It is currently Sat Nov 23, 2024 7:14 am
 Post subject: 6502-Builds
PostPosted: Wed Jan 27, 2021 7:58 pm
Guys, been a while since I've been online!
I was chatting with someone recently about 6502 stuff and thought I would share my 6502 build environment.
https://github.com/cbmeeks/6502-Builds
Basically, it's just a build script around the original WozMon, Microsoft BASIC (for multiple platforms), etc.
When you run the build script, look in each folder under "dist" for the binaries.
There may be some config you may have to make (file locations, etc.). Let me know if you need any help.
Anyway, I hope this helps someone out and wanted to share.
Enjoy!
 Post subject: Re: 6502-Builds
PostPosted: Wed Jan 27, 2021 8:18 pm
Thanks for sharing!
PostPosted: Wed Jan 27, 2021 9:17 pm
My pleasure. It's not perfect, but it was very helpful for me a while back.
PostPosted: Thu Jan 28, 2021 8:48 am
I see that you have quite a presence on github! I joined several months ago, but so far I've just been lurking and trolling a bit and trying to get the feel of things. My trusty old Vi$ta desktop machine appears to have finally died, so I'll be switching to a slightly more modern platform, which should allow me to update Chrome and interact more easily with github. I will be going over much of my personal assembly (and BASIC) source code from the last 39 years and uploading it gradually to my account, probably after converting to Kowalski Simulator format for the (generic) 6502 stuff and running some superficial verification tests.
PostPosted: Thu Jan 28, 2021 1:30 pm
Yeah, I've used GitHub for years. I used to be a paid member but some time ago, they started allowing private repos for free.
I would love to see your code uploaded! What is your GitHub handle?
PostPosted: Thu Jan 28, 2021 4:06 pm
You get one free guess ... after that, I'll have to charge ya! :D
[BTW: 95838 is my postal ZIP code. I paid off the mortgage on my old run-down shanty last month, so there's a significant chance that I'll be staying here until I die or the house falls down.
PostPosted: Thu Jan 28, 2021 9:13 pm
Oh man...you made me have to work and use my brain. Too old and tired for that. LOL
I found ya.
BTW, I like that shanty. Many of those around where I live. Still looks better than the place I lived when I was young. lol
PostPosted: Fri Jan 29, 2021 6:50 am
barrym95838 wrote:
[BTW: 95838 is my postal ZIP code. I paid off the mortgage on my old run-down shanty last month, so there's a significant chance that I'll be staying here until I die or the house falls down.]
Could use a coat of paint, but otherwise seems fine. :D
PostPosted: Fri Jan 29, 2021 7:13 am
In its original form it might have been about as simple as I want to live. It makes me dizzy when a building's walls aren't vertical though.
PostPosted: Fri Jan 29, 2021 2:46 pm
:mrgreen:
PostPosted: Fri Jan 29, 2021 3:27 pm
:mrgreen:
That was an improvement, but it could really use some paint. :D Also, where's the outhouse? :shock:
PostPosted: Fri Jan 29, 2021 3:31 pm
Barry has a composting toilet inside run off highly efficient 6502 ASM. Everything running in zero page. ;-)
PostPosted: Fri Jan 29, 2021 9:48 pm
It would take an awful lot of paint to seal and hold that one up!
PostPosted: Tue Feb 16, 2021 4:07 pm
Is that for taking a number zero?
