qwertykeyboard wrote:
It seems that TI is one of the few manufacturers that still make logic chips. Browsing Digi-Key seems to reveal that, in most cases, with the exception of Toshiba, all other major IC manufacturers have stopped making 74 series chips in DIP.
Once TI stops making these chips we're in real trouble
![Shocked :shock:](./images/smilies/icon_eek.gif)
There are others. Try searching Allied and Mouser, as well as Digi-Key. No one vendor has everything.
As I earlier said, PDIP is slowly but surely on its way out. Hardly any commercial products use them anymore, mostly because SMT parts are more economical in terms of materials and labor, especially labor. As the demand for PDIP diminishes manufacturers will discontinue them and it will be all SMT.
Anyone with reasonably good close-up eyesight and a reasonably steady hand can solder SMT devices. My POC units have some SOIC and SOJ parts, all of which were manually soldered. Here's a close-up of a MAX238 in a SOIC24 package on my POC V1.2 unit. SOIC is 50 mil pitch and as can be seen, is easily soldered.
File comment: MAX238 SOIC24 Manually Soldered
SOJ packages are similar. Here's a close-up of the SRAM on my POC V1.2 unit. It's in an SOJ32 package, which is also 50 mil pitch.
File comment: SRAM SOJ32 Manually Soldered
The really fine pitch stuff, such as TSOP, is more challenging, but hobbyists have manually soldered them.
This video explains the techniques for manually soldering SMT parts. Nothing unusual in the way of tools and supplies is used.
