1080p HD Video on custom FPGA/VDAC/2MBx18 SyncRAM board
ElEctric_EyE
Re: 1080p HD Video on custom FPGA/VDAC/2MBx18 SyncRAM board
Post by ElEctric_EyE »
Next step is to put a blockRAM between the onboard 65Org16.b and the hardware pixel generator.
It will be a wide blockRAM but not too deep. Maybe 8 addresses at this point. The blockRAM databus will be accommodating the required 6-bit address and also 16-bit data going to the pixel generator module. It will be write-only to start, getting it's programming from the 65Org16.b.
After this stage is successful, the 65Org16.b will be removed from each of the PVBs, and then all of them then will receive commands from offboard.
This is why 6-bit address: These are the current registers
// Register addresses
always @(posedge clk2) 							//write to registers
 if (cpuWE & vgaCS)
	case ( cpuAB [5:0] )
		6'b000000: x0t   <= cpuDO;				//variables for line generator
		6'b000001: y0t   <= cpuDO;
		6'b000010: x1t   <= cpuDO;
		6'b000011: y1t   <= cpuDO;
		6'b000100: xc    <= cpuDO;				//variables for circle generator
		6'b000101: yc    <= cpuDO;
		6'b000110: rad   <= cpuDO;
		6'b000111: color <= cpuDO;				//pixel color variable for line/circle/fill/pixel plot
		6'b001000: bXlen <= cpuDO;				//X length of blitter
		6'b001001: bYlen <= cpuDO;				//Y length of blitter
		6'b001010: bXc   <= cpuDO;				//X start copy
		6'b001011: bYc   <= cpuDO;				//Y start copy
		6'b001100: bXp   <= cpuDO;				//X start paste
		6'b001101: bYp   <= cpuDO;				//Y start paste
		6'b001110: Xp    <= cpuDO;				//X for pixel plot
		6'b001111: Yp    <= cpuDO;				//Y for pixel plot
		//6'b010000 reserved for hoffset on previous PVB's
		//6'b010001 reserved for voffset on previous PVB's
		6'b010010: fXlen <= cpuDO;				//X length of fill
		6'b010011: fYlen <= cpuDO;				//Y length of fill
		6'b010100: fXs	<= cpuDO;				//X start
		6'b010101: fYs	<= cpuDO;				//Y start
		6'b010110: htiming[VIDEO] <= cpuDO;	//		htiming[VIDEO] = 1920;
		6'b010111: htiming[FRONT] <= cpuDO;	//    htiming[FRONT] = 160;
		6'b011000: htiming[SYNC]  <= cpuDO;	//    htiming[SYNC]  = 438;
		6'b011001: htiming[BACK]  <= cpuDO;	//    htiming[BACK]  = 120;
		6'b011010: vtiming[VIDEO] <= cpuDO;	//    vtiming[VIDEO] = 1080;
		6'b011011: vtiming[FRONT] <= cpuDO;	//    vtiming[FRONT] = 44;
		6'b011100: vtiming[SYNC]  <= cpuDO;	//    vtiming[SYNC]  = 85;
		6'b011101: vtiming[BACK]  <= cpuDO;	//    vtiming[BACK]  = 2;
		6'b011110: cX <= cpuDO;					//X for character plot
		6'b011111: cY <= cpuDO;					//Y for character plot
		6'b100000: cC <= cpuDO;					//background pixel color
		6'b100001: Charsize <= cpuDO;
		6'b100010: Att <= cpuDO;				//Attributes [15:8], 8-bit character value [7:0]
	endcase
ElEctric_EyE
I decided to take a bit of a rest from the project this past week.
My thoughts were on focusing efforts on designing the controller board. I never did get into it... There was in itch for the rotating cube I had always wanted to do since the beginning of this project. EDIT: Andre's video in this thread was my original inspiration.
Earlier I had wanted to do a hardware ellipse plotter, but I now think this may be best suited to a cpu plotting it in 'scratchpad' memory. The only issue I foresee is the co-cordinates will have to be sorted, or somehow generated in the proper order.
So I went back to work on the project today with this in mind and was able to fit 2x 16Kx11 block RAMs (11bits for 2K resolution), with a total blockRAM usage now up to 90%. 1 RAM holds X and the other RAM holds Y coordinates. The cpu only has access the 'scratchpad' and can read or write to it. So far it is working plotting a simple line.
Now to make things more exciting and non-linear, I'll use genius pseudo sin wave generator I remember seeing here on the forums.
