Some interesting MOS/CSG chip layout comparisons
fhw72
Post by fhw72 »
Some days ago I created an overlay of my (admittedly bad quality) die shot of the
8500R4 (aka 6510) and 8501R4.
I'm quite sure that the 6510 was developed BEFORE the 8501... but
the layout of the later 8500R4 seems to be derived from the 8501R4
or maybe they created them with having the variants already in their minds?!
But better see yourself (please be patient while it loads):
https://is.gd/rgcifA
Please note the metal lines at the right part of the chip:
Doesn't really make sense for the 8500... that's why I think the 8501 came first!
Does someone have shots of the MOS8502? I'd bet it's the same except the I/O port section.
fhw72
Re: Some interesting MOS/CSG chip layout comparisons
Post by fhw72 »
No real layout comparison... but maybe someone wants to take a look at the
Metal and Poly layer of the MOS8360R2 aka "TED"
from the Commodore C16/plus4 line of computers: https://is.gd/ZC6VrT
Or the 6509R7 CPU: https://is.gd/spxeF5
Enjoy the slide.... :D
Interesting finding and an interesting tool for comparisons...
I wonder when CSG got computer aided design? It's possible to copy and paste once your layout is vectors in a computer - but the original 6502 was a ruby-lith layout done with sharp knives. So, at some point, I'd suppose, MOS/CSG would have digitised that layout and started on a journey of making derived designs.
Is it possible that the 6510 was its own thing at the time but the 8500 was a later recreation? It's surprising (to me) that the 8500 has 8 bits of I/O port logic, with 8 pads, but only 6 pads bonded. Was there a chip which used all 8 bits of the port? Or a plan for such a chip?
fhw72
Post by fhw72 »
The 8502 used more bits of the port (7 bits)!
fhw72
Post by fhw72 »
Here's a comparison of the 6510 and 8500:
https://is.gd/ad5OyB
Please note that the main core in the middle is the same size (proportionally) but the outer
perimeter (i.e. drivers, ports etc.) are stretched vertically - a little bit.
PLA/Decode rom is also perfectly aligned!
fhw72
Post by fhw72 »
Did you ever want to skin the CIA? :D
https://is.gd/Qsy6lh
Nice! Are there any bugs or idiosyncrasies in the 6526 which might inspire a look at the transistor netlist?
fhw72
Post by fhw72 »
Yes... I want to check the *EXACT* differences between the 6526R4 and the successor 8521R1 (which was labeled 6526 as it's identical
in fucntionality but has some differences in the interrupt control).
fhw72
Post by fhw72 »
I redid the 8500R4 vs. 8501R4 comparison:
Vertical slider: https://is.gd/8ECZRp
Horizontal slider: https://is.gd/ZWHAMC
Enjoy!
daniMolina
Post by daniMolina »
Beautiful!
fhw72
Post by fhw72 »
daniMolina wrote:
Beautiful!
Then you might like this one too:
https://is.gd/ivRQTB
It's the overlay of metal and poly layer.
fhw72
Post by fhw72 »
Someone wanted to know the differences between
MOS8501R1 <-> MOS8501R4
Here we go:
https://is.gd/6fcY1U
GATEIN Logic seems untouched. What I can see so far:
MOS8501R1 still has the (unused!) SYNC pin logic (moved between pads for NMI# and IRQ#).
This logic was replaced with a back bias generator.
fhw72
Post by fhw72 »
Yet another one just finished:
MOS8726R1
https://is.gd/fk6HzZ
fhw72
Post by fhw72 »
In order to dig a little deeper in the 6522R0 I restitched the publicly available pictures
of the 6522R0 and realigned metal and poly layer:
https://is.gd/WM2hJr
fhw72
Post by fhw72 »
And here another one:
https://is.gd/lZ4IZn
