It is currently Fri Nov 22, 2024 6:58 am
PostPosted: Sat Apr 25, 2020 1:13 pm
Shawn Odekirk wrote:
Is there anything special about pin 13 on the ATF22V10C that could cause my address decoding to not work as I expect?
Shouldn't be. Whilst some PAL/GAL chips have a dedicated OE input the ATF22V10C isn't one of them. As far as I can tell from the datasheet pin 13 is just a regular input. The Lattice GAL22V10 certainly does it that way.
I'd point out that another thread here is discussing similar issues with the ATF22V10C/TL866II+ combo.
If you have access to another GAL programmer I'd be interested in the results.
PostPosted: Sat Apr 25, 2020 7:03 pm
Could it be that some of the 1's or some of the 0's you're seeing on the output pins are actually a high-impedance state? If you haven't already, maybe you should try the test again but with pullup resistors attached. Then with pulldown resistors.
Pull-up and pull-down resistors don't seem to have an effect.
Martin A wrote:
Does changing the device name from g22v10 (GAL mode) to p22v10 (PAL mode) make any difference ?
Changing the device name to p22v10 doesn't seem to have an effect.
I tried using GALasm instead of WinCupl, and that didn't seem to have an effect either.
Thanks for the link. I skimmed that thread before I began having my problem. I need to go back and read it again more carefully. Just glancing at it now, it looks like he may be having the exact same problem I am. His BOOTUP_OE signal is assigned to pin 13.
Unfortunately I only have the one programmer and Atmel chips. I have one Lattice PALCE22V10Q, which is not on the TL866II+ supported devices list, and all of my attempts to program it so far have failed.
PostPosted: Sun Apr 26, 2020 10:28 am
I've access to the VP-290 programmer, and I've built a quick and dirty test board to check the output file from WinCUPL.
It appears to work as expected using a stock ATF22V10C-15.
The 2 Blue LEDs are connected to the A and B inputs on pins 13 and 14. The green ones to the regular outputs, and the red ones to the inverse, fed from pins 20 to 23.
The CPU board is a Grant Searle 7 chip 6502 design with an extra chip select decodes so that I can POKE 32768,x to set the LEDs. The LED's are configured to sink current so they're on when the output is low .
File comment: POKE 32768,3
File comment: POKE 32768,2
File comment: POKE 32768,1
File comment: POKE 32768,0
PostPosted: Sun Apr 26, 2020 3:37 pm
Martin,
Thank you for taking the time to test this. It looks like the VP-290 correctly programs the ATF22V10C.
FYI, this thread got off-topic from the original post. I think this thread seems better suited to continuing the discussion of problems programming the ATF22V10C using the TL866II+ programmer.
