POC VERSION TWO
- BigDumbDinosaur
POC Version 2 Logic
This project is still languishing, as for some reason I can't seem to get my head around the CUPL code needed to program the CPLD. Adding to the fun, I discovered some irritating bugs in Atmel's WinCUPL that wasted a fair amount of my time as I tried to convert what I want the circuit to do into the mumbo-jumbo understood by the CUPL compiler. Some of the syntax described in the CUPL programming manual is either not correctly implemented in the compiler, or is not supported at all.
One thing that has become quite clear is that WinCUPL is not very good software. It is touchy about what's in the source code and will crash in some cases during compilation if an error is encountered. WinCUPL appears to have originally been an MS-DOS program that got "WIMPed" back in the days of Windows 95/98 and hasn't seen much maintenance since then. The latest date that I could find indicating that anyone had a look at the code is in 2004. Testing has determined that it is unstable on Windows 7 64 bit (which I don't use—I cannot stand its user interface). Oddly, running the UNIX strings command on the executable turns up references to Logical Devices Corp., the originators of CUPL. They haven't been around for years.
ElEctric_EyE
Re: POC Version 2
Screw Atmel BDD. I never liked not being able to program their GAL22 IC because of their proprietary algorithm when I first got into programmable logic.
I know it's difficult sometimes to loose allegiance to a particular company, but Xilinx has some great software. Heck you can even choose schematic entry for your CPLD.
But maybe the issue is 5v compatibility?
- BigDumbDinosaur
Re: POC Version 2
- BitWise
- In Memoriam
Re: POC Version 2
I run WinCUPL on an old XP laptop which solves some of the stability issues but I still always save before compiling and make frequent backups.
You could probably achieve the same thing running XP in a virtual machine under either Windows 7 or Linux. I use VirtualBox to create expendable XP development environments on my main Windows 7 64-bit machine for legacy software like this.
Andrew Jacobs
- BigDumbDinosaur
Re: POC Version 2
Re: POC Version 2
ElEctric_EyE wrote:
...but Xilinx has some great software. Heck you can even choose schematic entry for your CPLD. But maybe the issue is 5v compatibility?
Though they are no longer made, the XC9500s are excellent parts IMO. AFAIK the largest one made in 5V was the 108, in PLCC84. Yes, they are discontinued, but they are not that difficult to find, and still supported by the Xilinx tools.
- BigDumbDinosaur
Re: POC Version 2 Logic
...Adding to the fun, I discovered some irritating bugs in Atmel's WinCUPL that wasted a fair amount of my time as I tried to convert what I want the circuit to do into the mumbo-jumbo understood by the CUPL compiler. Some of the syntax described in the CUPL programming manual is either not correctly implemented in the compiler, or is not supported at all.
Anyhow, I was able to build and compile CUPL code for the ATF1508AS CPLD. Here's what I've developed so far:
* W65C816S PROOF OF CONCEPT SINGLE-BOARD COMPUTER *
* Copyright (c)1991-2014 by BCS Technology Limited. All rights reserved. *
* Permission is hereby granted to use, copy, modify and distribute this software, *
* provided this copyright notice remains unaltered in the source code and proper *
* attribution is given. Redistribution, in any form, must be at no charge to the *
* end user. This code or any part thereof, including any derivation, MAY NOT be *
* incorporated into any package intended for sale unless written permission to do *
* so has been granted by the copyright holder. *
* THERE IS NO WARRANTY OF ANY KIND WITH THIS SOFTWARE. *
* While it is believed that all code will perform as intended, the user assumes *
* all risk in connection with the incorporation of this software into any system. *
* VERSION HISTORY *
Ver Rev Date Revision
0.1.0 2014/02/17 Original version.
0.2.0 2014/07/21 Added wait-state logic
0.3.0 2014/09/07 Added hardware management unit (HMU).
0.4.0 2014/10/18 Added "bleed-through" to write accesses to ROM.
