Druzyek wrote:
The next request would be a way to recognize errors immediately. As it is now, all the text gets pasted in instantly from a text file and any errors scroll immediately off the screen. Would it be possible to implement a separate output for error messages like stdout and stderr in C? It seems like modifying or replacing ABORT might do it. Another way might be to add a flag in zero page that causes an error message to go into an infinite loop when on but that can be switched off later after the file has been pasted in so the prompt still works interactively even when you cause errors. What do you think?
The great part about Forth is that you can actually go in and change the things that you think should work differently. I'll be interested to see what you come up with for a solution to this problem, as I also end up pasting very large inputs at times, and it would be nice to have it stop at the first error instead of having to scroll back and find it. I often want to throw away all the rest of the input, as a word that didn't compile will mess up most of the code that follows, and I would need to modify ACCEPT to do that. A flag in zero page, like you suggested might work well for my situation, and I could look for a control code (perhaps CTRL-Q) to allow regular input again. You will find (although I commented it out) where CTRL-P and CTRL-N were handled in ACCEPT for the input history. Do be careful as some CTRL combinations are handled by the terminal and not passed to the application (at least on Linux, anyway), such as CTRL-L (clears the screen).
ABORT (which you will find really just falls into QUIT) might be one place to make changes. It is called (jumped to, really, as it resets the stack anyway) after the error message has been printed. If you want the location where the error message is actually printed, you will need to look at "error:" in taliforth.asm. I believe this routine is used for all of the errors that would end up calling ABORT. You'll also want to look in "xt_number:" (just before the "_all_converted:" label) in native_words.asm if you want the name of an unknown word.
If Forth can't find a word, it tries to turn it into a number, so the spot where it realizes that the text at the input is not a number (and therefore an unknown word) is actually in the NUMBER routine.
You have the luxury of writing your own emulator, so you could make a "stderr" that goes somewhere else without actually needing to add hardware. You could just make an extra address that you write to for output, and then write some forth words to use it.
Keep us posted on whatever you end up with for a solution.
It seems ABORT is doing what it's supposed to do. TaliForth2 stops doing whatever it was doing, reports the error and goes into the QUIT loop to wait for user input. Since the 'user input' is actually text that is pasted into the emulator, it responds as though the error is ignored by the user who just keeps typing. Is it possible for the 65C02 system emulator to emulate mass storage for TaliForth2 ? Maybe a specific directory could be used as the mass storage the emulator could read. If the file were INCLUDEed instead of pasted into TaliForth2 , interpretation/compilation should stop at the first error.
