Here's one I generated years ago. It's in a bit of an odd format for historical reasons... It's intended for a 128 x 64 LCD/OLED display, which tend to use a memory map where the 128 columns go right to left and 8 rows of eight pixels go top to bottom; bit zero of the memory is the highest. On that display dimension, it gives four rows of twenty-three columns.
The font is six pixels wide by sixteen pixels high, stored as five pixels wide (there isn't a lot of point wasting space by storing the blanks) and doesn't have an characters below the space. Ten bytes per character; odd bytes along the line are the bottom half of the character and even bytes are the top half. In both cases, bit zero is at the top.
This is a larger font than the one requested by the OP but it's available for any use - including playing with it to change it.
const uint8_t fonts[960] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ' '
0x00, 0x00, 0x00, 0x00, 0x0B, 0xF8, 0x00, 0x00, 0x00, 0x00, // '!'
0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, // '"'
0x02, 0x20, 0x0F, 0xF8, 0x02, 0x20, 0x0F, 0xF8, 0x02, 0x20, // '#'
0x04, 0x60, 0x08, 0x90, 0x1F, 0xF8, 0x09, 0x10, 0x06, 0x20, // '$'
0x06, 0x10, 0x01, 0x28, 0x04, 0x90, 0x0A, 0x40, 0x04, 0x30, // '%'
0x07, 0x30, 0x08, 0xC8, 0x09, 0x30, 0x06, 0x00, 0x09, 0x00, // '&'
0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, // '''
0x00, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x10, 0x04, 0x00, 0x00, // '('
0x00, 0x00, 0x00, 0x00, 0x10, 0x04, 0x0F, 0xF8, 0x00, 0x00, // ')'
0x01, 0x10, 0x00, 0xA0, 0x03, 0xF8, 0x00, 0xA0, 0x01, 0x10, // '*'
0x01, 0x00, 0x01, 0x00, 0x07, 0xC0, 0x01, 0x00, 0x01, 0x00, // '+'
0x00, 0x00, 0x2C, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, // ','
0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, // '-'
0x0C, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // '.'
0x0C, 0x00, 0x03, 0x00, 0x00, 0xC0, 0x00, 0x38, 0x00, 0x00, // '/'
0x07, 0xF0, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x07, 0xF0, // '0'
0x00, 0x00, 0x00, 0x10, 0x00, 0x10, 0x0F, 0xF8, 0x00, 0x00, // '1'
0x0C, 0x10, 0x0A, 0x08, 0x09, 0x08, 0x08, 0x88, 0x08, 0x70, // '2'
0x04, 0x10, 0x08, 0x08, 0x08, 0x88, 0x08, 0x88, 0x07, 0x70, // '3'
0x03, 0x00, 0x02, 0xC0, 0x02, 0x30, 0x0F, 0xF8, 0x02, 0x00, // '4'
0x04, 0xF8, 0x08, 0x48, 0x08, 0x48, 0x08, 0x48, 0x07, 0x88, // '5'
0x07, 0xF0, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x10, // '6'
0x00, 0x08, 0x0E, 0x08, 0x01, 0x88, 0x00, 0x68, 0x00, 0x18, // '7'
0x07, 0x70, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x70, // '8'
0x04, 0x70, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0xF0, // '9'
0x0C, 0xC0, 0x0C, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ':'
0x00, 0x00, 0x2C, 0xC0, 0x1C, 0xC0, 0x00, 0x00, 0x00, 0x00, // ';'
0x01, 0x00, 0x02, 0x80, 0x04, 0x40, 0x08, 0x20, 0x00, 0x00, // '<'
0x02, 0x80, 0x02, 0x80, 0x02, 0x80, 0x02, 0x80, 0x02, 0x80, // '='
0x08, 0x20, 0x04, 0x40, 0x02, 0x80, 0x01, 0x00, 0x00, 0x00, // '>'
0x00, 0x10, 0x00, 0x08, 0x0B, 0x08, 0x00, 0x88, 0x00, 0x70, // '?'
