It is currently Mon Jun 24, 2024 12:50 pm
 Post subject: Font for graphical LCD
PostPosted: Fri Dec 18, 2020 10:12 pm
I finally got a 128x64 graphical LCD working with a 6507 an 6532 for my calculator project. The LCD doesn't have a font built in. Does anyone know if there is a 5x8 one in the Public Domain I can use? According to what I've read, a "bitmapped typeface" cannot be copyrighted but it can be patented.
PostPosted: Fri Dec 18, 2020 10:54 pm
What characters do you need?
PostPosted: Sat Dec 19, 2020 2:05 am
If 5x8 does not include the blank column separating characters, you could just copy what all the intelligent character LCDs use, shown near the top of the displays page of the 6502 primer. If you want something smaller, to get more characters in since it's a pretty small display, see if https://www.hpcalc.org/hp49/utils/fonts/ helps. There are lots of fonts there.
PostPosted: Sat Dec 19, 2020 2:53 am
There is VB source code for a primitive font (glyph) editor which has been used to develop fonts for a FPGA based display controller here:
https://github.com/robfinch/Cores/tree/master/software/GlyphEdit
It is pretty primitive but works enough to create fonts. It can handle just about any font size up to 32x32.
http://www.finitron.ca
PostPosted: Sat Dec 19, 2020 6:36 am
Just the standard ones from ! to ~ which includes upper and lowercase, numbers, and the most common punctuation and symbols.
Thanks! What is the copyright situation on those though? If the character set for those intelligent displays is in the public domain, I haven't been able to find mention of it yet.
PostPosted: Sat Dec 19, 2020 1:30 pm
They have some fonts at OpenGameArt.org. The licensing is usually okay. Author typically just want a note to the origin. I have used images from that source before.
PostPosted: Wed Dec 23, 2020 6:53 pm
Here's one I generated years ago. It's in a bit of an odd format for historical reasons... It's intended for a 128 x 64 LCD/OLED display, which tend to use a memory map where the 128 columns go right to left and 8 rows of eight pixels go top to bottom; bit zero of the memory is the highest. On that display dimension, it gives four rows of twenty-three columns.
The font is six pixels wide by sixteen pixels high, stored as five pixels wide (there isn't a lot of point wasting space by storing the blanks) and doesn't have an characters below the space. Ten bytes per character; odd bytes along the line are the bottom half of the character and even bytes are the top half. In both cases, bit zero is at the top.
This is a larger font than the one requested by the OP but it's available for any use - including playing with it to change it.
const uint8_t fonts[960] = {
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,    // ' '
   0x00, 0x00, 0x00, 0x00, 0x0B, 0xF8, 0x00, 0x00, 0x00, 0x00,    // '!'
   0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00,    // '"'
   0x02, 0x20, 0x0F, 0xF8, 0x02, 0x20, 0x0F, 0xF8, 0x02, 0x20,    // '#'
   0x04, 0x60, 0x08, 0x90, 0x1F, 0xF8, 0x09, 0x10, 0x06, 0x20,    // '$'
   0x06, 0x10, 0x01, 0x28, 0x04, 0x90, 0x0A, 0x40, 0x04, 0x30,    // '%'
   0x07, 0x30, 0x08, 0xC8, 0x09, 0x30, 0x06, 0x00, 0x09, 0x00,    // '&'
   0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00,    // '''
   0x00, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x10, 0x04, 0x00, 0x00,    // '('
   0x00, 0x00, 0x00, 0x00, 0x10, 0x04, 0x0F, 0xF8, 0x00, 0x00,    // ')'
   0x01, 0x10, 0x00, 0xA0, 0x03, 0xF8, 0x00, 0xA0, 0x01, 0x10,    // '*'
   0x01, 0x00, 0x01, 0x00, 0x07, 0xC0, 0x01, 0x00, 0x01, 0x00,    // '+'
   0x00, 0x00, 0x2C, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00,    // ','
   0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00,    // '-'
   0x0C, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,    // '.'
