CRC65, A frugal 6502 SBC
Re: CRC65, A frugal 6502 SBC
An user reported write problems with certain brand of CF disk, so I delved into the timing of the CF disk and came up with a interim solution that should fix the write problem. The updated CPLD equation is here: https://www.retrobrewcomputers.org/lib/ ... _12_21.zip
As I did more testing, I discovered an unexpected result: I can now run CRC65 at 29.5MHz! It is just a matter of replacing the 14.7MHz oscillator with 29.5MHz oscillator and change the serial baud to 230400. That's all. CRC65 retains all the original functions but will now run twice as fast. It turns out the previous overclocking limitations were also CF disk related and I didn't realize it was not a CF access time problem, but a hold time problem.
ASCII mandelbrot in 38 seconds, wow!
I think I'll get up now and go toot my horn and pound on my chest a bit...
I'm curious about your algorithm/code. My BBC Basic version (which I used as a crude BASIC benchmark) runs in 48 seconds on my 16Mhz 65C02 board
https://unicorn.drogon.net/mandel.txt
code:
https://unicorn.drogon.net/mandel.bas
If you're running a Basic, give that version a go - it should run under most Microsoft style BASICs unchanged.
And this:
!!!!!!!!!!""""""######################$$$$$$$$$$%%%&'(),7*'&%%$$$$$$######"""""
!!!!!!""####################$$$$$$%%%%%&'(.</1+-@@@>@@@@@@@@@/@3)(()1*'%$$#####
!!!!!"###############$$$%%%%%%%%%%&&&&'+/.2@@@@@@@@@@@@@@@@@@@@@@@@@+('&%%$$###
!!!!"##########$$$$$%%&**''''''''''''((+0@@@@@@@@@@@@@@@@@@@@@@@@@@@@+)-&%$$###
!!!!"####$$$$$$$$%%%%&'(=0-+*+32*-)))*+2@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@3+&%$$$##
!!!!##$$$$$$$$$%%%%%&''(*2@@@@@@@@8.,,@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@-+&%$$$##
!!!"$$$$$$$$%%%%%%&)()),@@@@@@@@@@@@@2@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@96'%%$$$$#
!!!#$%%$$$%&&&&''')*1341@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@*'&%%$$$$#
!!!((*++,@0--5//15<@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@6,)'&&%%$$$$#
!!!#$%%%$%&&&&&''')*<:@3@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@)'&%%$$$$#
!!!"$$$$$$$$%%%%%&&*()),@@@@@@@@@@@@@3@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@0'%%$$$$#
!!!!##$$$$$$$$%%%%%%&'')*@@@@@@@@@>0,,@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@1.&%$$$##
!!!!#####$$$$$$$$%%%%&'(:<-+*,1@+@)))*+2@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@5*&%$$$##
!!!!"#########$$$$$$%&&)*'''''(''''''()+/@@@@@@@@@@@@@@@@@@@@@@@@@@@6+)-&%$$###
!!!!!"##############$$$%%%%%%%%%%%&&&&'82/1@@@@@@@@@@@@@@@@@@@@@@@@2+('&%%$$###
!!!!!""#################$$$$%%%%%%%%%&&&'),@@@@@@@@@@@@@@@@@@@@@@8@@@+(%%$$####
!!!!!!""####################$$$$$$%%%%%&')/@0@+-@@@@@@@@@@@@@0@@)))),*'%$$#####
!!!!!!!!""""#####################$$$$$$$$$$%%&&&&'(*8@@@@@@,('&%%%%%$$$########
!!!!!!!!!"""""#####################$$$$$$$$$$%%%%&')-+/@@2))&%%%$$$$$$#######""
!!!!!!!!!!""""""######################$$$$$$$$$%%%%&'(),0*'&%%$$$$$$######"""""
Time taken: 10952
I'm using EhBASIC, 2.22p4 running the program below. I've not tried porting BBC BASIC to my hardware. I did run your benchmark on EhBASIC and it took 43 seconds with 29.5MHz CPU clock. So either BBC BASIC is significantly better than EhBASIC or my CRC65 running at 29.5MHz is actually not that fast. I should find out which...
10 MAXITER=20
20 LET C$=" .,'~!^:;[/<&?oxOX# "
30 FOR Y=-39 TO 39
40 FOR X=-39 TO 39
50 CREAL=X/20
70 CIMAG=Y/20
80 ZREAL = CREAL
90 ZIMAG = CIMAG
95 COUNT = 1
100 ZM = ZREAL*ZREAL
105 ZN = ZIMAG*ZIMAG
107 ZL = ZM+ZN
110 IF ZL>4 THEN GOTO 170
120 Z2=ZM-ZN+CREAL
130 ZIMAG=ZREAL*ZIMAG*2+CIMAG
140 ZREAL=Z2
150 COUNT=COUNT+1
160 IF COUNT<MAXITER THEN GOTO 100
170 PRINT MID$(C$,1+COUNT,1);
180 NEXT X
185 PRINT ""
190 NEXT Y
200 END
10 MAXITER=20
30 FOR Y=-39 TO 39
40 FOR X=-39 TO 39
50 CREAL=X/20
70 CIMAG=Y/20
80 ZREAL = CREAL
90 ZIMAG = CIMAG
95 COUNT = 1
107 ZL = ZM+ZN
120 Z2=ZM-ZN+CREAL
140 ZREAL=Z2
150 COUNT=COUNT+1
180 NEXT X
185 PRINT ""
190 NEXT Y
200 END
BBC Basic is significantly better (and faster!) than EhBasic; I think it is commonly held to be about twice as fast as MSBasic and similar Basics. Soooo, your 29.5MHz CRC65 is definitely no slouch
https://projects.drogon.net/comparing-old-basics/
However that does not detract from your near 30Mhz system - which is pretty good!
