40 years ago I dreamed about building my own computer. But then buying them was so much easier. Then I saw Ben Eaters video and got really hooked. My first attempt derived from Ben's SAP1 was a success (or as my father put it "a lot of effort to calculate 1+1"). But I had to realize that expanding that system beyond the stage of "demonstration level speeds" would not really work, so I'm going for a 6502 based design as Mark2.
After about a month of research I had to realize that the biggest obstacle would be video. For modern monitors it has to be at least VGA, and I have not found any simple video chip that could be used. I don't want to use microcontrollers or FPGA. That left a solution like
https://tldr.fi/2014/09/27/zc160-vga-adapter1/
https://www.bigmessowires.com/2008/07/2 ... em-design/
or
viewtopic.php?f=4&t=3329
I especially liked the Vulcan design, although IMHO from those projects listed it's the one least documented. Unfortunately it seems to be dead in the water
Design goals:
VGA Video 640x480 or 800x600
no FPGA or micro crontroller
I like the Vulcan copy machine
16k part of the video buffer should be mapped to the CPU 64kb memory space
some extra memory for data (64kb is not much for data)
I also want to add a AMD coprocessor ... just for the kicks.
64 colors (2 bit per color)
I came up with this layout: The CPU controls a number of 574 chips. I will need a number of GALs to create the selection logic. The whole address space looks like
0000-00FF Page Zero
0100-01FF Stack
0200-03FF I/O space
0400-7FFF memory
8000-BFFF 16kb window
C000-FFFF 16kb ROM The extra 574 register to the top right helps to map the extra memory (16kb at a time).
The Video memory is double buffered. One buffer is used by the sync counters to generate the VGA signal. The second buffer is written to in parallel either from CPU or the copy machine. That means I have a number of possible datapaths between the components, and I plan to use (a lot) 245 chips to separate each of them. Another issue is the bus width of 9 and 10 bits - that adds the need of some extra 245 chips. The sync signal is generated by 2 counters and a 512kb memory chip. I will need to set up correct information in the memory during initialization of the computer. The 8bits will also reset the 2 sync counters at the right time. There is a copy machine. The source counter is made up of 193 chips and can be switched between 2 separate 12bit counters and a full 24bit counter. I figure a simple transistor between counter four and five should do the job, pulling the ripple input low if I need 2 separate counters. The destination counter is made up by counter-comparator-register trios forming 2 10/9 bit counters to address the buffer ram. This little trick should enable me to access a 64x64 (7bit by 7bit) Window of the Video memory. Adding 3x bits and 2y bits to the IPC of the 6502 should allow me to directly draw into the video buffer So please tell me what you think and help me straighten up the design
thanks
Michael
