It is currently Sat Nov 23, 2024 7:57 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat May 21, 2016 3:20 am
I've had the idea for a side project for quite some time. It's nothing new but I've wanted to prototype 65c02 computers as easily as the Arduino folks do with their shields.
My idea was to build modules (or "bricks") that would have common lines in the same place for each brick.
For example, the address bus, data bus, etc. would be in the same spot. Other bricks that use those buses would have the same headers in the same spot. So a 65c22, for example, would have the 8 data pins in the same spot. Four address pins (A0:A3) in the same spot, etc.
Now certain pins that are specific to the 65C02 and not useful for other bricks would be in their own section. Not connected to anything but a header for experiments. Of course, a custom brick could be made to use those pins as needed.
Finally, a section for chip selects is off to the side and not connected to the CPU. I haven't figured out how I would do this yet. But I'm thinking of several different "glue" bricks that would tie an address line and a line from a mux, etc. into a chip select. Or a glue brick could be a CPLD that ties all of the chip selects into address lines or where ever.
A ROM brick would tie into address pins, data pins, RW, etc. But again, the "magic" would be with the glue bricks.
At the very least, I would have a small board with a 65c02 ready to plug in with fewer wires.
Your thoughts are welcomed. I would love your opinions.
I used the EasyEDA to design my board. This is the first board I've ever designed so I'm sure I've made mistakes.
One thing missing is an on-board clock. I realize I forgot that. I have a pin for an external clock. I could use some ideas for that too. Perhaps having an on-board clock would be ideal. But keep in mind I'm not designing for speed. 1-4 Mhz tops.
Also, notice there is a jumper for the power source. I thought it would be nice if each board could select between 3.3v and 5v. All they would have to do is put a jumper on VCC. Of course, level shifters would be required on modules of different voltages.
https://easyeda.com/editor#id=u41trXf9qI
File comment: Gerber Files
ProtoBrickCPU.zip [16.25 KiB]
Downloaded 86 times
PostPosted: Sat May 21, 2016 5:12 am
Just a quick note before I close up for the night. The two output clocks of the 65C02 should not be used for anything. WDC recommends that all timing be from the clock generator that is driving the MPU. WDC neither tests or guarantees timing between PHI2 (pin 37) and the PHI1O (pin 3) and PHI2O (pin 39) outputs, which will lag PHI2 by an unspecified amount.
Also, in the interest of reducing the footprint of the MPU, I suggest that you use the PLCC-44 version, not the PDIP-40. Aside from some space savings and potentially easier circuit routing, the PLCC-44 package has two VSS connections, which will help with minimizing ground bounce problems.
PostPosted: Mon May 23, 2016 5:58 pm
I've been giving this some thought for a possible future project based on the rc2014.
I'm thinking of putting some 74HC138 decoders on the motherboard and distributing them to the sub-boards (what you call bricks). Each brick would get (let's say) 16 pins from the address decoders on the motherboard (8 from each decoder). One address decoder is on A14-A12 and one address decoder is on A11-A9. Then, on the board, a few dip switches or jumpers (or a combination) can be used to set the address for the chip on the module, possibly in combination with one or two more TTL chips like a 74LS00.
Another option is to use one or two 74HC688 (8-bit comparator) on the module in combination with some jumpers. You would connect one side of the comparator(s) to the significant part of the address bus, and the other side to the combination of 0's and 1's you need to check for. With a smart jumper system, you can adjust the number of "insignificant pins" by connecting the "fixed side" of some comparators to the address bus.
===Jac
PostPosted: Thu May 26, 2016 8:25 pm
Thanks for the suggestions!
@jac
Sounds like you and me are wanting the same thing. That's a very interesting idea on the glue logic.
I've been brainstorming some ideas for that as well. The other bricks should be pretty simple. RAM, ROM, VIA, etc.
A microcontroller would be perfect for this but you're not going to get much speed out of it. I don't need super fast but faster than 2-3 MHz would be nice.
PLCC-44 is certainly an option. I may look into that sometime.
**EDIT**
BTW, I might totally rip off that rc2014 idea. That is really awesome. The most expensive part would be the base board. The modules look to be pretty small.
PostPosted: Thu May 26, 2016 10:46 pm
I know, right? The idea of a small passive motherboard with numerous small cute configurable plugins, each with a single function, is very attractive.
I'm thinking I'd use some edge connectors on the motherboard so that the modules don't need any connectors at all. I'm thinking my modules would probably be 1" x 5" so a module with (say) a Propeller or 6502 would cost less than $20 (based on OSHPark pricing which would make the module $25 for three each).
