; Bit Counting
; This file contains various 6502 coded algorithms that
; count the number of one bits in a byte value.
; The different CPU performance and memory usage
; characteristics have been calculated for each method
; to show how speed and space trade offs.
; These examples have been developed for use with
; Michal Kowalski's 6502 emulator.
; If you can think of any other ways of calculating
; this or speeding up these routines please let me
; know.
; Andrew Jacobs
; Revision History:
; 2007-08-28 AJ First release.
.ORG $00
SCRATCH .DS 2 ; Some scratch memory
.ORG $8000
.START $8000
; Bit Counting Via a Lookup Table
; The fastest way of figuring out how many bits are set
; in a byte is to use a precalculated table and index
; into it using either X or Y.
; This method is so simple that you don't need to put
; the code in a subroutine for reuse.
; The only downside to this is that it needs a whole
; 256 byte page to hold the lookup table.
; Time: 6 cycles (+1 if data table crosses page)
; Size: 256 bytes (for data)
ByteAtATime:
LDX #54 ; Load value to lookup
LDA ByteBitCounts,X ; and get its bit count
NOP ; A contains bit count
; We can add together the bit counts of several bytes
; to compute the total number of bits in larger values.
LDA #$12 ; Set up an example
STA SCRATCH+0 ; 16-bit value
LDA #$34
STA SCRATCH+1
CLC ; Clear carry
LDX SCRATCH+0 ; Fetch first data byte
LDA ByteBitCounts,X ; bit count
LDX SCRATCH+1 ; And add in the next
ADC ByteBitCounts,X
NOP ; A has bit total count
JMP HalfTheDataTable ; Jump to next method
; Look up table of bit counts in the values $00-$FF
ByteBitCounts:
.BYTE 0,1,1,2,1,2,2,3,1,2,2,3,2,3,3,4
.BYTE 1,2,2,3,2,3,3,4,2,3,3,4,3,4,4,5
.BYTE 2,3,3,4,3,4,4,5,3,4,4,5,4,5,5,6
.BYTE 3,4,4,5,4,5,5,6,4,5,5,6,5,6,6,7
.BYTE 4,5,5,6,5,6,6,7,5,6,6,7,6,7,7,8
; Bit Counting With A Smaller Lookup Table
; We can half the size of the look up table by using
; the fact that the bit count for a value V in the
; range $80-$FF will be one more than that for V & $7F.
; So if we move bit 7 into the carry then look up the
; bit count for bits 6 downto 0 and add the carry back
; we get the right result.
; Time: 20 cycles (+1 if data table crosses page)
; Size: 142 bytes (13 for code, 128 for data)
HalfTheDataTable:
LDA #$54 ; Load a test value
JSR BitCountSeven ; Calculate the count
NOP ; Result is in A
JMP NybbleAtATime ; Jump to next method
BitCountSeven:
CLC ; Ensure bit 0 is safe
ADC #$80 ; Put bit 7 into carry
AND #$7F ; Strip out bits 6-0
TAX
LDA SevenBitCounts,X ; Fetch the bit count
ADC #0 ; Add in bit 7
RTS
; Look up table of bit counts in the values $00-$7F
SevenBitCounts:
; Bit Counting With An Even Smaller Lookup Table
; If we are prepared to do a small amount of shifting
; then we can reduce the data table to just 16 bytes.
; This alogrithm breaks the value into two $0-$F nybble
; values and adds the bit counts for these together.
; Time: 39 cycles (+2 if data table crosses page)
; Size: 36 bytes (20 for code, 16 for data)
NybbleAtATime:
JSR BitCountNybble ; Calculate the count
JMP BitAtATime ; Jump to next method
BitCountNybble:
PHA ; Save a copy of value
LSR ; Shift down hi nybble
LSR
LSR
LSR
AND #$0F
TAY ; And save in Y
PLA ; Recover value
AND #$0F ; Strip out lo nybble
TAX ; And save in X
CLC
LDA NybbleBitCounts,X ; Then add counts for
ADC NybbleBitCounts,Y ; each nybble
RTS
; Look up table of bit counts in the values $00-$0F
NybbleBitCounts:
; Bit Counting Using Shifts
; The smallest method for count bits shifts the value
; left one bit at a time and counts each one bit that
; is shifted out.
; If we use ASL to perform the shift then the value
; will become zero after at most eight iterations. By
; looking for see when the value has reached zero we
; can stop iterating as soon as there are no bits left
; to shift out.
; Time: 17 to 91 cycles (depending on the value)
; Size: 12 bytes
BitAtATime:
JSR BitCountIterative ; Calculate the count
JMP DivideAndConquer ; Jump to next method
BitCountIterative:
LDX #0 ; Clear bit count
BitShiftLoop:
ASL ; Shift a bit
BCC BitCountSkip ; Did a one shift out?
INX ; Add one to count
ORA #0 ; Retest for zero
BitCountSkip:
BNE BitShiftLoop ; Repeat till zero
TXA ; Move count to A
RTS
; Divide and Conquer
; This alogrithm works by aligning and adding parts of
; the value until finally a bit count is produced.
; | 0 + 1 | 1 + 0 | 0 + 1 | 1 + 1 |
; +---v-------v-------v-------v----
; | 0 1 + 0 1 | 0 1 + 1 0 |
; +-------v---------------v--------
; | 0 0 1 0 + 0 0 1 1 |
; +---------------v----------------
; | 0 0 0 0 0 1 0 1 |
; This method always takes the same amount of time
; regardless of the value
; Time: 66 cycles
; Size: 37 bytes
DivideAndConquer:
JSR BitCountParallel ; Calculate the count
BRK ; All done
BitCountParallel:
PHA
AND #$55 ; Strip out odd bits
STA SCRATCH
PLA
LSR ; Strip out even bits
AND #$55
CLC ; And add together
ADC SCRATCH
PHA
AND #$33 ; Strip out odd pairs
STA SCRATCH
PLA
LSR
LSR
AND #$33 ; Strip out even pairs
CLC
ADC SCRATCH ; And add together
STA SCRATCH
LSR
LSR
LSR
CLC
ADC SCRATCH ; Add to lo nybble
AND #$0F ; And prune to result
RTS
.END