Thanks for sharing that benchmark video, Gordon - interesting that over in this thread on stardot we more or less concluded that BBC Basic's main advantage came from the BBC Micro's 2MHz CPU speed. (Perhaps you were running Basic 4? That's certainly faster in some ways, as it uses 'C02 opcodes and was a revisiting of Basic 2.)
- Sheep64
- In Memoriam
plasmo on Wed 6 Jan 2021 wrote:
* 64-byte ROM, dual boot either from serial port or CF disk
From my calculations, booting from opto-resistors has a soft limit of 64 bytes. That is less restrictive than I first imagined.
* PC board size goal of 100mm X 50mm, so 2 pc boards per 100mm X 100mm panel.
BigEd on Sat 16 Jan 2021 wrote:
An application! Excellent. It's but a small step to make this an alarm clock and a stopwatch... or egg timer.
plasmo on Thu 21 Jan 2021 wrote:
My pc board shipment is taking a walkabout all over USA. It came through Los Angeles gateway early last Friday morning, then went to San Diego, then to Phoenix, to Tucson, back to Phoenix, and now is on hold in Cincinnati.
plasmo on Sun 24 Jan 2021 wrote:
Given the murky supply chain for the retro hobbyist electronics, it really is a good idea to build multiple boards to prove out a design and then periodically build a couple boards during the life of the product.
I was shocked by the level of excess packaging from electronic distributors. Honestly, do my 14 pin DIP sockets have to placed in a tube, wrapped in anti-static packaging and sealed with tamper-proof stickers? After reading the terms and conditions of sale, it is apparent that some fraudsters purchase genuine components and then "return" fakes. This leaves the fraudster with higher quality components while the distributor unwittingly conveys counterfeit electronics. Apparently, this either extends to DIP sockets or the warehouse staff have been trained to package everything to this standard. I would prefer that the components weren't packaged, packaged again, sealed, bar-coded, bagged, bubble-wrapped and boxed. However, that is the minimum to counter deceitful customers.
plasmo on Mon 25 Jan 2021 wrote:
Anyone in USA interested in trying out CRC65, I'm giving away 3 blank pc boards.
- GARTHWILSON
- Forum Moderator
Sheep64 wrote:
I was shocked by the level of excess packaging from electronic distributors. [...]
Most things about electronics, these days, make sense at scale. Even a thousand units isn't appropriate scale for everything to work out - and yet, in the hobbyist world, we seldom get up to even a hundred units. So we see odd things...
It's BBC Basic that's significantly faster and better in the opinion of many. I benchmarked them together some time back.
I also upgraded all 7 CRC65 boards I have to 29.5MHz. All except one were able to run at 29.5MHz, so W26C02's 14MHz max rating is quite conservative. Ironically, the one that failed was the one I built specifically for overclocking experiment; it has fast (10nS) RAM and fast CPLD (5nS) whereas other 6 boards have 25nS RAM and 10nS CPLD. The failed board actually works better at lower voltage, lower than 4.9V, so my suspicion is system noise is causing the failure. CRC65 is 2-layer board with no design consideration for signal integrity, so I'm asking for troubles with 10nS RAM and 5nS CPLD and it shows.
Blank pc board is easy & cheap to ship. 50mm X 100mm board is lesser than 1oz, so I just put it in regular domestic 1st class letter mail or even International 1st class letter mail. It is important to keep the pc board away from the postmarking machine at the top edge of the envelop.
- floobydust
I also took one of my C02 Pocket SBC boards and put a 7.3728MHz oscillator in it. Using the same Basic program, it completes the Mandelbrot in 148.01 seconds. Note that this is using my CMOS version of EhBasic. I would also note that the Pocket SBC has a 10ms jiffy timer via the SCC2691 UART which sequences a software RTC along with the Benchmark timer (which measures the 148.01 seconds) and also has interrupt-driven send and receive for the UART. I also matched the 57.6K baud rate for the test.
Granted, it's not a massive speed increase, but it is certainly faster... perhaps as much as 4%, depending on the test. I've uploaded the latest 2.22p5C02 version, which is both easier to integrate to an existing system and everything is contained in a single source file. All you need to change is the character in and out routines to your monitor's equiavalents at a minimum.
Bought few I2C 128x128 OLED with 16 grey levels to experiment with.
https://www.ebay.com/itm/3pcs-1-5inch-I ... 3696175425
It is a nice looking display that's 1.3 inch wide instead of 1" wide of the 128x64 OLED display. Unfortunately the pin assignments are different than the 128x64 OLED, so I have to build an adapter board to swap VCC and GND pins.
The display initialization routines are different than 128x64 OLED; after plowing through the SSD1327 datasheet and becoming frustrated with the large list of options, half of which I don't understand, I skipped all that and used the reset default values. It worked fine just with a command to turn on the display.
The display data format is also different; instead of 8 pixels per data byte, it is now 2 pixels per byte with 16 grey levels per pixel. The amount of data to fill a screen goes up by a factor of 8 (twice the screen resolution, and 4 times the data per pixel), so instead of 50mS to fill a 128x64 screen it now takes about 400mS to fill the screen. The screen fill is noticeable now.
The biggest hurdle I encountered was the interleaving of the screen; no where in the data sheet mentioned that. Once I've figured out that it fills every other lines when writing to the screen, everything works just fine.