Simple line drawing test using the 'scratchpad' blockRAMs:
                  LDX #255
                  LDY #0
graph             TXA
                  STA scratchx,Y
                  TYA
                  STA scratchy,Y
                  INY
                  DEX
                  BNE graph
                  LDX #2
                  LDA CLUT,X
                  STA color
                  LDX #0
plot              LDA scratchx,X
                  STA Xp
                  LDA scratchy,X
                  STA Yp             ;auto plot pixel and halt cpu until done
                  INX
                  CPX #255
                  BNE plot
ElEctric_EyE
I gave up early on the software sin generator, in favor of the Xilinx CORDIC Sin/Cos hardware engine. I had success very early on, although it does push the project's occupied slices to 92%.
The CORDIC Sin/Cos engine was very easy to interface to, I set it up for a bit width of [10:0] and optimal pipeline mode, which a cycle after it receives an 11-bit phase input, it outputs 11-bit values on the x_out and y_out lines. I sort of rushed through it, I'll have to go back and re-read the CORDIC data sheet.
I made a program to put the sinwave data into the scratchpad X&Y RAMs, then it draws lines from the center of the screen to the coordinates in the RAMs.
;---------     sine wave generator
                  LDX #0
                  LDY #0
sinwave1          STX phase
                  TYA
                  STA scratchx,Y
                  LDA sinyout
                  CLC
                  ADC #512
                  STA scratchy,Y
                  INX
                  INY
                  CPY #1023
                  BNE sinwave1
                  LDX #1060
sinwave2          STX phase
                  TYA
                  STA scratchx,Y
                  LDA sinxout
                  CLC
                  ADC #512
                  STA scratchy,Y
                  INX
                  INY
                  CPY #2047
                  BNE sinwave2
;---------     plot
                  LDX #2
                  LDA CLUT,X
                  STA color
                  LDA #1920/2
                  STA lx0
                  LDA #1080/2
                  STA ly0
                  LDY #0
pline             LDA scratchx,Y
                  STA lx1
                  LDA scratchy,Y
                  STA ly1
                  INY
                  CPY #1919
                  BNE pline
1920x1080
1920x1080
So you get single-cycle trig functions at 11bit precision?
ElEctric_EyE
Here is the CORDIC data sheet.
I was looking at the very bottom of page 15 (also pg.2): "A parallel CORDIC core with N bit output width has a latency of N cycles and produces a new output every cycle."
I use parallel mode, which uses more silicon, but there is a serial mode as well but requires more cycles and more signals. This is my top-level pin assignments for the .xco file, the bare minimum (I'm experimenting w/higher resolutions again):
   sincos sincos ( .clk(clk),
						 .phase_in(phase_in [11:0]),
						 .x_out(x_out [11:0]),
						 .y_out(y_out [11:0]));
The lightbulb tool only lets you choose 1 function from several trig possibilities mentioned under Features. It let's you choose the #of bits too. I initially choose 11 bits, but I'm experimenting with higher bits and shifting right for less error. I'd gone up to 16-bits precision, and Slice resources went from 92% to 96%.
Seems pretty handy! Once you've chosen a model of FPGA, might as well fill it up with useful functions.
ElEctric_EyE
Under trig functions, besides the CORDIC generator, there is also the option to use the DDS compiler. I set that up tonight successfully and compared resources used.
Since all I am really needing here are simultaneous SIN & COS outputs for storage in the X & Y BRAMs for circle/ellipse generation using simple LUT's, the DDS compiler option is appearing to be more appealing. Slice LUT's and occupied slices only went up 2% using DDS. I chose to use blockRAM as opposed to distributed RAM. The curve looks much better too. Less errors
ElEctric_EyE
Much easier to manage software-wise:
                  LDX #0
                  LDY #0
sinwave1          STX phase
                  TYA
                  STA scratchx,Y
                  LDA sinxout
                  CLC
                  ADC #1080/2
                  STA scratchy,Y
                  INX
                  INX
                  INX
                  INX
                  INY
                  CPY #2047
                  BNE sinwave1
             ;------plot
                  LDX #2
                  LDA CLUT,X
                  STA color
                  LDA #1920/2
                  STA lx0
                  LDA #1080/2
                  STA ly0
                  LDY #0
                  STA lx1
                  LDA scratchy,Y
                  STA ly1
                  INY
                  CPY #1919
                  BNE pline
Again, my weak line drawing algorithm is not suitable for drawing across the entire 1920x1080 resolution yet. This is why the origin of the lines is @(1920/2, 1080/2).
ElEctric_EyE
Oh yeah! I've got it: The KEY.
