Printing $41 via the BSOUT ($FFD2) kernel subroutine will display an 'A'.
Sounds like a good worked example. I'll use
easy6502 to assemble and to get a listing:
Address Hexdump Dissassembly
$0600 a9 41 LDA #$41
$0602 20 d2 ff JSR $ffd2
$0605 60 RTS
To run this using SYS we'll need to convert the program to decimal bytes and POKE them in. (Easy6502 defaults to producing code at $600 and always disassembles from there, so I've left that as is. In this case the code isn't sensitive to where it's placed)
POKE 1536,169
POKE 1537,65
POKE 1538,32
POKE 1539,210
POKE 1540,255
POKE 1541,96
SYS 1536
and it works as expected:
File comment: Screenshot from http://www.thomasskibo.com/6502/pet2001/
As an optimisation, which could easily be confusing for the beginner, you can always replace a sequence
JSR somewhere
RTS
with the shorter and faster alternative
JMP somewhere
To do that, we note that JMP is 4c in hex, or 76 decimal, so we need
POKE 1538,76
instead.