   0x0C, 0x00, 0x03, 0x00, 0x00, 0xC0, 0x00, 0x38, 0x00, 0x00,    // '/'
   0x07, 0xF0, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x07, 0xF0,    // '0'
   0x00, 0x00, 0x00, 0x10, 0x00, 0x10, 0x0F, 0xF8, 0x00, 0x00,    // '1'
   0x0C, 0x10, 0x0A, 0x08, 0x09, 0x08, 0x08, 0x88, 0x08, 0x70,    // '2'
   0x04, 0x10, 0x08, 0x08, 0x08, 0x88, 0x08, 0x88, 0x07, 0x70,    // '3'
   0x03, 0x00, 0x02, 0xC0, 0x02, 0x30, 0x0F, 0xF8, 0x02, 0x00,    // '4'
   0x04, 0xF8, 0x08, 0x48, 0x08, 0x48, 0x08, 0x48, 0x07, 0x88,    // '5'
   0x07, 0xF0, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x10,    // '6'
   0x00, 0x08, 0x0E, 0x08, 0x01, 0x88, 0x00, 0x68, 0x00, 0x18,    // '7'
   0x07, 0x70, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x70,    // '8'
   0x04, 0x70, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0xF0,    // '9'
   0x0C, 0xC0, 0x0C, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,    // ':'
   0x00, 0x00, 0x2C, 0xC0, 0x1C, 0xC0, 0x00, 0x00, 0x00, 0x00,    // ';'
   0x01, 0x00, 0x02, 0x80, 0x04, 0x40, 0x08, 0x20, 0x00, 0x00,    // '<'
   0x02, 0x80, 0x02, 0x80, 0x02, 0x80, 0x02, 0x80, 0x02, 0x80,    // '='
   0x08, 0x20, 0x04, 0x40, 0x02, 0x80, 0x01, 0x00, 0x00, 0x00,    // '>'
   0x00, 0x10, 0x00, 0x08, 0x0B, 0x08, 0x00, 0x88, 0x00, 0x70,    // '?'
   0x01, 0xE0, 0x02, 0x10, 0x04, 0xC8, 0x05, 0x28, 0x02, 0xF0,    // '@'
   0x0F, 0x00, 0x02, 0xE0, 0x02, 0x18, 0x02, 0xE0, 0x0F, 0x00,    // 'A'
   0x0F, 0xF8, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x70,    // 'B'
   0x07, 0xF0, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x04, 0x10,    // 'C'
   0x0F, 0xF8, 0x08, 0x08, 0x08, 0x08, 0x04, 0x10, 0x03, 0xE0,    // 'D'
   0x0F, 0xF8, 0x08, 0x88, 0x08, 0x88, 0x08, 0x08, 0x00, 0x00,    // 'E'
   0x0F, 0xF8, 0x00, 0x88, 0x00, 0x88, 0x00, 0x08, 0x00, 0x00,    // 'F'
   0x07, 0xF0, 0x08, 0x08, 0x08, 0x88, 0x04, 0x88, 0x0F, 0x90,    // 'G'
   0x0F, 0xF8, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x0F, 0xF8,    // 'H'
   0x00, 0x00, 0x0F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,    // 'I'
   0x06, 0x00, 0x08, 0x00, 0x08, 0x00, 0x07, 0xF8, 0x00, 0x00,    // 'J'
   0x0F, 0xF8, 0x00, 0xC0, 0x01, 0x20, 0x02, 0x10, 0x0C, 0x08,    // 'K'
   0x0F, 0xF8, 0x08, 0x00, 0x08, 0x00, 0x08, 0x00, 0x08, 0x00,    // 'L'
   0x0F, 0xF8, 0x00, 0x70, 0x01, 0x80, 0x00, 0x70, 0x0F, 0xF8,    // 'M'
   0x0F, 0xF8, 0x00, 0x30, 0x00, 0xC0, 0x03, 0x00, 0x0F, 0xF8,    // 'N'
   0x07, 0xF0, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x07, 0xF0,    // 'O'
   0x0F, 0xF8, 0x00, 0x88, 0x00, 0x88, 0x00, 0x88, 0x00, 0x70,    // 'P'
   0x07, 0xF0, 0x08, 0x08, 0x0A, 0x08, 0x0C, 0x08, 0x17, 0xF0,    // 'Q'
   0x0F, 0xF8, 0x00, 0x88, 0x00, 0x88, 0x00, 0x88, 0x0F, 0x70,    // 'R'
   0x04, 0x70, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x10,    // 'S'
   0x00, 0x08, 0x00, 0x08, 0x0F, 0xF8, 0x00, 0x08, 0x00, 0x08,    // 'T'
   0x07, 0xF8, 0x08, 0x00, 0x08, 0x00, 0x08, 0x00, 0x07, 0xF8,    // 'U'
   0x00, 0x38, 0x03, 0xC0, 0x0C, 0x00, 0x03, 0xC0, 0x00, 0x38,    // 'V'