This is all still pretty vague in my head at this time. A complete system with enough hardware to build (say) an Apple 1 replica would still end up costing more than (say) the Replica 1, but the nice thing is that you'll be able to reuse the modules you already have, for other computer replicas or for your own design.
But let's not get distracted. The next hardware I'll design is probably going to be an expansion board for L-Star that lets you emulate a KIM-1 or Elektor Junior, or an expansion board that will finally let me build a Commodore PET replica, which is what this entire Propeddle / L-Star fun was all about in the first place :-)
===Jac
PostPosted: Thu May 26, 2016 11:35 pm
The main board should have all the basics on it, like some RAM, ROM, and I/O. It would be rather pointless to just put the processor by itself on a wider and longer pin configuration. A board with the processor plus some basics could be made up to plug into another DIP socket. The next DIP size up is 48 pins, but rare, and the next one up after that is 64 pins, and with .9" row spacing, like the 68000 had, but sockets for that are rare too.
The rc2014 idea might work well, giving it a dual-row pin header of .025" square pins (like my memory module has) so a decent number of pins doesn't get so long. This configuration also allows boards that need some extra width.
Vector (and maybe other companies) used to supply 44-contact prototyping boards that plug into the Commodore 64, like this one I built some extra I/O onto:
It shows up approximately actual size on my monitor. A card cage of those would be really compact and cute.
For things that need more connections, the 96-pin DIN 41612 connectors work nicely. They fit in standard hobbyist-friendly perfboard, and there are card cages available with these too. I have chosen this type of connector for my new workbench computer.
PostPosted: Fri May 27, 2016 1:31 am
But then you're a bit stuck, aren't you, because that part of the design is then frozen. The RC2014 setup makes it endlessly flexible. There's something very attractive about that concept.
PostPosted: Fri May 27, 2016 2:17 am
Flexibility comes with jumper options. You plug the tiny jumpers onto pin headers, and you can move or remove the jumpers as many times as you wish, with no soldering. PCs used to have a lot of these, especially on plug-in cards. The RC2014 thing is still good; but the CPU board should have more than just the processor.
PostPosted: Fri May 27, 2016 12:20 pm
I don't speak for everyone, but the reason having the CPU alone (for me) is that I want to build other systems that aren't based on the 6502.
The ColecoVision, for example, is a favorite of mine. A Z80 board and a 6502 board could use the same RAM/ROM boards. Especially if I keep their unique pins separate.
A ColecoVision clone is something I've always wanted to build. Especially since it's such a simple system.
PostPosted: Fri May 27, 2016 1:31 pm
It does seem to me that a modular system should separate RAM, ROM and I/O from the CPU, in order to allow experimentation with different memory maps (or even banking schemes.) It's not ideal for any specific setup, but the idea is to maximise flexibility.
PostPosted: Fri May 27, 2016 7:12 pm
You could do that with a single board whose glue logic is in a CPLD.
PostPosted: Fri May 27, 2016 7:27 pm
That can be done with jumpers too (or programmable logic as BDD suggested), to use different memory maps or schemes, and memory sizes and distributions or even disable onboard memory altogether in favor of completely offboard memory. You can also use jumpers to select between a 65c02 and 65816 in the same socket.
The 6502 and Z80 bus structures are a bit different, so the processor board would have to at least have some logic on it to arrive at a common memory interface, right? So if a bare-6502 board or a bare-Z80 board were plugged into an I/O or memory module, those modules would have to have jumpers or use programmable logic to sort out the interface to the processor's bus.
PostPosted: Wed Jun 08, 2016 10:44 pm
I played around with such a design prior to designing my SBC. It certainly is not the most cost effective design, but it has the advantage of being fully modular.
Here are a few pics of my take on such a system.
CPU:
RAM / ROM:
Isometric Rendering:
- Billy
PostPosted: Wed Jun 08, 2016 10:46 pm
Continued due to max attachments...
The system has headers for the data, address, and other 6502 bus lines as well as connections to the rx and tx pins of the USB connector (could be used by a serial board).
- Billy
PostPosted: Thu Jun 09, 2016 12:21 pm
Those are some nice designs.
Regarding the Z80/65c02 boards connecting to RAM/ROM...maybe I didn't explain very well. But the idea was to simply have all of the address and data lines in the same spot for CPU, RAM and ROM. A15-A0 is common. D7-D0 is common.
But yes, the I/O and "glue" logic would have to be jumpered or unique for Z80/65c02.
Users browsing this forum: rwiker and 33 guests
