Heres the revised code.
; Bit Counting
; This file contains various 6502 coded algorithms that
; count the number of one bits in a byte value.
; The different CPU performance and memory usage
; characteristics have been calculated for each method
; to show the speed and space trade offs.
; If you have the space to spare than the 256 byte
; lookup table is the fastest otherwise the in place
; shift/add method is a good allrounder.
; These examples have been developed for use with
; Michal Kowalski's 6502 emulator.
; If you can think of any other ways of calculating
; this or speeding up these routines please let me
; know.
; Compiled by Andrew Jacobs (BitWise) with additions
; from members of the 6502.org forum.
; Thanks to Thowllly & dclxvi for code speed ups and
; dclxvi for the in place shift/add method.
; Revision History:
; 2007-08-28 AJ First release.
; 2007-08-30 AJ Included forum suggestions.
.ORG $00
SCRATCH .DS 2 ; Some scratch memory
.ORG $8000
.START $8000
JMP ByteAtATime ; Jump to first example
; Bit Counting Via a Lookup Table
; The fastest way of figuring out how many bits are set
; in a byte is to use a precalculated table and index
; into it using either X or Y.
; This method is so simple that you don't need to put
; the code in a subroutine for reuse.
; The only downside to this is that it needs a whole
; 256 byte page to hold the lookup table.
; Time: 6 cycles (+1 if data table crosses page)
; Size: 256 bytes (for data)
; Look up table of bit counts in the values $00-$FF
ByteBitCounts:
.BYTE 0,1,1,2,1,2,2,3,1,2,2,3,2,3,3,4
.BYTE 1,2,2,3,2,3,3,4,2,3,3,4,3,4,4,5
.BYTE 2,3,3,4,3,4,4,5,3,4,4,5,4,5,5,6
.BYTE 3,4,4,5,4,5,5,6,4,5,5,6,5,6,6,7
.BYTE 4,5,5,6,5,6,6,7,5,6,6,7,6,7,7,8
ByteAtATime:
LDX #$54 ; Load value to lookup
LDA ByteBitCounts,X ; and get its bit count
NOP ; A contains bit count
; We can add together the bit counts of several bytes
; to compute the total number of bits in larger values.
LDA #$12 ; Set up an example
STA SCRATCH+0 ; 16-bit value
LDA #$34
STA SCRATCH+1
CLC ; Clear carry
LDX SCRATCH+0 ; Fetch first data byte
LDA ByteBitCounts,X ; bit count
LDX SCRATCH+1 ; And add in the next
ADC ByteBitCounts,X
NOP ; A has bit total count
JMP HalfTheDataTable ; Jump to next method
; Bit Counting With A Smaller Lookup Table
; We can half the size of the look up table by using
; the fact that the bit count for a value V in the
; range $80-$FF will be one more than that for V & $7F.
; Infact it doesn't matter which bit we use providing
; we are left with an easy to access 7 bits afterwards.
; So if we move bit 0 into the carry using LSR and then
; look up the bit count for bits 6 downto 0 and add the
; carry back we get the right result.
; Time: 16 cycles (+1 if data table crosses page)
; Size: 136 bytes (8 for code, 128 for data)
BitCountSeven:
LSR ; Put bit 0 into carry
TAX
LDA SevenBitCounts,X ; Fetch the bit count
ADC #0 ; Add in bit 7
RTS
; Look up table of bit counts in the values $00-$7F
SevenBitCounts:
HalfTheDataTable:
LDA #$54 ; Load a test value
JSR BitCountSeven ; Calculate the count
NOP ; Result is in A
JMP NybbleAtATime ; Jump to next method
; Bit Counting With An Even Smaller Lookup Table
; If we are prepared to do a small amount of shifting
; then we can reduce the data table to 16 bytes.
; This algorithm breaks the value into three parts. The
; hi nybble is shifted down and placed in Y. The shifts
; leave bit 3 of the value in the carry so only bits
; 2 to 0 need to be extracted into X. The bit counts
; for the X & Y values are looked up and added which
; combines them with the bit in C.
; Time: 31 cycles (+2 if data table crosses page)
; Size: 33 bytes (17 for code, 16 for data)
BitCountNybble:
TAX ; Save a copy of value
LSR ; Shift down hi nybble
LSR
LSR
LSR ; Leave <3> in C
TAY ; And save <7:4> in Y
TXA ; Recover value
AND #$07 ; Put out <2:0> in X
TAX ; And save in X
LDA NybbleBitCounts,Y ; Fetch count for Y
ADC NybbleBitCounts,X ; Add count for X & C
RTS
; Look up table of bit counts in the values $00-$0F
NybbleBitCounts:
NybbleAtATime:
JSR BitCountNybble ; Calculate the count
JMP BitAtATime ; Jump to next method
; Bit Counting Using Shifts
; The smallest method for count bits shifts the value
; left one bit at a time and counts each one bit that
; is shifted out.
