Hi everyone, I'm bulding a simple computer with a Rockwell 6502P, but I'm having problems with the writing process.
I connected the 6502 to an arduino and to a w27c512 EPROM to test it. I loaded the code for load the accumulator with memory and then push it into the stack.
When it's time to write the memory, the R/W pin goes LOW, the EPROM is set in high impedence state (because of the A15 pin goes LOW), but the data bus of the 6502 seems to remain in high impedence state or reading state.
In fact, the arduino reads in the data bus the same byte of the previous instruction, and if I put a 10Kohm resistor as pull-up on each line of the bus, the byte read is FF.
The pin that I connected to the Vcc are: IRQ, NMI, VCC, RES, SO, BE.
PHI2 frequency is 10Hz.
RDY is connected to Vcc with a 1Kohm resistor.
What can I do? Could be the chip bad?
Thanks.
Error in data bus while writing
Re: Error in data bus while writing
Welcome!
If you really do mean 10Hz, that's too slow for an old non-CMOS 6502. It will lose track of what it is doing.
Instead, clock at 1MHz and use some form of single-stepping circuit (search this forum for suggestions)
Every cycle has two halves... the first half when Phi2 is low, and the 2nd half when it's high.
During the first half, the conditions you describe are NORMAL for a write cycle. The CPU remains high-impedance until Phi2 goes high. THEN is when you need to take your sample (if you're not doing it that way already).
If you continue to have difficulty please post a photo and a schematic. This will help us to advise you.
Cheers, and welcome!
ps- on this forum you may attach images to your post
So you don't reset your CPU? It may or may not work then. How about RDY line?
Thank you all.
Good result!
It could be that your CPU is actually a CMOS chip in disguise. Try loading this little routine into it to find out for sure.
