Dutch, german and some english: KIM-1 Elektuur Junior DOS65
Deleted
Re: Dutch, german and some english: KIM-1 Elektuur Junior DO
Thanks for the update Hans. I believe Acorn's Atom was also popular in NL - is that so? Do you have any materials on that?
Edit: I think the original post would have been to this page:
which has much information within.
Elektuur/Elektor and the Junior Computer and other 6502 based machines.
The Junior computer design was published by Elektuur/Elektor from 1980 on. It was published in a series of magazine articles, four books and several socalled paperware A4 booklets.
Deleted
Thank you, Hans.
I've spent many hours in that fascinating section of the old web site and I look forward to checking out the new format.
Cheerful regards, Mike
Deleted
- BigDumbDinosaur
I don't have too much interest in the old machines of which Hans speaks, but I must compliment you on your site, which is a good read no matter what.
Greetings Hans,
The new and updated information looks great in the new format. I'm sure it represents a tremendous amount of work and time. Thank you!
If it helps, I came across a copy of the schematic for the Elektuur Junior which is much nicer than the schematic found in the scanned Book 1 PDF file.
(Oddly, I can't reach the site with my normal config because Google's nameservers at 8.8.8.8 can't resolve it. My ISP's own nameservers can.)
I have the same problem.. although it did work with Google's nameserver a few hours ago, intermittently. Not now.
-Tor
-Tor
- BigDumbDinosaur
I use 4.2.2.2 and 4.2.2.3 for the nameservers around here. Google's servers can sometimes lead you down a dirt road.
Deleted
- jac_goudsmit
I've been looking at Hans Otten's pages and Ruud Baltissen's pages, as well as Patrick Zoete's "Kim-Kenner" magazine archives, and I've been doing a little project with my MicroKim (https://hackaday.io/project/4418).
Seeing that Junior schematic again after working with the MicroKim for a while made me realize that the Junior and MicroKim schematics are actually more similar to each other than the Junior and the KIM-1 or the MicroKim and the KIM-1: After all, both Junior and MicroKim have one 6532 instead of the KIM-1's two 6530's.
Of course the MicroKim has the inverter on A4 to the 6532 and the extra logic around IO2/IO3 to emulate the KIM-1 memory map, and the Junior has the common-cathode displays to reduce parts count.
Makes me wonder how hard it would be to turn a MicroKim into a Junior. Not much, I think...
===Jac
===Jac
Deleted
Deleted
- BigDumbDinosaur
HansO wrote:
