Raymond,
I can't recall the speed rating of the '802 I tested in my ][+ over 25 years ago (-4 maybe?), but I don't remember encountering any difficulties (other than lack of monitor support for the native mode, obviously). I wasn't using any peripherals with interrupts, or any DOS other than 3.3.
Mike B.
65802 anyone?
Re: 65802 anyone?
Welcome Raymond!
It sounds like the CMOS CPU is likely to run well in an Apple II (I confess I don't have a good grasp of the various models or revisions of that machine.)
Some of you here might be interested to know that it's not so straightforward in Acorn's BBC Micro - there's a thread with experiments here where it's found that slugging the CPU clock with a capacitor, to skew it by 10-20ns, can rescue the situation. What's extremely unexpected is the failure mode: sometimes bad N or C flags from an SBC immediate, and no other addressing mode or instruction. The result is OK, but the flag not.
Re: 65802 anyone?
Welcome to the forum, Raymond.
DRAM timing, 65C02 too fast, tinkering with delaying the PHI0 clock input of the CPU to compensate for this...
Sounds familiar, somehow.
Re: 65802 anyone?
Plamen now sells a plug-compatible 65816 for 6502 computers: http://www.a2heaven.com/webshop/index.p ... uct_id=151
His stock depletes often so if interested visit occasionally. As of now there are 3 available...
Andy
Andy
Re: 65802 anyone?
Even before the IIgs folks were replacing their 65c02s with 65816s in the Apple IIe and IIc simply gain access to 16-bit wide registers. There were a couple of spreadsheets that could take advantage of the 65816 and the speed advantage was massive, even at 1mhz, just because it was so much easier to deal with 16-bit values when number crunching.
- GARTHWILSON
- Forum Moderator
Re: 65802 anyone?
LeoN wrote:
http://www.pro-electr.net/search?q=w65c802
It might be worth buying two or three, testing them, and if they prove to be legitimate 65802's buy more, and if it still looks good, buy a load of them to keep for people here and other 6502 forums.
Re: 65802 anyone?
On the photo, the marking of chips is the same with that. And the production date stamp is the same. Probably non-faked chips.
- BigDumbDinosaur
Re: 65802 anyone?
- BitWise
- In Memoriam
Re: 65802 anyone?
I might be tempted to get some more
Andrew Jacobs
eightbitdoh
Re: 65802 anyone?
Hi, Just an update years after the topic. While I never sourced an '802, I did replace my 6502 with WDC W65c02s in the A][ motherboard using the steps listed on the WDC site (jumper lead and pin left out of socket).
Back to topic I guess 65c802s were actually available last year - I'm getting errors on pro-electr.net site.
I have use of an expansion card with an '816 in it, so didn't pursue.
Raymond.
Raymond.
