OK, I still find it difficult to navigate all the files listed on that site. But I did a google search of the site and found this
text file. It says "this SCH is valid for the 3008 to 3032. It is just a matter of placing the right 'jumpers' and RAM-ICs."
I have not reproduced the entire text file here, but the author, Ruud Baltissen, also says, "You may copy the schematics for NON-commercial use. I hope you enjoy it. If you use it, just give me at least some credit like "Stolen from Ruud
The accompanying schematic is
http://www.zimmers.net/anonftp/pub/cbm/ ... e/3008.gif The image is rotated 90 degrees, so I'm posting a normal version below.
Assuming this matches your 3032, then you may connect a reset pushbutton from ground to the 10 nf capacitor on pin 2 of the 555 timer IC. BTW, is your multimeter a digital type, or analog (with an actual needle and semi-circular scale)?
Hi Jeff,
based on my little knowledge, the 3008 share the same pcb with 3016 and 3032, so it should be ok.
I have both digital and analog multimeter, however the multimeter hasn't the ohm part working (it's a 1982 multimeter and it uses that 3v battery, actually out of production). BTW Ruud Baltissen also helped me a couple of days ago with this problem
Well, I did a couple of steps foreward!
- I checked the ROM checksum putting them in my 8032 and now I know they're ok.
- I checked the CPU socket and I discovered it's faulty. So I changed it and now I have that behaviour I had with just one 6502 of mine: the garbage stays for a while then disappear. The CPU is now refreshing the screen.
When at first I wrote on this forum, I wrote on the vintage-computer.com forum too, so now there is a lot of people helping me: you, here, and some nice guys in this other thread:
http://www.vintage-computer.com/vcforum ... 2-quot-CRTWithout your help I probably didn't discovered the faulty socket, so thank you very much for that!
We're approaching the problem from two different ways, and this is quite interesting indeed!
Well, now I only need to find a button on my spare parts cash to make the reset button
will tell you soon!
----EDIT: I put the reset switch; it seems that somebody in the past did the trick, since there was evidence of solder on C68 capacitor. Well, it didn't help. Then screen remains black even with the reset button. At least we have one information more: the reset doesn't makes the garbage screen appear again.
However the reset button made me remember I read something in the past about a monitor switch, so I googled for a while and I found this info:
http://newsgroups.derkeiler.com/Archive ... 00431.htmlI tried this with this result:
- the garbage stays on the screen until I tap the button, then it turns the display to black screen.
- keeping the button pressed, it doesn't enter in the monitor mode.
maybe this info would be useful for somebody that has enough skill to decipher it...
Giovi
