I ordered some: "5pcs" of R65C02P4. Here is what I got (they shipped very fast):
As you can see, every package is slightly different. Some have those two shallow holes near the ends, some do not. I tested them. Three chips appear to draw less power than other two (those act just like my old MOS6502AD). I tested them for BRA instruction: NMOS 6502 treats it as NOP with operand. Two chips appear to be real 65C02, three are 6502. One of them is "low power" though, drawing same amount as 65C02s do.
This one was also able to run at 6.667MHz, all the others (including my trusty MOS6502AD) were able to reach 5.333MHz. Tried searching for "CMOS 6502 without BRA", but you can imagine what are the results
Let's take a closer look at the chips now:
Bottoms are scratched, notches at the edge all look different, there are signs of sanding on tops, some corners are rounded too. Leads are shiny, not mat, as it is the case of new WDC parts. Also: MEXICO on top, KOREA / PHILIPPINES on the bottom. Right. Are those real chips? Yes. But not new, and labels on top are bogus.
https://www.youtube.com/watch?v=j9nasajve1o
