Hi,
about a year ago, I bought an Advin Pilot-MVP on ebay for about $70. It seems to be quite simple on the inside, no microcontroller, discrete parts and only an EEPROM for some identification from what I can tell... Would anyone want hi-res images of the board to reverse engineer the schematic as this should be able to program some of the GALs that has been requested programming algorithms for here. (http://www.advin.com/universal-EPROM-pr ... wnload.htm)
Advin Pilot-MVP
Re: Advin Pilot-MVP
Wouldn't it be best to use the software provided by the manufacturer? If you have a parallel port and can run windows (even in a VM, perhaps) then you're good to go.
Re: Advin Pilot-MVP
Re: Advin Pilot-MVP
Oh, sorry, I see - take the circuit and build an equivalent.
(It's good to know that it's working well!)
