Wikipedia about the C128 in C64 mode:
"Some of the few C64 programs that fail on a C128 will run correctly when the CAPS LOCK key is pressed down
(or the ASCII/National key on international C128 models).
This has to do with the larger built-in I/O port of the C128's CPU.
Whereas the SHIFT LOCK key found on both C64 and C128 is simply a mechanical latch for the left SHIFT key,
the CAPS LOCK key on the C128 can be read via the 8502's built-in I/O port.
A few C64 programs are confused by this extra I/O bit;
keeping the CAPS LOCK key in the down position will force the I/O line low,
matching the C64's configuration and resolving the issue."
Edit:
After checking on a real C64 how P7,P6 work, it appears that my memory was wrong there: It's been a few years.
$0000 is the direction register, a Bit set to '1' means output.
$0001 is the data register.
When P7\P7 are configurated as output, if the P6\P7 Bit set to 1 in the data register it reads back as '1'.
But when P6\P7 was configurated as output and the P6\P7 data Bit was set to 1,
and then changing the direction of that P6\P7 port Bit to "input",
after 0.2s .. 0.25s the P6\P7 data Bit reads back as '0'.
(0.25s with a cold 6510, 0.2s after one hour of system uptime.)
So that could be done just with tinkering with the values of the P7,P6 pulldown resistors R102, R101
on the 'Card A_Registers' PCB.
Being able to plug OurCPU into a C128 isn't one of the project's goals, it just would be "the icing on the cake".
IMHO it could be done when making a special 40 pin adaptor PCB for plugging into the 8502 socket of the C128
to compensate for the different pinout of the 8502, and to use one of the GND wires in one of the flat cable
between OurCPU and C128 as I\O port signal P6.
But this solution would be a kludge, of course.
![Smile :)](./images/smilies/icon_smile.gif)
Don't know, if we have enough free space on the 'Card A Registers' PCB to make P6 a true I\O pin,
maybe it would do if P6 is an input only.
And we probably would have to add another resistor plus a solder jumper to OurCPU.
