A while back I had asked about some GAL suggestions (viewtopic.php?f=10&t=4176&p=46283&hilit=ATF750#p46283).
I had thought the ATF750C-10PU would be a good idea because the specs sounded like what I needed.
I had made a purchase the other day on Mouser and I thought I would get one.
I *COMPLETELY* forgot that CPLD wasn't recommended because it used a proprietary programming algorithm.
So anyway, I now own one. :-/
I have one of those universal Chinese chip programmers so I might try that.
So, have I completely wasted my money or is there a somewhat cheap way to program these? I love that they are in DIP packages. Which is why I kept going back to them.
Fortunately, I only bought one.
I messed up...bought a ATF750C-10PU
- BigDumbDinosaur
Re: I messed up...bought a ATF750C-10PU
Also, don't forget my offer if you decide to go with an Atmel CPLD instead. You even replied to it.
The symbol Fcc is a fused source of 5 volts DC.
Or, you can readily implement a standard JTAG port on your unit. All it takes is a 10 pin header and a small bussed resistor network (or four discrete resistors).
I don't think that CPLD works with JTAG header/protocol does it?
- BigDumbDinosaur
Wait...do you mean implementing a JTAG port on my design using a SMD CPLD or implementing a JTAG to try and program the ATF750C?
cbmeeks - did you ever find a way to program your ATF750? Those things look so neat and I almost bought a bunch naively expecting TL866-II & minipro to be able to program them, but alas they can't. They are probably the last frontier of DIP PLDs, the other one being GAL22V10, which really lacks registers to do anything useful when put on an 8-bit bus with only 2 registers remaining. ATF750 would be much more interesting.
/Andrew
No, I gave up on them and went with ATF1508/etc.
Well, I don't have a ATF750, but one of my programmers says it can program ATV750 which seems to be quite similar (according to datasheets). The programmer is a BP soft CP-1128.
Anyone knows if the ATV750 is compatible with the ATF750? If anyone has a ATF750 to spare I can test it.
