Good 74HC parts to have
- BigDumbDinosaur
Re: Good 74HC parts to have
qwertykeyboard wrote:
What frequency would you recommend for the can oscillator that will reliably work on a breadboard? (I'm using a rockwell R65C02 btw)
- GARTHWILSON
- Forum Moderator
Rockwell's R65C02 could be stopped, but only with phase 2 high, not low. The maximum phase-2-low time that's guaranteed to work is 5µs. What surprises me now is that this is the first time I've noticed that Synertek's data book says there's no maximum phase-2-low time for their SY65C02. I thought only WDC could stop the clock with phase 2 low.
- BigDumbDinosaur
qwertykeyboard
If I wanted to use another 74AC74 to divide the clock further after the output of the first 74AC74, would there be any kind of problems with this? Also I'm wondering as to why to use a 74AC74 instead of a 74HC74?
- GARTHWILSON
- Forum Moderator
No. Do as many cascades stages as you want. (There are two available in a single '74 IC though).
According to the data sheet, WDC's W65C02 wants a faster rise and fall time than the 74HC might produce.
qwertykeyboard
- BigDumbDinosaur
Does that mean I'd need to use a 74ac14 instead of a 74hc14 for the single cycle circuit (the one that keeps PHI0 high unless the button is pushed) listed on your clock generation primer?
qwertykeyboard
The good thing is that discrete logic in PDIP packages is still plentiful and relatively inexpensive. However, it isn't going to stay that way, so a little bit of hoarding now may prove to be a wise thing to do.
I especially like this ^^^^ paragraph. You may find a price break at qty 10. Get plenty of DIP sockets too.
Once TI stops making these chips we're in real trouble
- BigDumbDinosaur
It seems that TI is one of the few manufacturers that still make logic chips. Browsing Digi-Key seems to reveal that, in most cases, with the exception of Toshiba, all other major IC manufacturers have stopped making 74 series chips in DIP.
As I earlier said, PDIP is slowly but surely on its way out. Hardly any commercial products use them anymore, mostly because SMT parts are more economical in terms of materials and labor, especially labor. As the demand for PDIP diminishes manufacturers will discontinue them and it will be all SMT.
Anyone with reasonably good close-up eyesight and a reasonably steady hand can solder SMT devices. My POC units have some SOIC and SOJ parts, all of which were manually soldered. Here's a close-up of a MAX238 in a SOIC24 package on my POC V1.2 unit. SOIC is 50 mil pitch and as can be seen, is easily soldered.
SOJ packages are similar. Here's a close-up of the SRAM on my POC V1.2 unit. It's in an SOJ32 package, which is also 50 mil pitch.
The really fine pitch stuff, such as TSOP, is more challenging, but hobbyists have manually soldered them.
This video explains the techniques for manually soldering SMT parts. Nothing unusual in the way of tools and supplies is used.
- GARTHWILSON
- Forum Moderator
LOL, I violate most of the rules he gives in that video!
- BigDumbDinosaur
qwertykeyboard
- BigDumbDinosaur
Only thing is that SMD parts aren't as flexible when it comes to prototyping and just whipping something together.
You can probably do this with other counters, too. I also think that there may be some subtleties about this that I'm unable to think of at the moment, but I'm sure someone else will step in and explain any issues I'm missing with this technique.
qwertykeyboard
I don't own an oscilloscope, so would it be useful to buy a cheap little logic analyzer like this: https://www.ebay.ca/itm/USB-Logic-Analy ... SwLSBc-btw
to do debugging and that type of stuff.