; If we use ASL to perform the shift then the value
; will become zero after at most eight iterations. By
; looking for see when the value has reached zero we
; can stop iterating as soon as there are no bits left
; to shift out.
; Time: 18 to 76 cycles (depending on the value)
; Size: 10 bytes
BitCountIterative:
LDX #$FF ; Set count to -1
.Incr: INX ; Add one to count
.Loop: ASL ; Shift by one bit
BCS .Incr ; Count one bits
BNE .Loop ; Repeat till zero
TXA ; Move count to A
RTS
BitAtATime:
JSR BitCountIterative ; Calculate the count
JMP ShiftAndAdd ; Jump to next method
; Shift and Add
; This method uses the most significant bits of the
; accumulator to keep track of the bit count as the
; remaining data value bits are shifted out of least
; significant position.
; The follow illustrates the intermediate states of the
; calculation for the sample $54 value. The : shows the
; division between the running count and the remaining
; uncounted bits.
; | 0 | 1 | 0 | 1 | 0 | 1 | 0 | 0 | Initial value
; | 0 | 0 : 1 | 0 | 1 | 0 | 1 | 0 | C = 0 skip add
; | 0 | 0 | 0 : 1 | 0 | 1 | 0 | 1 | C = 0 skip add
; | 0 | 0 | 0 | 0 : 1 | 0 | 1 | 0 | C = 1
; | 0 | 0 | 0 | 1 : 1 | 0 | 1 | 0 | Add $0F+C ($10)
; | 0 | 0 | 0 | 0 | 1 : 1 | 0 | 1 | C = 0 skip add
; | 0 | 0 | 0 | 0 | 0 | 1 : 1 | 0 | C = 1
; | 0 | 0 | 0 | 0 | 1 | 0 : 1 | 0 | Add $03+1 ($04)
; | 0 | 0 | 0 | 0 | 0 | 1 | 0 : 1 | C = 0 skip add
; | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 0 : C = 1
; | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 1 | Add $00+C ($01)
; Time: 40 to 46 cycles (depending on the value)
; Size: 34 bytes
BitCountShiftAdd:
LSR ; Is bit 0 set?
BCC .Skip0
ADC #$3F ; Yes, add $40
.Skip0 LSR ; Is bit 1 set?
BCC .Skip1
ADC #$1F ; Yes, add $20
.Skip1 LSR ; Is bit 2 set?
BCC .Skip2
ADC #$0F ; Yes, add $10
.Skip2 LSR ; Is bit 3 set?
BCC .Skip3
ADC #$07 ; Yes, add $08
.Skip3 LSR ; Is bit 4 set?
BCC .Skip4
ADC #$03 ; Yes, add $04
.Skip4 LSR ; Is bit 5 set?
BCC .Skip5
ADC #$01 ; Yes, add $02
.Skip5 LSR
ADC #$00 ; Add bit 6 to count
RTS
ShiftAndAdd:
JSR BitCountShiftAdd ; Calculate the count
JMP DivideAndConquer ; Jump to next method
; Divide and Conquer
; This algorithm works by aligning and adding parts of
; the value until finally the bit count is produced.
; | 0 + 1 | 1 + 0 | 0 + 1 | 1 + 1 |
; +---v-------v-------v-------v----
; | 0 1 + 0 1 | 0 1 + 1 0 |
; +-------v---------------v--------
; | 0 0 1 0 + 0 0 1 1 |
; +---------------v----------------
; | 0 0 0 0 0 1 0 1 |
; This method always takes the same amount of time
; regardless of the value
; Time: 50 cycles
; Size: 34 bytes
BitCountParallel:
TAX
AND #$55 ; Strip out odd bits
STA SCRATCH
TXA
AND #$AA ; Strip out even bits
LSR
ADC SCRATCH ; And add together
TAX
AND #$33 ; Strip out odd pairs
STA SCRATCH
TXA
AND #$CC ; Strip out even pairs
LSR
LSR
STA SCRATCH
LSR
LSR
LSR
ADC SCRATCH ; Add to lo nybble
AND #$0F ; And prune to result
RTS
DivideAndConquer:
JSR BitCountParallel ; Calculate the count
BRK ; All done
.END
I think that includes all the comments. Cycle counts where done by hand so might be a bit out.
Edit: Fixed typos.
