Dual port ram
- BigDumbDinosaur
Re: Dual port ram
KhanTyranitar wrote:
Ok, so PH0 is only for timing the CPU. My CPU (65816) does not have a PH1 or PH2 output which means I must generate those signals externally. What is the cleanest way to generate those signals? Flip-flop?
Re: Dual port ram
?? Surely in the case of an '816 system, one must use the CPU's input clock as the (only) timing reference. There's no need for any other clock.
- BigDumbDinosaur
Re: Dual port ram
KhanTyranitar
Re: Dual port ram
Ok, is that CLK in PH0 at double the frequency of your outputs?
I am working on building a 65816 based computer (for personal use)
Eventual goals include:
65816 CPU up to 14-16 MHz (In Turbo Mode)
up to 16MB RAM (512K on the main board)
Dual YM3438 audio
IEC serial device support
Dual YM3438 audio
Re: Dual port ram
[edited: typo correction]
KhanTyranitar
Re: Dual port ram
Ok, that's good to know. So a related question my VIC-II chip outputs 1 MHz but I need to generate a PH1 and PH2 off that for timing the slow side of the RAM and for other 1 MHz devices. How do I do that?
Dual YM3438 audio
Dual YM3438 audio
- BigDumbDinosaur
Re: Dual port ram
- BigDumbDinosaur
Re: Dual port ram
KhanTyranitar
Re: Dual port ram
On the 1 MHz bus I have to use the VIC-II clock as the source because it is the bus master. The VIC-II uses its own clock to time its memory access. The 20 MHz bus however has no such limitation as it does not have to be in sync with the 1 MHz bus.
Dual YM3438 audio
Dual YM3438 audio
- BigDumbDinosaur
Re: Dual port ram
Incidentally, CSG indirectly solved this problem with the 8563/8568 video display controllers (VDC) of the C-128 and C-128D by giving the VDC its own RAM, thus making accessing the video RAM an asynchronous process.
Last edited by BigDumbDinosaur on Mon Jan 16, 2017 3:58 pm, edited 1 time in total.
Re: Dual port ram
If we're still talking about using dual port RAM to serve a slow side and a fast side, that doesn't sound intractable to me. The two clock regimes are independent.
- BigDumbDinosaur
Re: Dual port ram
Interesting aside: the reason the VIC's registers can be read and written when the 8502 is running at 2 MHz is because all I/O device accesses in the C-128 occur at 1 MHz due to clock stretching. If that weren't the case, once switched to 2 MHz mode, it would not be possible to return the machine to 1 MHz, since the VIC would be incommunicado.
Re: Dual port ram
On a more basic level, the VIC has internal registers -- just like a 6522, for example -- which need to be readable and writable by the CPU. 65xx peripherals don't have Output Enable or Write Enable inputs because the Ø2 input (combined with the R/W input) fulfills that function.
As for Phase-Locked Loops, this technology is wonderfully accessible now. I'm sure one can find a one-chip solution that will take the existing 1 MHz clock and generate a synchronized clock running at 14 MHz (or almost any other integer multiple you care to choose).
There are so many products available it's actually hard to choose. On the down side, many of them are offered only in surface-mount packages with rather fine lead pitches. You'd either need to do a PCB or buy a little breakout adapter PCB.
KhanTyranitar
Re: Dual port ram
Except that since I'm using dual port RAM, the VIC-II almost never needs to steal CPU cycle in order to gain access to the RAM, since in my setup, the VIC-II has its own dedicated RAM port.
This will be a separate thread, but for now here is the summary.
At startup, the system does in fact run at 1MHz with the VIC-II generating the CLK for everything. A logic circuit latches the clock signal and routes the data where it needs to go. There is a transceiver that connects the CPU with the ROMs, the VIC-II, the SID(s), and the CIAs. When the VIC-II needs to read the RAM, because it has its own dedicated ports, it does not need to steal CPU cycles. The exception is that if the CPU is attempting to read or write to a ROM, or any of the IO chips at the same time as the VIC-II is reading, in which case the CPU is halted until the process is completed. Again this halting will only occur if those two things are happening at the same time. Otherwise, since the CPU has its own RAM port it can do its own thing.
Now as you recall, the 6510 has some IO pins (P0-5) that enable ROM banking and cassette port communication. I have a circuit that mimics that feature, only mine adds two more pins (P6&7). One of these when switched high will enable turbo mode, which basically tells a logic circuit to decouple the CPU (and everything on the fast side) from the 1 MHz clock and instead couple to the 20MHz clock. The VIC remains master of the slow bus. At this point however, if the CPU attempts to access a ROM, SID, CIA, or VIC-II register, the CPU is halted, then re-coupled to the 1MHz clock again. The CPU completes its access, then it is decoupled and switched back to the 20MHz clock.
I am still working on this latching system and the logic that will control it. That will be its own thread. I know it's complicated, but it should still function. I may loose a cycle here and there during the switches depending on how synchronized things happen to be, but those missed cycles should not be a major issue so long as things are timed so that data isn't lost.
As far as I can tell from going through this process, the two busses can be though of as operating separately with a common RAM access and a form of forced synchronization when needed. And to minimize slowdowns, some things can be done. For example, if I read the ROMs and copy them to RAM, I can then bank the ROMs out. Then when those routines are accessed, they can execute from RAMat full speed. Then the CPU only has to slow down for IO access.
The approach I'm taking will be mostly transparent to the software. If I try to write a VIC-II register for example, as soon as the CPU outputs it's address lines, and a positive address match occurs, then the CPU is halted using the RDY pin. Then the 20MHz clock is decoupled and the 1MHz clock is swapped in. When the clock is in the right phase, the RDY signal is released and the CPU will complete its operation. Once the cycle is complete, the RDY pin is held again, the 1MHz is swapped out with the 20MHz clock, and when the clock is in the right phase, the RDY pin is released.
I am not opposed to some type of phase locked loops, or having one chip handle all the logic functions. And generating all the signals from the VIC-IIs clock output. Alternately I can also do it from the VIC-IIs 8MHz input.
Dual YM3438 audio
Dual YM3438 audio
KhanTyranitar
Re: Dual port ram
Dual YM3438 audio
Dual YM3438 audio
