Thanks,
EPROM programmer
EPROM programmer
Does anyone know a cheap way to program EPROMs without the expense of a programmer. Or does anyone know where there is a cheap programmer I could get?
Thanks,
Thanks,
Check out this thread under the Hardware topic:
http://www.6502.org/forum/viewtopic.php?t=634
Hope this helps!
Hope this helps!
Well, I have heard of people programming some types of flash roms using a PC mainboard by hot-swapping the BIOS chip (assuming the PC is able to run a copy of it's BIOS from RAM). I never tried it, and can't say I'd recommend it, heheh. But that could be cheap if you happen to have the right stuff for it.
Wally Daniels
Re: EPROM programmer
Thanks, :D :D
Thanks, :D :D
Haunting Ebay for used programmers might be your best way if you
don't have anything running yet. Also is there any chance that there might
be a local Robotics club nearby ? or even a University or trade School that
might have someone there during the Summer months who could help.
Another avenue to consider is to find an old Apple ][, C64 etc that
had an Programmer with it. I did my first EPROM programming ( and
assembling ) with a C64. It work great and was not alot of money.
This brings up an idea tho, as this topic occurs frequently. Maybe
the group should create an 02 based standalone programmer that tethers
to a PC and will accept Motorola "S" record or Intel hex. This would be a
good beginners project. Could we make something adaptable to Daryls brd
and is controlled by a VIA(S) or PIAs like the Needhams PB10 ?
-Wally
Wally Daniels
art of making do with what you have " ( that may not be verbatim, but if
you check comp.lang.forth archives you'll find it quick enough )
I think the real point to be made here is that of the concept. Understand exactly what it is you need to do, and you will have more flexibility.
I do agree, I would not use anything but a VIA.