0.5.0 2014/11/24 Added ability to map out ROM and/or I/O to expose RAM at same
address. Change doesn't affect HMU,
0.5.1 2014/11/25 Some intermediate logic defintions changed to pinnodes to re-
duce number of product terms on some outputs.
Name glue;
PartNo B402170001;
Date 2014/02/17;
Revision 0.5.0;
Designer BDD;
Company BCS Technology Limited;
Assembly POC V2;
Location U2;
Device f1508plcc84;
ATF1508AS (PLCC-84)
______________________________________
RESB x---|1 INPUT/GCLR INPUT/OE1 84|---x
x---|2 INPUT/OE2/GCLK2 INPUT/GCLK1 83|---x CLKP
Vcc x---|3 VccINT Gnd 82|---x Gnd
ABTB x---|4 I/O IO/GCLK3 81|---x E
IRQB x---|5 I/O I/O 80|---x RWB
A0 x---|6 I/O I/O 79|---x VDA
GND x---|7 Gnd VccIO 78|---x Vcc
VPB x---|8 I/O I/O 77|---x RDY
VPA x---|9 I/O I/O 76|---x A15
A1 x---|10 I/O I/O 75|---x A14
NMIB x---|11 I/O I/O 74|---x D7
x---|12 IO/PD I/O 73|---x D4
Vcc x---|13 VccIO Gnd 72|---x Gnd
x---|14 IO/TDI (JTAG) IO/TDO (JTAG) 71|---x
A2 x---|15 I/O I/O 70|---x D5
x---|16 I/O I/O 69|---x A18
x---|17 I/O I/O 68|---x A17
x---|18 I/O I/O 67|---x A16
Gnd x---|19 Gnd VccIO 66|---x Vcc
x---|20 I/O I/O 65|---x /RD
x---|21 I/O I/O 64|---x D0
x---|22 I/O I/O 63|---x D6
x---|23 IO/TMS (JTAG) IO/TCK (JTAG) 62|---x
/EWS x---|24 I/O I/O 61|---x D1
x---|25 I/O I/O 60|---x D2
Vcc x---|26 VccIO Gnd 59|---x Gnd
x---|27 I/O I/O 58|---x D3
RST x---|28 I/O I/O 57|---x /RAM
x---|29 I/O I/O 56|---x /WD
x---|30 I/O I/O 55|---x /ROM
x---|31 I/O I/O 54|---x A13
Gnd x---|32 Gnd VccIO 53|---x Vcc
x---|33 I/O I/O 52|---x A11
x---|34 I/O I/O 51|---x A12
x---|35 I/O I/O 50|---x A10
x---|36 I/O I/O 49|---x A8
/IO2 x---|37 I/O I/O 48|---x A9
Vcc x---|38 VccIO Gnd 47|---x Gnd
/IO3 x---|39 I/O I/O 46|---x /IO1
x---|40 I/O IO/PD 45|---x
/IO0 x---|41 I/O I/O 44|---x /IO4
Gnd x---|42 Gnd VccINT 43|---x Vcc
|______________________________________|
INPUT PIN ASSIGNMENTS
pin = A0; /* address line $000001 */
pin = A1; /* address line $000002 */
pin = A2; /* address line $000004 */
pin = A8; /* address line $000100 */
pin = A9; /* address line $000200 */
pin = A10; /* address line $000400 */
pin = A11; /* address line $000800 */
pin = A12; /* address line $001000 */
pin = A13; /* address line $002000 */
pin = A14; /* address line $004000 */
pin = A15; /* address line $008000 */
pin 24 = !EWS; /* enable wait-stating */
pin = IRQB; /* MPU maskable interrupt */
pin = NMIB; /* MPU nonmaskable input */
pin = E; /* MPU operating mode */
pin = RWB; /* MPU read/write */
pin = VDA; /* MPU valid data address */
pin = VPA; /* MPU valid instruction address */
pin = VPB; /* MPU interrupt vector pull */
pin 83 = PHI2; /* system clock */
pin 1 = RESB; /* system reset */
OUTPUT PIN ASSIGNMENTS
pin = A16; /* address line $010000 */
pin = A17; /* address line $020000 */
pin = A18; /* address line $040000 */
pin = ABTB; /* MPU abort interrupt */
pin = !IO0; /* I/O device 'A' select */
pin = !IO1; /* I/O device 'B' select */
pin = !IO2; /* I/O device 'C' select */
pin = !IO3; /* I/O device 'D' select */
pin = !IO4; /* I/O device 'E' select */
pin = !RST; /* inverted reset */
pin = !RAM; /* RAM chip select */
pin = !RD; /* read data */
pin = !ROM; /* ROM chip select */
pin = !WD; /* write data */
BIDIRECTIONAL PIN ASSIGNMENTS
pin = D0; /* data line $01 */
pin = D1; /* data line $02 */
pin = D2; /* data line $04 */
pin = D3; /* data line $08 */
pin = D4; /* data line $10 */
pin = D5; /* data line $20 */
pin = D6; /* data line $40 */
pin = D7; /* data line $80 */
pin = RDY; /* MPU wait */
MACHINE ARCHITECTURE & HARDWARE MANAGEMENT UNIT DEFINTIONS
+--------------------------+ $07FFFF
| RAM (448 KB) |
+-------+--------------------------+ $010000
| E-RAM | E-ROM (8 KB) |
+-------+--------------------------+ $00E000
| Hardware Management Unit |
+-------+--------------------------+ $00DF00
| D-RAM | I/O (3.75 KB) |
+-------+--------------------------+ $00D000
| C-ROM | C-RAM (4 KB) |
+-------+--------------------------+ $00C000
| RAM (48 KB) |
+--------------------------+ $000000
1 KB = 1024 bytes
HMU
Register Address Register Description Bit Function Notes
hmumcfg $00DF00 System configuration: 0 0: C-RAM write-protection off A
1: C-RAM write-protection on
1 0: E-RAM write-protection off A
1: E-RAM write-protection on
2 not defined
3 0: I/O A
1: D-RAM
4 0: C-RAM A
1: C-ROM
5 0: E-ROM A
1: E-RAM
6 0: bank $00 remapping off A
1: bank $00 remapping on
7 0: hardware protection off A,B
1: hardware protection on
hmubnki $00DF01 In-context bank
hmubnks $00DF02 System mode bank
hmubnku $00DF03 User mode bank
hmupisr $00DF04 Interrupt status: 0-2 interrupting device ID C,D
6 1: NMI detected
7 1: IRQ detected
hmupimr $00DF05 Interrupt masks: 0 1: IRQ A enabled
1 1: IRQ B enabled
2 1: IRQ C enabled
3 1: IRQ D enabled
hmustat $00DF06 System status: 6 0: supervisor mode enabled A,C
1: user mode enabled
7 1: SCSI DMA request active
Notes: A) Default following reset.
B) Also disables bank $00 remapping.
C) Read only register.
D) Valid only if bit 7 = 1.
