00011000 0000 r 18 <- $ea01 ($6a01)
00110100 0000 W 34
00000000 0000 r 00
00101000 0000 r 28 <- $ea02 ($6a02)
11101010 0000 W ea
00000011 0000 W 03
00110100 0000 W 34
00000000 0000 r 00
11101010 0000 r ea
00001000 0000 r 08 <- back to $ea00 and repeat
00011000 0000 r 18
00110100 0000 W 34
00000000 0000 r 00
00101000 0000 r 28
11101010 0000 W ea
00000011 0000 W 03
00110100 0000 W 34
00000000 0000 r 00
11101010 0000 r ea
00001000 0000 r 08 <- cycle starts again
00011000 0000 r 18
00110100 0000 W 34
00000000 0000 r 00
00101000 0000 r 28
11101010 0000 W ea
00000011 0000 W 03
00110100 0000 W 34
00000000 0000 r 00
11101010 0000 r ea
Basically I'm completely stuck at the moment an unsure what to troubleshoot next. Any suggestions on something I can try?
Pic of my circuit can be found here: https://imgur.com/a/V4fHCDu