   0x00, 0xF8, 0x0F, 0x00, 0x00, 0xE0, 0x0F, 0x00, 0x00, 0xF8,    // 'W'
   0x0E, 0x38, 0x01, 0x40, 0x00, 0x80, 0x01, 0x40, 0x0E, 0x38,    // 'X'
   0x00, 0x38, 0x00, 0x40, 0x0F, 0x80, 0x00, 0x40, 0x00, 0x38,    // 'Y'
   0x0C, 0x08, 0x0B, 0x08, 0x08, 0x88, 0x08, 0x68, 0x08, 0x18,    // 'Z'
   0x00, 0x00, 0x1F, 0xFC, 0x10, 0x04, 0x00, 0x00, 0x00, 0x00,    // '['
   0x00, 0x00, 0x00, 0x38, 0x00, 0xC0, 0x03, 0x00, 0x0C, 0x00,    // '\'
   0x00, 0x00, 0x10, 0x04, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00,    // ']'
   0x00, 0x10, 0x00, 0x08, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10,    // '^'
   0x10, 0x00, 0x10, 0x00, 0x10, 0x00, 0x10, 0x00, 0x10, 0x00,    // '_'
   0x00, 0x08, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,    // '`'
   0x06, 0x00, 0x09, 0x40, 0x09, 0x40, 0x09, 0x40, 0x0F, 0x80,    // 'a'
   0x0F, 0xF8, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x07, 0x80,    // 'b'
   0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x04, 0x80,    // 'c'
   0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x0F, 0xF8,    // 'd'
   0x07, 0x80, 0x09, 0x40, 0x09, 0x40, 0x09, 0x40, 0x05, 0x80,    // 'e'
   0x0F, 0xF0, 0x00, 0x48, 0x00, 0x48, 0x00, 0x48, 0x00, 0x10,    // 'f'
   0x27, 0x80, 0x28, 0x40, 0x28, 0x40, 0x28, 0x40, 0x1F, 0xC0,    // 'g'
   0x0F, 0xF8, 0x00, 0x80, 0x00, 0x40, 0x00, 0x40, 0x0F, 0x80,    // 'h'
   0x00, 0x00, 0x00, 0x00, 0x0F, 0xC8, 0x00, 0x00, 0x00, 0x00,    // 'i'
   0x20, 0x00, 0x20, 0x00, 0x1F, 0xC8, 0x00, 0x00, 0x00, 0x00,    // 'j'
   0x0F, 0xF8, 0x01, 0x00, 0x02, 0x80, 0x04, 0x40, 0x08, 0x00,    // 'k'
   0x00, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x00, 0x00, 0x00, 0x00,    // 'l'
   0x0F, 0xC0, 0x00, 0x40, 0x0F, 0x80, 0x00, 0x40, 0x0F, 0x80,    // 'm'
   0x0F, 0xC0, 0x00, 0x80, 0x00, 0x40, 0x00, 0x40, 0x0F, 0x80,    // 'n'
   0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x07, 0x80,    // 'o'
   0x3F, 0xC0, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x07, 0x80,    // 'p'
   0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x3F, 0xC0,    // 'q'
   0x0F, 0xC0, 0x00, 0x80, 0x00, 0x40, 0x00, 0x40, 0x00, 0x00,    // 'r'
   0x04, 0x80, 0x09, 0x40, 0x0A, 0x40, 0x04, 0x80, 0x00, 0x00,    // 's'
   0x07, 0xF0, 0x08, 0x40, 0x08, 0x40, 0x00, 0x00, 0x00, 0x00,    // 't'
   0x07, 0xC0, 0x08, 0x00, 0x08, 0x00, 0x04, 0x00, 0x0F, 0xC0,    // 'u'
   0x00, 0xC0, 0x03, 0x00, 0x0C, 0x00, 0x03, 0x00, 0x00, 0xC0,    // 'v'
   0x01, 0xC0, 0x0E, 0x00, 0x01, 0xC0, 0x0E, 0x00, 0x01, 0xC0,    // 'w'
   0x0C, 0xC0, 0x03, 0x00, 0x03, 0x00, 0x0C, 0xC0, 0x00, 0x00,    // 'x'
   0x20, 0x00, 0x23, 0xC0, 0x1C, 0x00, 0x04, 0x00, 0x03, 0xC0,    // 'y'
   0x0C, 0x40, 0x0A, 0x40, 0x09, 0x40, 0x08, 0xC0, 0x00, 0x00,    // 'z'
   0x00, 0x00, 0x00, 0x80, 0x0F, 0x78, 0x10, 0x04, 0x00, 0x00,    // '{'
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00,    // '|'
   0x00, 0x00, 0x10, 0x04, 0x0F, 0x78, 0x00, 0x80, 0x00, 0x00,    // '}'
   0x00, 0x10, 0x00, 0x08, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10,    // '~'
