I've working on an adapter for my C02 Pocket SBC which has a 16-bit IDE port and a DS1511Y RTC. I'm using an ATF16V8BQL CPLD to manage all of the I/O decode and drive the high-byte read and write latches for the 16-bit data port as well. I seem to have a working CPLD at this point, but I'm looking for a sanity check. The datasheet shows different modes for the ATF16V8, which aren't 100% clear (to me at least).
In any case, I'm using a single I/O select which is 32-bytes wide which drives an input on the CPLD along with 5 address lines (A0-A4), a phase 2 clock aligned Read and Write signals. I'm grounding the OC line and have a Clock attached to the CLK input, but I don't think I actually need it. I'm using addresses $00 - $13 for the RTC, locations above $13 are not used. Locations $14-$15 are for the high-byte read/write latches. Locations $16-$17 are for CS1 on the IDE drive and locations $18-$1F are for CS0 on the IDE drive.
I've burned a CPLD and have it on a breadboard with pull-up resistors and switches to set the address and R/W lines, plus LEDs and resistors on the output to show the status of the lines. It seems to be working... the Simulator also follows what should be. However, I was hoping to use the OC line with the I/O select, as it "should" enable or disable all of the outputs , or so I thought. I could never get that to work regardless, so I just grounded and used another input for the select line. I'm hoping some with more knowledge and experience on this can give me some feedback/guidance on what I' m doing (right or wrong). I'm still thinking I don't need a clock signal on pin 1... but I'm not certain.
Here's the code for WinCUPL:
Name IDE-RTC ;
PartNo 01 ;
Date 1/04/2020 ;
Revision 01 ;
Designer KM ;
Company Analogue Technologies ;
Assembly SBC2 ;
Location ;
Device G16V8MS ;
PIN 1 = CLK ; /* */
PIN 2 = A0 ; /* */
PIN 3 = A1 ; /* */
PIN 4 = A2 ; /* */
PIN 5 = A3 ; /* */
PIN 6 = A4 ; /* */
PIN 7 = !MRD ; /* */
PIN 8 = !MWR ; /* */
PIN 9 = !SEL ; /* */
PIN 11 = !OC ; /* */
PIN 18 = !UBWE ; /* */
PIN 16 = !UBRE ; /* */
PIN 19 = UBWL ; /* */
PIN 17 = UBRL ; /* */
PIN 12 = !CS0 ; /* */
PIN 13 = !CS1 ; /* */
PIN 15 = !RTC ; /* */
PIN 14 = !HBT ; /* */
/** Declarations and Intermediate Variables Definitions **/
FIELD ADDRESS = [A4..0];
RTC = SEL & ADDRESS:['h'00..13];
HBT = SEL & ADDRESS:['h'14..15];
CS1 = SEL & ADDRESS:['h'16..17];
CS0 = SEL & ADDRESS:['h'18..1F];
/** Logic Equations **/
UBWE = MWR & SEL & ADDRESS:['h'18..18];
UBRE = MRD & SEL & ADDRESS:['h'14..14];
UBWL = MWR & SEL & ADDRESS:['h'15..15];
UBRL = MRD & SEL & ADDRESS:['h'18..18];
If anyone has some suggestions on a better way to do this, I'm open to them. I'm currently modifying the adapter board and replacing the 44-pin IDE connector with a Compact Flash socket, so I'm just using the same basic layout and the same CPLD setup. Thanks.
