FAL6567 back-burner project
Re: FAL6567 back-burner project
I got slightly further with the project, but I don't have a C64 to test with. The last thing I did was create a board layout for something compatible with a VIC-II socket. I'm not sure how the board would fit. It may require adjusting the surrounding tin shielding.
This project was really for a chip equivalent to the 6567 for existing systems. It's possible these days to fit an entire C64 compatible into an FPGA. One of the generic existing FPGA boards could be used for that purpose. I've built several SoC's which are more high-powered than the C64 for the Nexys4ddr board for instance.
Looks like a fine replacement board! I have a C64 somewhere in my basement, I can check the dimensions tonight if you want me to.
My original idea was actually to use a CPLD for interfacing a 65C02 to a Vic-20 (based on a previous project which did so using discrete logic). At first I didn't think of making a C64 expansion for it, it was more of having a 40-col VGA output (for terminal), but with your nice 6567-core it might actually be worth a try to get C64-compatible graphics (I have no need for sound at the moment). I also want to allow for DIP 6502 (externally) to keep unintentional opcode compatibility as an option. For now I am only running Arlets original 6502 + RAM internally in the CPLD (I will add external DRAM later).
Oh, and I am using Lattice CPLD (code is usually 95%+ similar though).
Which Lattice part are you using kakemoms, and how much on-chip RAM does it offer?
The metal box seems to be around 70x80mm, but if you look at pictures on the net, the VIC-II chip seems to be placed at different positions depending on the version of the board. So you may want to buy one before you decide on a layout.
I use a MachXO3 CPLD. There isn't much RAM in it, so a more permanent solution will be to add SRAM (but things take time). I think you can get them with up to around 64KB memory, depending on what you put inside.
To follow up; The MachXO3 was not up to the task of running this core, so I ended up making my own implementation (of a 6560) for VGA. My core doesn't have sprites so its much simpler.
Just a question: Do you have to run this core at 1200MHz? It seems excessive. Some documentation would also be helpful.
I've modified the board to latch some output bits in order to increase the number of bits available for color. But I've may not have posted this change yet.
Still on the back burner.
FYI, I have several different C64's. I would be happy to offer any kind of help. I have an older "breadbin" C64 (NTSC), a C64C (much newer) and even a PAL C64.
Also, I have several C128's and a C128-D that also used the VIC-II.
What is the current status of 6567 core? How it's currently compatible with real 6567? I'm thinking to use this core in FPGA64 project which has so-so quality of VIC-II model.
Still needs some serious testing. It hasn't been run in anything except the simulator. There's bound to be bugs yet. The core has a mode that allows it to support more sprites (in theory) in a real C64. So the timing may be off as a result. The core is made around the idea of interfacing to a real C64, so it has bus output that should be compatible. But if you are making the core for an FPGA board this kind of bus interface might not be the best.
I have been thinking a little bit about this. Have you thought about generating the clock on-chip, and only use the external clock as a sync for external DRAM/6510 access (via FIFO)?
There are some extra logic resources available in the FPGA beyond what's required to implement a VIC-II compatible core. So I'm wondering what the extra logic resources could be used for ? One possibility I've thought of is more timer's / event generators. Or maybe floating point ?
After scouting out some C64's to test with, I got to wondering if I could build a 6567 VIC-II test computer myself. It might be lower cost than a working vintage C64. And it would have almost all new parts. I've come up with a couple of circuits but they use a lot of IC's and I'm looking for something simple. I'm wondering if it could be interfaced to a micro-controller of some kind. Looking for suggestions here.
Are you aware of Grant Searle's minimal designs?
http://searle.hostei.com/grant/
There are of course others.
A C64-like computer was designed for a test rig. The system will be composed of a least two circuit boards. The free cad toolset is limited to boards that are 3” x 4” and everything won’t fit on one board. The boards will be connected with a 50-pin connector.
A 14.318MHz oscillator is used for the color clock. A 32.768MHz oscillator is divided by four to generate an 8.192 MHz dot clock signal. This signal is slightly off the required 8.182 MHz signal, but color output isn’t being used so this is probably okay. Otherwise it would be a pita to generate the 8.18MHz clock. The VIC-II chip generates the PHI02 clock for the system.
The board only uses the sync and luminance outputs of the VIC-II chip since a VGA replacement will be used. Composite video out is only needed to verify the circuit works with a 6567.
A 65C22 is used to supply the high order address lines for when the VIC-II has control of the bus.
Three transparent latches are used to latch the row and column address from the VIC-II to generate an address for the static RAM (on the cpu board).
All the parts are low power CMOS except for the 6567.
