the pinout is not the problem, i already have the symbol (as it can seen on the picture), just not the footprint for the PCB.
Oh, I was talking about footprint: pinouts are footprint, not schematic symbol, to my mind.
I thought about mentioning that the physical dimenions are also standardized by JEDEC, but got lazy and didn't because I figured "DIP is DIP: just copy any existing DIP footprint with the right number of pins and tweak the pinout."
But yes, JEDEC has a specific standard for the physical footprints, as well. A
dual-in-line package (DIP) is "A device package configuration that has two parallel rows of pins that are spaced nominally 0.3 inch, 0.4 inch, or 0.6 inch apart with the pins on 0.1-inch centers." The truly gory details of the 0.6 inch devices can be found in
MO-015. (That's free to download, but registration with their website is required.) But the one sentence above pretty well sums it up.
And, in case you want them, the specs for byte-wide EPROM pinout standards can be found in
EPROM3.4.1.
