Could it be that some of the 1's or some of the 0's you're seeing on the output pins are actually a high-impedance state? If you haven't already, maybe you should try the test again but with pullup resistors attached. Then with pulldown resistors.
Pull-up and pull-down resistors don't seem to have an effect.
Does changing the device name from g22v10 (GAL mode) to p22v10 (PAL mode) make any difference ?
Changing the device name to p22v10 doesn't seem to have an effect.
I tried using GALasm instead of WinCupl, and that didn't seem to have an effect either.
I'd point out that another thread
here is discussing similar issues with the ATF22V10C/TL866II+ combo.
If you have access to another GAL programmer I'd be interested in the results.
Thanks for the link. I skimmed that thread before I began having my problem. I need to go back and read it again more carefully. Just glancing at it now, it looks like he may be having the exact same problem I am. His BOOTUP_OE signal is assigned to pin 13.
Unfortunately I only have the one programmer and Atmel chips. I have one Lattice PALCE22V10Q, which is not on the TL866II+ supported devices list, and all of my attempts to program it so far have failed.