$DEFINE cblkwpe hmumcfg0
$DEFINE eblkwpe hmumcfg1
$DEFINE dblkmap hmumcfg3
$DEFINE cblkmap hmumcfg4
$DEFINE eblkmap hmumcfg5
$DEFINE bnk0rmap hmumcfg6
$DEFINE protect hmumcfg7
$DEFINE activirq [hmupisr0..2]
$DEFINE nmimask hmupisr6
$DEFINE irqmask hmupisr7
$DEFINE irqaenab hmupimr0
$DEFINE irqbenab hmupimr1
$DEFINE irqcenab hmupimr2
$DEFINE irqdenab hmupimr3
$DEFINE protmode hmustat6
$DEFINE scsidreq hmustat7
BURIED LOGIC DECLARATIONS
node bank0; /* 1 = $000000-$00FFFF being accessed */
pinnode = [blatch0..2]; /* A16-A18 latches */
node dblk; /* 1 = $00D000-$00DFFF being accessed */
pinnode = [hmubnki0..7]; /* HMU in-context bank register */
pinnode = [hmubnks0..7]; /* HMU supervisor mode bank register */
pinnode = [hmubnku0..7]; /* HMU user mode bank register */
pinnode = [hmumcfg0..7]; /* HMU system configuration register */
pinnode = [hmupimr0..7]; /* HMU interrupt mask register */
/* pinnode = [hmupisr0..7]; /* HMU interrupt status register */
pinnode = [hmustat0..7]; /* HMU system status register */
node hmurd; /* 1 = reading from HMU */
node hmusel; /* 1 = HMU being accessed */
node hmuwd; /* 1 = writing to HMU */
node ioblk; /* 1 = I/O address space being accessed */
node iosel; /* 1 = I/O device being accessed */
/* pinnode = [irqn0..2]; /* IRQ priority encoder bits */
node opcode; /* 1 = opcode fetch in progress */
node rdflag; /* 1 = data fetch in progress */
node rdyout; /* 1 = MPU wait-stated */
node vbus; /* 1 = address bus valid */
node vdbus; /* 1 = data address valid */
node vpbus; /* 1 = operand address valid */
node wdflag; /* 1 = data store in progress */
node wsenab; /* 1 = wait-state in progress */
pinnode = wsff; /* wait-state flip-flop */
REGISTER RESETS & PRESETS
/* hmurd.AR = !RESB;
hmusel.AR = !RESB;
hmuwd.AR = !RESB;
rdflag.AR = !RESB;
rdyout.AR = !RESB;
wdflag.AR = !RESB;
wsenab.AR = !RESB; */
wsff.AR = !RESB;
/* hmurd.AP = 'b'0;
hmusel.AP = 'b'0;
hmuwd.AP = 'b'0;
rdflag.AP = 'b'0;
rdyout.AP = 'b'0;
wdflag.AP = 'b'0;
wsenab.AP = 'b'0; */
wsff.AP = 'b'0;
[hmumcfg0..7].AR = !RESB;
[hmubnki0..7].AR = !RESB;
[hmubnks0..7].AR = !RESB;
[hmubnku0..7].AR = !RESB;
/* [hmupisr0..7].AR = !RESB; */
[hmupimr0..7].AR = !RESB;
[hmustat0..7].AR = !RESB;
[hmumcfg0..7].AP = 'b'0;
[hmubnki0..7].AP = 'b'0;
[hmubnks0..7].AP = 'b'0;
[hmubnku0..7].AP = 'b'0;
/* [hmupisr0..7].AP = 'b'0; */
[hmupimr0..7].AP = 'b'0;
[hmustat0..7].AP = 'b'0;
BUS CONTROL LOGIC
opcode = VDA & VPA; /* true if opcode fetch */
vdbus = VDA & !VPA; /* true if valid data address */
vpbus = !VDA & VPA; /* true if valid operand address */
vbus = VDA # VPA; /* true if valid address */
rdflag = RWB & vbus; /* true if fetch operation */
wdflag = !RWB & vbus; /* true if store operation */
EXTENDED ADDRESSING LOGIC
[blatch0..2].LE = vbus & !PHI2;
[blatch0..2].L = vbus & !PHI2 & [D0..2];
bank0 = [blatch2..0]:'b'000; /* true if $000000-$00FFFF */
extram = !bank0; /* true if $010000-$07FFFF */
MEMORY MAPPING LOGIC
basram = (!A15 # !A14) & bank0; /* $000000-$00BFFF */
cblk = A15 & A14 & !(A13 # A12) & bank0; /* $00C000-$00CFFF */
dblk = A15 & A14 & !A13 & A12 & bank0; /* $00D000-$00DFFF */
eblk = A15 & A14 & A13 & bank0; /* $00E000-$00FFFF */
ioblk = dblk & !(A11 & A10 & A9 & A8); /* I/O hardware */
/* RAM selection rules... */
