n00b Verilog Questions
ElEctric_EyE
Post by ElEctric_EyE »
Hello, I need to delay a 1-bit signal by 6 cycles. What is a more proper/cleaner way to do the following? I know a multistage shift register would work, but not sure how to code it.
//delay countflag by 6 cycles
reg countflag, s1, s2, s3, s4, s5, s6;
always @(posedge clk) begin
	s1 <= countflag;
	s2 <= s1;
	s3 <= s2;
	s4 <= s3;
	s5 <= s4;
	s6 <= s5;
end
TIA
Arlet
Re: n00b Verilog Questions
Post by Arlet »
Your method works, and if you're lucky the tools will synthesize a shift register. But you can also make an explicit shift register yourself:
reg [5:0] s;
wire q = s[5];
   s <= { s[4:0], countflag };
ElEctric_EyE
I checked the RTL schematic. My code shows multiple FF's in a row which was expected. Your code works, but I cannot see it in the RTL schematic.
I'm puzzled about your code, I would have expected a '<<' or '>>' somewhere. How does the Verilog know that this is a shift register?
Arlet
Post by Arlet »
The { } is the concatenation operator. It combines multiple bits. In this case it takes s[4:0] as the most significant bits, and add countflag as the least significant bit. If you write s <= { countflag, s[5:1] } it's a shift register to the right.
ElEctric_EyE
Arlet wrote:
...it takes s[4:0] as the most significant bits, and add countflag as the least significant bit....
Ah... Thanks! I was thinking 'replaces' which would result in no action.
Arlet
Post by Arlet »
Replacing the least significant bit would look like { s[5:1], countflag }
ElEctric_EyE
Excellent! Why then isn't your code showing up in the RTL schematic? Has it been absorbed? Is this the ideal situation when using Verilog?
Arlet
Post by Arlet »
I don't know. Are you using the input and output ? If not, it may have been optimized away. I just tried it in ISE, and it shows up in the RTL schematic as 6 FFs. In the technology schematic is shows up as a single slrc16e.
enso
Post by enso »
Arlet, in your example I imagine you wanted to use q and not countflag... You can make it even simpler without a temporary:
reg [5:0] s;
   s <= { s[4:0], s[5] };
and possibly even simpler:
reg [5:0] s;
   s <= { s, s[5] };
Verilog should trim the high bit when assigning the 7-bit result to a 6-bit register. I think. I am away from my system to check. Maybe it's an error condition, but verilog is generally pretty permissive.
Of course in the real world to get any data into s you'll have to mux it in somewhere.
Arlet
Post by Arlet »
No, countflag is the input, and q is the 6-cycle delayed output.
enso
Post by enso »
oh, I see, it's just a streaming shift register. My mistake, I was rotating for some reason.
enso
Post by enso »
I can't remember for sure, but I think verilog allows aggregate lvalues:
reg  [4:0]s, q;
   {q,s} <= { s, countflag };
Am I wrong?
[Edited typos]
enso
Post by enso »
OK, here is my favorite way to do this:
wire q;
SRL16 shifter(q,1,0,1,0,clk,countflag);
This little gem creates a shift register inside a single LUT. 1,0,1,0 is backwards binary 0101 - decimal 5, which creates a tap at the 6th bit.
This method is a little frowned upon since it binds you to Xilinx chips. Personally I am sold, so I write a lot of code like this (I prefer instantiation as it more closely resembles a netlist or a schematic. As I see it, it's more readable for some types of circuits).
Arlet
Post by Arlet »
My code also creates a shift register inside a single LUT, so it comes down to what you find easier to express.
enso
Post by enso »
To be totally accurate, instantiating guarantees that an SRL16 will be created. Otherwise, it is merely likely that a single SRL16 will be created and not a bunch of flip-flops. It depends on the settings buried in command-line switches and project settings.
An instantiated SRL16 may also be manually placed at a specific location on the chip.
