Compiling TaliForth2 on Windows
Re: Compiling TaliForth2 on Windows
scotws wrote:
If you are all-out for the smallest code possible, and you are going to be writing different games, which means you're going to keep running into the size problem, you might want to consider creating a Token Thread Code (TTC) Forth instead of using Tali. See http://www.bradrodriguez.com/papers/moving1.htm for the AFAIK best introduction to the differences. It will be slower - possibly a lot slower - but you could strip the Forth down to the bare essentials and use single-byte tokens for fantastic size games.
I'd quite like to understand what's going on with this game which makes it so large: it is certain that the game can't be more compact? (Having said which, how much memory are we talking about?)
If I was writing a graphics intensive Forth application, I'd try a really lean Indirect Thread Code (ITC) Forth ( or maybe even a Token Thread Code Forth if memory was really tight ) and write the graphics routines as code words.
Just from a quick look at the examples presented, it looks like this Forth code might be a direct translation of C into Forth. That is something Jeff Fox advised against.
Druzyek wrote:
It depends on what you mean by "direct." Most of the highest level words like ColorTile have the same purpose as the corresponding C functions, but the subwords and internal functionality are implemented from scratch. I knew the purpose of the functions, so there was no need to translate the C to Forth line by line.
dup c@ \ get first byte of length,color pair
swap 1+ swap \ increment tile pointer
count \ get first byte of length,color pair
\ and increment tile pointer
: TileHW ( addr -- addr+2 w h)
dup c@ swap 1+ \ Get width
dup c@ swap 1+ \ Get height
-rot ; \ Arrange the results.
count \ Get width
swap count \ Get height
rot swap ; \ Arrange the results.
SamCoVT wrote:
Druzyek wrote:
The next request would be a way to recognize errors immediately. As it is now, all the text gets pasted in instantly from a text file and any errors scroll immediately off the screen. Would it be possible to implement a separate output for error messages like stdout and stderr in C? It seems like modifying or replacing ABORT might do it. Another way might be to add a flag in zero page that causes an error message to go into an infinite loop when on but that can be switched off later after the file has been pasted in so the prompt still works interactively even when you cause errors. What do you think?
ABORT (which you will find really just falls into QUIT) might be one place to make changes. It is called (jumped to, really, as it resets the stack anyway) after the error message has been printed. If you want the location where the error message is actually printed, you will need to look at "error:" in taliforth.asm. I believe this routine is used for all of the errors that would end up calling ABORT. You'll also want to look in "xt_number:" (just before the "_all_converted:" label) in native_words.asm if you want the name of an unknown word.
If Forth can't find a word, it tries to turn it into a number, so the spot where it realizes that the text at the input is not a number (and therefore an unknown word) is actually in the NUMBER routine.
You have the luxury of writing your own emulator, so you could make a "stderr" that goes somewhere else without actually needing to add hardware. You could just make an extra address that you write to for output, and then write some forth words to use it.
Keep us posted on whatever you end up with for a solution.
dwight wrote:
Symetric math is often better for polar math. Floored math is better for single lines or XY rectangular vectors. Symetric math makes zero an unique point. Floored math makes zero an offset. This can be vary important when doing multiple precision math on things like XY tables. Using math that rounds towards zero can really mess things up because it makes zero a unique point. You can't smoothly cross zero. As soon as you try to include offsets, thing go bad quickly.
It is easier to understand which is which by doing /mod instead of just mod. Both still need to follow the rule Dividend=Divisor*Quotient+Remainder. I've learned that I prefer floored math for most calculations but most processors round toward zero.
As an example. If one makes a table of sine and cosine with symetric math and incrementally calculates the next point around a circle, it won't close. If you use floored math, the circle will be a little off center but will close. This happens even for floating point but most don't notice the tiny error until many revolutions have been completed.
Dwight
Dwight
<some heading value> 360 MOD HEADING !
Druzyek wrote:
Creating a headerless version is going to be more work than I thought, so I won't be going down the rabbit hole after all. Instead, I should be able to fit the remaining code into additional banks by copying the entire 12k Tali Forth 2 installation into each of those banks.
It looks like you might be thinking in 'C' or at least not as much in Forth. For example, this piece of code from the word ColorTile:
What about a version of TaliForth2 with separated headers? The headers could reside in a separate set of banks. Each header would need an additional field to point to the word's executable code. The header banks could be switched in just long enough for the interpreter/compiler to get the address of the word to interpret or compile.
- GARTHWILSON
- Forum Moderator
JimBoyd wrote:
It seems ABORT is doing what it's supposed to do. TaliForth2 stops doing whatever it was doing, reports the error and goes into the QUIT loop to wait for user input.
I think you're thinking of ABORT" (pronounced "abort-quote"). ABORT" examines a flag on the stack, and if it's true, ABORT" will give the error message and abort. ABORT by itself (without the " at the end) does not report errors, and is not conditional.
With the source pasted in, it's like there is a mad typist at the keyboard ignoring all errors and continuing to type.
xt_count:
jsr underflow_1
lda (0,x) ; Get number of characters (255 max)
tay
; move start address up by one
inc 0,x ; LSB
bne +
inc 1,x ; MSB
; save number of characters to stack
* tya
dex
dex
sta 0,x ; LSB
stz 1,x ; MSB, always zero
z_count: rts
No. I mean using the word COUNT already supplied by TaliForth2.
Really? It seemed like a logical use. Another use is in a high level definition of TYPE
: TYPE ( ADR CNT -- ) \ TYPE takes an address of a string
\ and how many characters to display.
0 ?DO
COUNT EMIT
LOOP
DROP ;
I had some trouble with 2R> since I assumed it would be R> R> but it actually reverses the order.
No, it doesn't. 2R> and 2>R move a pair of cells while retaining the byte order and therefore the cell order.
Although 2R> is semantically equivalent to R> R> SWAP , that is because moving a pair of cells one at a time with the sequence R> R> or the sequence >R >R reverses the order.
Given the numbers 137 and 42 already on the return stack, the sequence R> R> moves the data like this:
137
return data
R>
137 42
return data
R>
137
42
return data
The word 2R> moves the data like this:
137
return data
2R>
42
137
return data
2R>
“two-r-from”
CORE EXT
Interpretation: Interpretation semantics for this word are undefined.
Execution: ( – – x1 x2 ) ( R: x1 x2 – – )
Transfer cell pair x1 x2 from the return stack. Semantically equivalent to R> R> SWAP.
See: 3.2.3.3 Return stack, 6.1.0580 >R 6.1.2060 R> 6.1.2070 R@ 6.2.0340 2>R, 6.2.0415
2R@, A.6.2.0410 2R>.
2R>
“two-r-from”
CORE EXT