ramsel = basram # /* base RAM */
cblk & (wdflag # !cblkmap) # /* C-RAM */
ioblk & dblkmap # /* D-RAM */
eblk & (wdflag # eblkmap) # /* E-RAM */
extram; /* extended RAM */
/* ROM selection rules... */
romsel = cblk & rdflag & cblkmap # /* C-ROM */
eblk & rdflag & !eblkmap; /* E-ROM */
/* I/O devices selection rules... */
iosel = ioblk & !dblkmap;
HMU ACCESS LOGIC
hmusel = dblk & A11 & A10 & A9 & A8; /* HMU base selection */
mcfgsel = !A2 & !A1 & !A0; /* configuration register */
ibnksel = !A2 & !A1 & A0; /* in-context bank register */
sbnksel = !A2 & A1 & !A0; /* system mode bank register */
ubnksel = !A2 & A1 & A0; /* user mode bank register */
pisrsel = A2 & !A1 & !A0; /* IRQ status register */
pimrsel = A2 & !A1 & A0; /* IRQ mask register */
statsel = A2 & A1 & !A0; /* system status register */
hmurd = hmusel & rdflag & PHI2; /* any register read */
hmuwd = hmusel & wdflag & PHI2; /* any register write */
IRQ PRIORITY ENCODING LOGIC
$IFDEF skip_this_code
table irqi => irqn {
'b'xxxx1xxx => 'd'3; /* IRQ A */
'b'xxxxx1xx => 'd'2; /* IRQ B */
'b'xxxxxx1x => 'd'1; /* IRQ C */
'b'xxxxxxx1 => 'd'0; /* IRQ D */
'b'00000000 => 'd'0; /* no pending IRQ */
$ENDIF
WAIT-STATE LOGIC
The following code causes a wait-state to occur on I/O or ROM accesses
if the EWS jumper block on the PCB is shorted. A wait-state will last
for one phase-2 clock cycle.
wsenab = (iosel # romsel) & EWS;
wsff.CK = PHI2 & wsenab;
wsff.D = wsff & wsenab;
rdyout = wsenab & wsff;
CONTROL OUTPUT STATEMENTS
[A16..18] = [blatch0..2] & vbus; /* A16-A18 address bits */
ABTB = 'b'1; /* abort interrupt -- testing */
IO0 = iosel & !A10 & !A9 & !A8 & vbus; /* I/O device 'A' select */
IO1 = iosel & !A10 & !A9 & A8 & vbus; /* I/O device 'B' select */
IO2 = iosel & !A10 & A9 & !A8 & vbus; /* I/O device 'C' select */
IO3 = iosel & !A10 & A9 & A8 & vbus; /* I/O device 'D' select */
IO4 = iosel & A10 & !A9 & !A8 & vbus; /* I/O device 'E' select */
RAM = ramsel & vbus; /* RAM chip enable */
RD = (rdflag & PHI2 #
rdflag & rdyout) & !hmusel; /* active low read */
RDY = !rdyout; /* MPU wait-state input */
RDY.oe = wsenab; /* active if wait-stating */
ROM = romsel & vbus; /* ROM chip enable */
RST = RESB; /* inverted reset */
WD = wdflag & (PHI2 # rdyout) & !hmusel; /* active low write */
HMU REGISTER ACCESS STATEMENTS
/* clocks... */
[hmumcfg0..7].CK = mcfgsel & hmuwd;
[hmubnki0..7].CK = ibnksel & hmuwd;
[hmubnks0..7].CK = sbnksel & hmuwd;
[hmubnku0..7].CK = ubnksel & hmuwd;
/* [hmupisr0..7].CK = pisrsel & hmuwd; */
[hmupimr0..7].CK = pimrsel & hmuwd;
[hmustat0..7].CK = statsel & hmuwd;
/* interrupt status conditioning... */
/* [hmupisr0..2].D = !IRQB & 'b'1; /**** testing ****/
/* [hmupisr3..5].D = 'b'1; /* unused ISR bits */
/* hmupisr{6}.D = NMIB; /* nonmaskable interrupt */
/* hmupisr{7}.D = IRQB; /* interrupt request */
/* configuration & control register writes... */
[hmumcfg0..7].D = mcfgsel & hmuwd & [D0..7];
[hmubnki0..7].D = ibnksel & hmuwd & [D0..7];
[hmubnks0..7].D = sbnksel & hmuwd & [D0..7];
[hmubnku0..7].D = ubnksel & hmuwd & [D0..7];
[hmupimr0..7].D = pimrsel & hmuwd & [D0..7];
[hmustat0..7].D = statsel & hmuwd & [D0..7];
/* register reads... */
[D0..7].oe = (
mcfgsel # ibnksel #
sbnksel # ubnksel #
pisrsel # pimrsel #
statsel
) & hmurd;
