Advin Pilot-MVP
Jokse
Advin Pilot-MVP
Post by Jokse »
Hi,
about a year ago, I bought an Advin Pilot-MVP on ebay for about $70. It seems to be quite simple on the inside, no microcontroller, discrete parts and only an EEPROM for some identification from what I can tell... Would anyone want hi-res images of the board to reverse engineer the schematic as this should be able to program some of the GALs that has been requested programming algorithms for here. (http://www.advin.com/universal-EPROM-pr ... wnload.htm)
Re: Advin Pilot-MVP
Wouldn't it be best to use the software provided by the manufacturer? If you have a parallel port and can run windows (even in a VM, perhaps) then you're good to go.
Jokse
Re: Advin Pilot-MVP
Post by Jokse »
Oh, for me it is working wonderfully. It was more to see if there was anything interesting on the inside for others... Especially the ones that have been asking about Atmel 22V10 and other Atmel PLDs...
Re: Advin Pilot-MVP
Oh, sorry, I see - take the circuit and build an equivalent.
(It's good to know that it's working well!)