;---------  Circle/Ellipse Generator from sine wave LUT
                  LDWi $0000                ;LDW #0
                  LDX #0
                  LDY #50
sinwave1          STX phase
                  LDA sinout
                  STAaw scratchx        ;STA scratchx,W
                  STY phase
                  LDA cosout
                  STAaw scratchy        ;STA scratchy,W
                  CPX #2047
                  BNE XNZ
                  LDX #0
XNZ               INX
                  CPY #2047
                  BNE YNZ
                  LDY #0
YNZ               INY
                  INW
                  CPWi $07FF             ;CPW #2047
                  BNE sinwave1
                  LDX #5            ;green
                  LDA CLUT,X
                  STA color
                  LDY #0
plot              LDA scratchx,Y
                  CLC
                  ADC #1920/2
                  STA Xp
                  LDA scratchy,Y
                  CLC
                  ADC #1080/2
                  STA Yp
                  INY
                  CPY #2047
                  BNE plot
Not sure why it seems to be doing every other dot...
Do you have a multiply instruction in this CPU?
ElEctric_EyE
No, I've not had time to pursue that yet...
Why do you ask? Do you have something in mind?
I was just thinking that multiplication is pretty handy for scaling things. And it's cheap - hardware multipliers already on the FPGA. You may recall I tried to add it to a branch of my 65Org16 but got into a mess and never dug it out completely.
ElEctric_EyE
Chances are I will get back into that sooner than later, as this stage of the project is almost finished. I have already tried once a long time ago to add multiply feature and came out with some issues I was not able to resolve, based on your core.
But as far as this project, I would like to put the ellipse/circle generator which is in software now, into a Verilog module so it can run much faster. After this I will be very close to some good 3-d vector animation!
ElEctric_EyE
ElEctric_EyE wrote:
...But as far as this project, I would like to put the ellipse/circle generator which is in software now, into a Verilog module so it can run much faster. After this I will be very close to some good 3-d vector animation!
That was a tangent :!: I tried the idea, but it got hairy real quick. After about 2hrs of writing the Verilog code, simulations revealed that the way I had envisioned this was not going to work due to timing issues and it was not worth the time investment that I was beginning to realize. To compound this issue, I forgot to save the initial project success before the heavy modification. It took 4 days to get back to the last pic with the ellipse. 3 of which due to to 1 character mis-type in address decoding. I found that error this morning after extensive sim's. Stupid mistake, but finding the needle (in the haystack) gives one confidence. So I post...
Long story short: I have 3Kx11 worth (3x 1Kx11) of data values that the cpu modified from an original 1Kx11 sine LUT. I don't think there's any need yet to do this part very fast...
There is 16Kx11 available. :wink:
This is how I program it, for those who dare analyze. :lol: . It's actually cake. The Y index values are cosines in the 'sinwave' routines. The X index values are sines. So by plotting sine/cosine in an X/Y system, you get a circle or ellipse depending on the X/Y index registers. The W index is the length of the LUT.
                  LDWi $0000                ;LDW #0
                  LDX #128
                  LDY #256
sinwave1          STX phase
                  LDA sinout
                  STY phase
                  LDA sinout
                  CPX #1023
                  BMI XNZ
                  LDX #0
XNZ               INX
                  CPY #1023
                  BMI YNZ
                  LDY #0
YNZ               INY
                  INW
                  CPWi $03FF             ;CPW #1023
                  BNE sinwave1
                  LDWi $0400                ;LDW #1024
                  LDX #850
                  LDY #256
sinwave2          STX phase
                  LDA sinout
                  STY phase
                  LDA sinout
                  CPX #1023
                  BMI XNZ2
                  LDX #0
XNZ2              INX
                  CPY #1023
                  BMI YNZ2
                  LDY #0
YNZ2              INY
                  INW
                  BNE sinwave2
                  LDWi $0800                ;LDW #2048
                  LDX #0
                  LDY #256
sinwave3          STX phase
                  LDA sinout
                  STY phase
                  LDA sinout
                  CPX #1023
                  BMI XNZ3
                  LDX #0
XNZ3              INX
                  CPY #1023
                  BMI YNZ3
                  LDY #0
YNZ3              INY
                  INW
                  CPWi $0BFF             ;CPW #3071
                  BNE sinwave3
                  LDX #7            ;yellow
                  LDA CLUT,X
                  STA color
                  LDY #0
plot              LDA scratchx,Y
                  LSR
                  CLC
                  ADC #150
                  STA Xp
                  LDA scratchy,Y
                  LSR
                  CLC
                  ADC #500
                  STA Yp
                  JSR DELAY2
                  INY
                  CPY #1023
                  BMI plot
                  LDX #5            ;green
                  LDA CLUT,X
                  STA color
                  LDY #1024
plot2             LDA scratchx,Y
                  LSR
                  LSR
                  LSR
                  CLC
                  ADC #700
                  STA Xp
                  LDA scratchy,Y
                  LSR
                  LSR
                  LSR
                  CLC
                  ADC #100
                  STA Yp
                  JSR DELAY2
                  INY
                  INY
                  INY
                  INY
                  CPY #2047
                  BMI plot2
                  LDX #1            ;white
                  LDA CLUT,X
                  STA color
                  LDY #2048
plot3             LDA scratchx,Y
                  LSR
                  LSR
                  CLC
                  ADC #1250
                  STA Xp
                  LDA scratchy,Y
                  LSR
                  LSR
                  CLC
                  ADC #350
                  STA Yp
                  JSR DELAY2
                  INY
                  INY
                  CPY #3071
                  BMI plot3
STALL             JMP STALL
So I have 3 virtex modifiers. A simple triangle would be a first test. These ellipses and circle would not be plotted. Lines would be drawn to their circumferences in some regular order.
