Since RetroSoftware is down and has been for a while, here is a copy of my original article:
Linear time bucket sortI have been going through some of the old stuff on my BBC disks and found this - I used it for some demos to sort sprites to allow them to be rendered top-down to chase/run ahead of the raster.
It is a linear time bucket sort 53 bytes (60 if buckets is not in ZP) that takes <2k cycles for 32 sprites indexed by character line and <6k cycles for 128 sprites. I am happy to discuss it on the forums.
I have tidied the code and added a few lines of basic to help see how it works. This is the generic version, I tailored it for each demo by changing the way each bucket index is calculated eg ignoring hidden sprites when iterating the two src lists.
The algorithm is very simple and probably has a great explanation on the web now!
The fast version here only supports up to 255 numbers in up to 255 buckets - I think - anyway 32 buckets fits nicely even for BASIC use and sorting over 100 items doesn't happen very often in real time.
I would be happy to hear comments / improvements etc on the forums. [1]
Richard (tricky) Broadhurst.
10 src_count = &F8 : REM contains num to sort - 1
20 bkt_count = &F9 : REM contains num buckets - 1
30 buckets = &70 : REM address in zp of buckets
40 REM B=buckets, N=numbers (20.5B + 41N + ~22) (B=32 N=128 ~ 5926)
50 REM (32/32) RESET 250 + SIZE 482 + OFFSET 422 + WRITE 772 + RTS 6 = 1990
60 DIM linear_sort 200, src 255, dst 255
70 FOR pass = 0 TO 3 STEP 2
80 P% = linear_sort
90 [OPT pass
100 .sort \\ call with X = number of buckets and Y = number of numbers to sort
110 LDX bkt_count \\ change to STX bkt_count if X is passed in (count = 1 based)
120 TXA
130 LSR A
140 LDA #0 \\ zero the count of each valid number's bucket
150 BCS odd \\ unroll loop in pairs, odd total, jump to second half - break even B=4 faster B=6+
160 .reset_buckets
170 STA buckets-1,X
180 DEX
190 .odd
200 STA buckets-1,X
210 DEX
220 BNE reset_buckets
230 \\ A=0 X=0 Y=? Z=1 N=0 C=?
240 LDY src_count \\ remove this line if passed in in Y
250 .size_buckets
260 LDX src-1,Y \\ get value to be sorting by [0..bkt_count)
270 INC buckets,X \\ increment how many of this buckets number we have
280 DEY
290 BNE size_buckets
300 \\ A=0 X=? Y=0 Z=1 N=0 C=?
310 CLC
320 LDX bkt_count \\ making X 1 based
330 .accumulate_buckets \\ offset bucket base by total of previous entries
340 ADC buckets-1,X
350 STA buckets-1,X
360 DEX
370 BNE accumulate_buckets
380 \\ A=src_count X=0 Y=0 C=0 Z=1 N=0
390 SEC
400 .write_results \\ this is where you would make changes to save another pass over the generated indices
410 TAY \\ A = Y = original index of value (1 based)
420 LDX src-1,Y \\ X = original value to sort on
430 DEC buckets,X \\ bucket value needs pre decrementing to give a zero based index
440 LDY buckets,X \\ Y = final index of original value
450 SBC #1
460 STA dst,Y \\ store original index in dst[final index]
470 BNE write_results
480 \\ A=0 X=? Y=? Z=1 N=0 C=1
490 RTS
500 ]
510 PRINT "sort &";~sort;" [";P%-linear_sort;"] src &";~src;" dst &";~dst
520 NEXT pass
530 :
540 ?bkt_count = 32
550 FOR m = 1 TO 200
560 ?src_count = m
570 FOR n = 0 TO m-1 : src?n = RND AND 31 : NEXT
580 PRINT
590 PRINT "src: "; : FOR n = 0 TO m-1 : PRINT ;src?n;" "; : NEXT : PRINT
600 CALL sort
610 PRINT "bkt: "; : FOR B = 0 TO 31 : PRINT ;buckets?B;" "; : NEXT : PRINT
620 PRINT "dst: "; : FOR n = 0 TO m-1 : PRINT ;dst?n;" "; : NEXT : PRINT
630 PRINT "ord: "; : FOR n = 0 TO m-1 : PRINT ;?(src+dst?n);" "; : NEXT : PRINT
640 NEXT
650 REM with buckets in ZeroPage sort is 53 bytes, otherwise 60 bytes, but no code changes are required
660 REM could use N based indices by offsetting lookups (try not to cross page boundaries)
670 REM could also easily unroll the size_buckets loop in pairs (would need to set A=0 before .accumulate_buckets)
680 REM if you just wanted a sorted list of numbers, you can replace accumulate_buckets and write_results with a loop over the buckets printing each index the number of times in each bucket
In the context of a BBC Micro, that is less than 16 scan lines to sort and get indices for 32 sprites or 48 scan lines to sort and get indices for 128 sprites sorted by character row.
is the original index of the sprite.
is how many entries landed in each bucket.
is the sorted index of the sprite.
is the sorted value or in this case, the sprite's character row.