   0x00, 0x38, 0x00, 0x44, 0x00, 0x44, 0x00, 0x44, 0x00, 0x38,    // 'degree'
PostPosted: Fri Dec 25, 2020 9:11 pm
If you're genuinely concerned about copyright/license issues, I'd just get a tile editor of the sort that homebrew game developers and ROM hackers use and roll one up yourself. It's really not difficult (I can do one in half an hour, and at 5x8 fixed-pitch it's not like you need to know much about typography,) and you can do it exactly to your taste, within the limits of the format.
5x8 on a 128px screen does seem like a bit of an odd choice to me. Depending on how many columns you really feel you need, 6x8 or 8x8 would probably be a little more comfortable.
PostPosted: Sat Dec 26, 2020 7:45 am
May I ask which display you're using, please? Is it one of the tiny 0.96" or 1.3" type?
Cheerful regards...
PostPosted: Sat Dec 26, 2020 2:11 pm
This is what I ended up doing with MS Paint and a Python script. Thanks for the suggestion.
Hmm, maybe 6x8 is what I mean then since the letter is five pixels wide and I'm not counting the one pixel space between letters.
Do you mean one of the little OLED displays from China? I have some of those to play with but haven't tested them out yet. For this I'm using an LCD: https://www.crystalfontz.com/product/cf ... ule-128x64
PostPosted: Sat Dec 26, 2020 2:52 pm
Looks exactly like this one I used on a Pi some time back:
https://www.youtube.com/watch?v=JBtS35qPmeo
and while I don't put up any text in that video, I do have some fonts I've used on it (and others like that in the past)
This is a nice, generic 8x8 font I have used in the past:
https://unicorn.drogon.net/font.h
This is a variable width one, condensed down to 5 high and 4 or 5 wide (ie. variable width) which I designed for the Pimoroni Scroll pHAT for the Pi:
https://unicorn.drogon.net/scrollPhatFont.h
It needs code support to check the width of each character which is stored left-shifted in a byte, 5 bytes long. so needs 5 bytes per character rather than 8. My code checks the width by scanning each of the 5 bytes for the right-most set bit - starting at bit 0 (rightmost) and working towards bit 7 (left most), so characters like double quote get worked out correctly.
Also this:
https://unicorn.drogon.net/font_acorn_8x8.h
is a font I've tweaked based on the Acorn font in the BBC Micro. It's an 8x8 font and in quite interesting as most of the vertical lines (e.g. in ! and others) are doubled. This was an intentional design by Sophie Wilson who designed it (and the Beeb, ARM, etc.) to cater for PAL video so the font was visible in an 80-column mode on a UK TV at the time. (640x256 pixel resolution). There is an article online about this somewhere which I read a while back but the link to it escapes me right now.
The biggest headache is storing the data in ROM on a 6502 - a 'basic' 64 character font in an 8x8 format needs 512 bytes of ROM space - which may or may not be an issue, but you can cut it down to just (say) uppercase only and pack to 7 bytes if you really need to save space.
Users browsing this forum: No registered users and 49 guests