[D0..7] = (
mcfgsel & [hmumcfg0..7] #
ibnksel & [hmubnki0..7] #
sbnksel & [hmubnks0..7] #
ubnksel & [hmubnku0..7] #
/* pisrsel & [hmupisr0..7] # */
pimrsel & [hmupimr0..7] #
statsel & [hmustat0..7]
) & hmurd;
/* * * * * E N D O F F I L E * * * * */A constraint of the EPCB Proto-Pro layout is the maximum allowable board size of 21 square inches (1354 square centimeters). The rectangular shape I conceived for POC V2 allows me to use the SCSI host adapter I devised for POC V1—the west end of the board has to stay unchanged so everything lines up. Unfortunately, that limits the space available to the CPLD and significantly limits the ability to use the topmost row of pins. However, the fitter that is part of Atmel's WinCUPL software can't fit my design to the 1508 as I want it. If I let the fitter auto-fit the design it works out fine, but results in many of the top row pins being assigned to a circuit function. I can move a few of the connections, but not enough to make it work.
It seems that I am going to be forced into using EPCB's production service so I can shape the PCB in a way that allows me to use the pins that are not readily accessible in the Proto-Pro layout. This issue is not unlike what ElEctric_EyE underwent in his project, except his problem was that of too many holes, rather than insufficient area. In my case, I'm okay with the hole count (637), but need more board area—my board is 6 inches × 3.5 inches, putting it right at the 21 square inch limit.
I'm going to work out a totally new board layout that is designed to make best use of the 1508, rather than work within the Proto-Pro limits, which should allow me to distribute I/O connections evenly around all sides of the device. I'm not seeing any other (obvious) solution.
- barrym95838
Re: POC Version 2
Those mounting holes @ 12:00 and 6:30 don't look necessary unless it's going to be used in a fighter jet, IMHO. Might you consider getting rid of them and doing a tiny bit of parts shuffling in order to get the space that you need at the top?
Mike
Mike
- BigDumbDinosaur
Re: POC Version 2
The original plan for POC V2 was the use of the smaller Atmel 1504AS CPLD, which comes in a PLCC-44 package. My code fitted that device. Recall that the switch to the 1508AS was because I couldn't get my hands on the Atmel programmer adapter for the PLCC-44 package and couldn't program the device via JTAG, since those pins were being used as I/Os.
ElEctric_EyE
Re: POC Version 2
Hi BDD, I feel your pain.
It's over $100 more for the Production service @ $300US for 2 boards. It does add some pressure to make sure the design comes out 100% the first time!
- BitWise
- In Memoriam
Re: POC Version 2
Sounds like its time to move to a more open design tool and send the plot files to China.
Andrew Jacobs
Re: POC Version 2
BitWise: I was going to suggest exactly the same thing.
- BitWise
- In Memoriam
Re: POC Version 2
Andrew Jacobs
- BigDumbDinosaur
Re: POC Version 2
- BigDumbDinosaur
Re: POC Version 2
BitWise wrote:
Can't you knock up a JTAG programming rig -- a PLCC socket on some strip board with power and JTAG connections.
I would have thought that in 'programming mode' the I/O pins would return to thier JTAG mode until the programming operation completes.