0x01, 0xE0, 0x02, 0x10, 0x04, 0xC8, 0x05, 0x28, 0x02, 0xF0, // '@'
0x0F, 0x00, 0x02, 0xE0, 0x02, 0x18, 0x02, 0xE0, 0x0F, 0x00, // 'A'
0x0F, 0xF8, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x70, // 'B'
0x07, 0xF0, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x04, 0x10, // 'C'
0x0F, 0xF8, 0x08, 0x08, 0x08, 0x08, 0x04, 0x10, 0x03, 0xE0, // 'D'
0x0F, 0xF8, 0x08, 0x88, 0x08, 0x88, 0x08, 0x08, 0x00, 0x00, // 'E'
0x0F, 0xF8, 0x00, 0x88, 0x00, 0x88, 0x00, 0x08, 0x00, 0x00, // 'F'
0x07, 0xF0, 0x08, 0x08, 0x08, 0x88, 0x04, 0x88, 0x0F, 0x90, // 'G'
0x0F, 0xF8, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x0F, 0xF8, // 'H'
0x00, 0x00, 0x0F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // 'I'
0x06, 0x00, 0x08, 0x00, 0x08, 0x00, 0x07, 0xF8, 0x00, 0x00, // 'J'
0x0F, 0xF8, 0x00, 0xC0, 0x01, 0x20, 0x02, 0x10, 0x0C, 0x08, // 'K'
0x0F, 0xF8, 0x08, 0x00, 0x08, 0x00, 0x08, 0x00, 0x08, 0x00, // 'L'
0x0F, 0xF8, 0x00, 0x70, 0x01, 0x80, 0x00, 0x70, 0x0F, 0xF8, // 'M'
0x0F, 0xF8, 0x00, 0x30, 0x00, 0xC0, 0x03, 0x00, 0x0F, 0xF8, // 'N'
0x07, 0xF0, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x07, 0xF0, // 'O'
0x0F, 0xF8, 0x00, 0x88, 0x00, 0x88, 0x00, 0x88, 0x00, 0x70, // 'P'
0x07, 0xF0, 0x08, 0x08, 0x0A, 0x08, 0x0C, 0x08, 0x17, 0xF0, // 'Q'
0x0F, 0xF8, 0x00, 0x88, 0x00, 0x88, 0x00, 0x88, 0x0F, 0x70, // 'R'
0x04, 0x70, 0x08, 0x88, 0x08, 0x88, 0x08, 0x88, 0x07, 0x10, // 'S'
0x00, 0x08, 0x00, 0x08, 0x0F, 0xF8, 0x00, 0x08, 0x00, 0x08, // 'T'
0x07, 0xF8, 0x08, 0x00, 0x08, 0x00, 0x08, 0x00, 0x07, 0xF8, // 'U'
0x00, 0x38, 0x03, 0xC0, 0x0C, 0x00, 0x03, 0xC0, 0x00, 0x38, // 'V'
0x00, 0xF8, 0x0F, 0x00, 0x00, 0xE0, 0x0F, 0x00, 0x00, 0xF8, // 'W'
0x0E, 0x38, 0x01, 0x40, 0x00, 0x80, 0x01, 0x40, 0x0E, 0x38, // 'X'
0x00, 0x38, 0x00, 0x40, 0x0F, 0x80, 0x00, 0x40, 0x00, 0x38, // 'Y'
0x0C, 0x08, 0x0B, 0x08, 0x08, 0x88, 0x08, 0x68, 0x08, 0x18, // 'Z'
0x00, 0x00, 0x1F, 0xFC, 0x10, 0x04, 0x00, 0x00, 0x00, 0x00, // '['
0x00, 0x00, 0x00, 0x38, 0x00, 0xC0, 0x03, 0x00, 0x0C, 0x00, // '\'
0x00, 0x00, 0x10, 0x04, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00, // ']'
0x00, 0x10, 0x00, 0x08, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, // '^'
0x10, 0x00, 0x10, 0x00, 0x10, 0x00, 0x10, 0x00, 0x10, 0x00, // '_'
