I've recently returned to my 65C02 cross emulator (6502CA) which I've been writing for what feels like forever
Much of it is done functionality wise, but with a few exceptions. Once of which is the implementation of a basic memory map facility usable by the Simulator part of the project.
The basic RAM/ROM side of things will be easy to implement, but I was wondering about basic VIA/ACIA implemetation and whether it's worth adding this in or just have a generic "I/O" classification.
If do try going beyond simple "I/O" then should I just have registers - at which ppint might as well be RAM - or should I try adding in (for the VIA) timers and maybe basic IRQ vector calling and have the port A and B have a window which you can toggle the lines on? Is it worth the effort?
Timers might be not worth it as the Simulator is not an Emulator and so, although it keeps track fo cycles, does not adhere to any time specifications and takes as long as it takes to execute a given instruction.
