It is currently Sat Sep 28, 2024 10:57 pm
PostPosted: Mon Jul 16, 2018 11:06 am
At memory location $FBDD in the Monitor (Apple II/e), resides a subroutine that beeps the speaker.
If we try to call that subroutine from Integer BASIC, we have to use CALL 768 (where 768 is in decimal form and it's equivalent in hexadecimal is $300)
Normally the correct one shouldn't be CALL 64477? (which is the decimal equivalent of $FBDD)
It should but according to Apple II reference manual, locations above 32767 are specified using negative numbers.
Okay but that doesn't mean that CALL 768 is still wrong?
Nevertheless, it's NOT wrong, it's correct, since the speaker beeps!
Why? :?
PostPosted: Mon Jul 16, 2018 12:39 pm
It looks to me like $300 is a common place to put user code - have you already done some POKE or code-loading action which set up a routine at $300?
CALL -1059
might be the right invocation in Basic to JSR to $FBDD
PostPosted: Mon Jul 16, 2018 12:51 pm
Correct!
Thank you! :)
PostPosted: Mon Jul 16, 2018 3:18 pm
Nicely done, Ed! I imagine that Integer BASIC Apple ][s are about as common as hen's teeth on your side of the pond, but you nailed the response.
PostPosted: Mon Jul 16, 2018 3:45 pm
Cheers Mike, indeed, pretty rare but not never seen. In fact I think there were one or two at the recent ABUG meetup. But as it happens I just did a bit of web searching - if I'd been really diligent, or if I'd thought of it, I might have fired up an emulator...