0x00, 0x08, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // '`'
0x06, 0x00, 0x09, 0x40, 0x09, 0x40, 0x09, 0x40, 0x0F, 0x80, // 'a'
0x0F, 0xF8, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x07, 0x80, // 'b'
0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x04, 0x80, // 'c'
0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x0F, 0xF8, // 'd'
0x07, 0x80, 0x09, 0x40, 0x09, 0x40, 0x09, 0x40, 0x05, 0x80, // 'e'
0x0F, 0xF0, 0x00, 0x48, 0x00, 0x48, 0x00, 0x48, 0x00, 0x10, // 'f'
0x27, 0x80, 0x28, 0x40, 0x28, 0x40, 0x28, 0x40, 0x1F, 0xC0, // 'g'
0x0F, 0xF8, 0x00, 0x80, 0x00, 0x40, 0x00, 0x40, 0x0F, 0x80, // 'h'
0x00, 0x00, 0x00, 0x00, 0x0F, 0xC8, 0x00, 0x00, 0x00, 0x00, // 'i'
0x20, 0x00, 0x20, 0x00, 0x1F, 0xC8, 0x00, 0x00, 0x00, 0x00, // 'j'
0x0F, 0xF8, 0x01, 0x00, 0x02, 0x80, 0x04, 0x40, 0x08, 0x00, // 'k'
0x00, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x00, 0x00, 0x00, 0x00, // 'l'
0x0F, 0xC0, 0x00, 0x40, 0x0F, 0x80, 0x00, 0x40, 0x0F, 0x80, // 'm'
0x0F, 0xC0, 0x00, 0x80, 0x00, 0x40, 0x00, 0x40, 0x0F, 0x80, // 'n'
0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x07, 0x80, // 'o'
0x3F, 0xC0, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x07, 0x80, // 'p'
0x07, 0x80, 0x08, 0x40, 0x08, 0x40, 0x08, 0x40, 0x3F, 0xC0, // 'q'
0x0F, 0xC0, 0x00, 0x80, 0x00, 0x40, 0x00, 0x40, 0x00, 0x00, // 'r'
0x04, 0x80, 0x09, 0x40, 0x0A, 0x40, 0x04, 0x80, 0x00, 0x00, // 's'
0x07, 0xF0, 0x08, 0x40, 0x08, 0x40, 0x00, 0x00, 0x00, 0x00, // 't'
0x07, 0xC0, 0x08, 0x00, 0x08, 0x00, 0x04, 0x00, 0x0F, 0xC0, // 'u'
0x00, 0xC0, 0x03, 0x00, 0x0C, 0x00, 0x03, 0x00, 0x00, 0xC0, // 'v'
0x01, 0xC0, 0x0E, 0x00, 0x01, 0xC0, 0x0E, 0x00, 0x01, 0xC0, // 'w'
0x0C, 0xC0, 0x03, 0x00, 0x03, 0x00, 0x0C, 0xC0, 0x00, 0x00, // 'x'
0x20, 0x00, 0x23, 0xC0, 0x1C, 0x00, 0x04, 0x00, 0x03, 0xC0, // 'y'
0x0C, 0x40, 0x0A, 0x40, 0x09, 0x40, 0x08, 0xC0, 0x00, 0x00, // 'z'
0x00, 0x00, 0x00, 0x80, 0x0F, 0x78, 0x10, 0x04, 0x00, 0x00, // '{'
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00, // '|'
0x00, 0x00, 0x10, 0x04, 0x0F, 0x78, 0x00, 0x80, 0x00, 0x00, // '}'
0x00, 0x10, 0x00, 0x08, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, // '~'
0x00, 0x38, 0x00, 0x44, 0x00, 0x44, 0x00, 0x44, 0x00, 0x38, // 'degree'
