It is currently Sat Nov 23, 2024 1:48 pm
PostPosted: Fri Jan 29, 2021 3:35 pm
I got one of these for very cheap though never got it going: https://datasheetspdf.com/pdf-file/5363 ... /EW32F50/1
The one I have requires -27v for contrast. How are you planning on generating the negative voltage? I see 8BIT is using an AA9090A running off 12v. Someone got one of the LCDs going using three 9v batteries, though I was hoping to generate it from the same 5v power source as everything else.
One thing, at least for the model I have, is that you need to start up the LCD first then apply the negative voltage after it's started. Not sure if that's something useful to try for yours.
PostPosted: Fri Jan 29, 2021 4:04 pm
I'm using a separate adjustable bench power supply to provide the negative voltage right now. Once I got it working, I will need to figure out how to generate -16V from 5V, don't think a simple charge pump doubler will do, need a bona fide booster converter.
PostPosted: Fri Jan 29, 2021 6:20 pm
The Z-80 has DMA capability which would increase efficiency for refreshing the display. I would not give up on that idea. I did do a composite video graphical display with an ATMega1284 which included the AVR doing Line, Box, and circle generation along with text. I cannot speak to the speed at this point as I don't recall, but it did work. It also had the option to output to an LCD.
PostPosted: Sat Jan 30, 2021 1:30 pm
In the Z80 world I probably would use a Z280 which has 4 DMA channels built in. Since this is 6502 forum, I thought I'd try it again using my newly developed 6502 SBC with the help of a CPLD I/O board. The CPLD I/O board was a CF drive interface board re-purposed as LCD interface. I'll need to make some cuts and jumpers and reprogram the CPLD, but conceptually it looks like the attached photos.
File comment: CRC65 SBC with CPLD I/O board driving the UG-32F01 320x240 LCD display
PostPosted: Sun Jan 31, 2021 2:51 pm
Daryl,
Sometimes just KNOWING that I'm on the right track is enough to solve the problem. Before I dive into your ATmega program trying to understand yet another assembly language, I thought I take another fresh look at my LCD interface logic and software since I'm using a new CPLD board with 6502. I found a couple mistakes and fixed them. Now I can actually display a pattern on the LCD! This is very encouraging.
File comment: UG-32F01 displaying a pattern
PostPosted: Sun Jan 31, 2021 6:04 pm
I'm glad you are making headway! If it helps, the only file you need to focus on is "vidgen.asm" It does all of the refresh based on an interrupt.
In Vid-LCD.asm, I set up a timer interrupt to provide 1 interrupt every 55.6us (microseconds). This does a refresh of 1 line. Doing the math, it completes a frame every 13.3mS, which is a 74.9Hz frame rate.
I don't recall the time needed to generate 1 line, but counting cycles in the code would provide that data.
Hope that helps.
PostPosted: Mon Feb 01, 2021 1:38 am
This is the program driving the display in my previous post. The display memory is 10K from 0xC000-0xE7FF. It started off with random display data and then filled it with one-byte pattern every frame. It took 2 minutes 10 seconds to fill the entire display this way. So that's 10K frames in 130 seconds or 74 frames per second, which is what I measured with a scope. This is 6502 is running flat out moving display data to the LCD display, not very good use of a 6502, but now I understand how it works, I can start to replace the software with hardware.
tstLCD.txt [2.07 KiB]
Downloaded 60 times
cron
