6502-Builds
6502-Builds
Guys, been a while since I've been online!
I was chatting with someone recently about 6502 stuff and thought I would share my 6502 build environment.
https://github.com/cbmeeks/6502-Builds
Basically, it's just a build script around the original WozMon, Microsoft BASIC (for multiple platforms), etc.
When you run the build script, look in each folder under "dist" for the binaries.
There may be some config you may have to make (file locations, etc.). Let me know if you need any help.
Anyway, I hope this helps someone out and wanted to share.
Enjoy!
Enjoy!
Re: 6502-Builds
Thanks for sharing!
Re: 6502-Builds
My pleasure. It's not perfect, but it was very helpful for me a while back.
- barrym95838
Re: 6502-Builds
I see that you have quite a presence on github! I joined several months ago, but so far I've just been lurking and trolling a bit and trying to get the feel of things. My trusty old Vi$ta desktop machine appears to have finally died, so I'll be switching to a slightly more modern platform, which should allow me to update Chrome and interact more easily with github. I will be going over much of my personal assembly (and BASIC) source code from the last 39 years and uploading it gradually to my account, probably after converting to Kowalski Simulator format for the (generic) 6502 stuff and running some superficial verification tests.
Re: 6502-Builds
Yeah, I've used GitHub for years. I used to be a paid member but some time ago, they started allowing private repos for free.
I would love to see your code uploaded! What is your GitHub handle?
- barrym95838
Re: 6502-Builds
[BTW: 95838 is my postal ZIP code. I paid off the mortgage on my old run-down shanty last month, so there's a significant chance that I'll be staying here until I die or the house falls down. ]
Re: 6502-Builds
Oh man...you made me have to work and use my brain. Too old and tired for that. LOL
I found ya.
BTW, I like that shanty. Many of those around where I live. Still looks better than the place I lived when I was young. lol
I found ya.
- BigDumbDinosaur
Re: 6502-Builds
barrym95838 wrote:
[BTW: 95838 is my postal ZIP code. I paid off the mortgage on my old run-down shanty last month, so there's a significant chance that I'll be staying here until I die or the house falls down.]
- GARTHWILSON
- Forum Moderator
Re: 6502-Builds
In its original form it might have been about as simple as I want to live. It makes me dizzy when a building's walls aren't vertical though.
Re: 6502-Builds
- BigDumbDinosaur
Re: 6502-Builds
That was an improvement, but it could really use some paint.
Re: 6502-Builds
Also, where's the outhouse?
- GARTHWILSON
- Forum Moderator
Re: 6502-Builds
It would take an awful lot of paint to seal and hold that one up!
- Sheep64
- In Memoriam
Re: 6502-Builds
cbmeeks on Fri 29 Jan 2021 wrote:
Barry has a composting toilet inside run off highly efficient 6502 ASM. Everything running in zero page.
