So Ive been able to test the 652X chips as following:
All out, i get 5.04V on the IRQ of the 6502
First one in (6520) i get the low 0.12V
I take it out again, put the second one in (6520) after which i get 5.12 V on IRQ of 6502
I put the third one in (6522) and i get the 5.12V again on IRQ of 6502
I also now get a single character on screen again! yey!
since i assume that both 6520 chips are identical, could i swap them to see if the error occurs again, is there a chance that i could break the working one?
In particular, I would monitor /RESET on the suspect chip during power-up. There should be an observable delay between +5V and /RESET going high. Make sure Phi2 is toggling at the suspect chip's input, too, using the AC voltage setting.
There is a noticeable difference between 5V and RESET. About a solid second on reset while it almost instant on 5V when i turn the machine on. I dont know if ive done the checking Phi2 right, but setting my multimeter to what i think is AC and a range of 200, it reads 4.2V and is constant.
Emmanuel