BTW, here is theDELAY2 routine so I can see the pixels plotted at a relatively slow rate. This is still 65Org16.b @74.25MHz.
DELAY2            LDX #$007
LXJ               LDWi $FFFF
GHJ               DEW
                  BNE GHJ
                  DEX
                  BNE LXJ
                  RTS
ElEctric_EyE
Alright! Some more progress. Changed the software that writes to each of the scratchpad blockRAM. Each blockRAM has it's own label now... Ellipses are still there for proof, now with a line drawn from each to another.
Heh, this is gonna be good! 3 other PVB's are on standby awaiting updates. They will run in serial, passing their RGB parallel graphics onto this, the final output board.
Sorry for the bad pic. The sun is actually out today which messed with the camera settings.
                  LDWi $0000                ;LDW #0
                  LDX #128
                  LDY #256
sinwave1          STX phase
                  LDA sinout
                  LSR
                  CLC
                  ADC #150
                  STAaw scratchx1        ;STA scratchx,W
                  STY phase
                  LDA sinout
                  LSR
                  CLC
                  ADC #500
                  STAaw scratchy1        ;STA scratchy,W
                  CPX #1023
                  BMI XNZ
                  LDX #0
XNZ               INX
                  CPY #1023
                  BMI YNZ
                  LDY #0
YNZ               INY
                  INW
                  BNE sinwave1
                  LDWi $0000
                  LDX #850
                  LDY #256
sinwave2          STX phase
                  LDA sinout
                  LSR
                  LSR
                  LSR
                  CLC
                  ADC #700
                  STAaw scratchx2
                  STY phase
                  LDA sinout
                  LSR
                  LSR
                  LSR
                  CLC
                  ADC #100
                  STAaw scratchy2
                  CPX #1023
                  BMI XNZ2
                  LDX #0
XNZ2              INX
                  CPY #1023
                  BMI YNZ2
                  LDY #0
YNZ2              INY
                  INW
                  CPWi $03FF
                  BNE sinwave2
                  LDWi $0000
                  LDX #0
                  LDY #256
sinwave3          STX phase
                  LDA sinout
                  LSR
                  LSR
                  CLC
                  ADC #1250
                  STAaw scratchx3
                  STY phase
                  LDA sinout
                  LSR
                  LSR
                  CLC
                  ADC #350
                  STAaw scratchy3
                  CPX #1023
                  BMI XNZ3
                  LDX #0
XNZ3              INX
                  CPY #1023
                  BMI YNZ3
                  LDY #0
YNZ3              INY
                  INW
                  CPWi $03FF
                  BNE sinwave3
                  LDX #7            ;yellow
                  LDA CLUT,X
                  STA color
                  LDY #0
plot              LDA scratchx1,Y
                  STA Xp
                  LDA scratchy1,Y
                  STA Yp
                  INY
                  CPY #1023
                  BMI plot
                  LDX #5            ;green
                  LDA CLUT,X
                  STA color
                  LDY #0
plot2             LDA scratchx2,Y
                  STA Xp
                  LDA scratchy2,Y
                  STA Yp
                  INY
                  INY
                  INY
                  INY
                  CPY #1023
                  BMI plot2
                  LDX #1            ;white
                  LDA CLUT,X
                  STA color
                  LDY #0
plot3             LDA scratchx3,Y
                  STA Xp
                  LDA scratchy3,Y
                  STA Yp
                  INY
                  INY
                  CPY #1023
                  BMI plot3
                  LDX #5            ;green
                  LDA CLUT,X
                  STA color
                  LDY #0
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,y
                  STA ly1                ;plot line from yellow to green
                  LDA scratchx2,Y
                  STA lx0
                  LDA scratchy2,y
                  STA ly0
                  LDA scratchx3,Y
                  STA lx1
                  LDA scratchy3,Y
                  STA ly1                ;plot line from green to white
                  LDA scratchx3,Y
                  STA lx0
                  LDA scratchy3,Y
                  STA ly0
                  LDA scratchx1,Y
                  STA lx1
                  LDA scratchy1,Y
                  STA ly1               ;plot line from white to yellow
STALL             JMP STALL
