for a project of mine I was looking arount the interwebz in search of an assembler IDE (think Eclipse or Visual Studio) for 650x processors. Since nothing I found matched my criteria I'm here to pay someone to do it for me, as the two programming langues I'm good at (Java and Cobol) aren't exactly suited for this kind of work.
The IDE should have the following features:
- Macros
- Memory Map with named/preallocated memory locations
- Named Variables
- The obvious syntax highlighting and error finding...
Compilation should be handled by some (preferably open source) third party compiler. No need to do something that already readily exists.
If you're reasonably certain you could stitch something like this together send me a pm.
Greetings,
-Giebels2609
P.S. At the end of it (if someone makes it for me) the whole thing will be published under the GPL.
P.P.S Happy Christmas and a merry new Year!
If it is missing features that you require, the source code is available so it may be possible to add features to it rather than start from scratch.
