Concept & Design of 3.3V Parallel 16-bit VGA Boards
ElEctric_EyE
Post by ElEctric_EyE »
ClearScreen and the Origin (green pixel):
START:	    LDA #$0000
            TAZP                 ;SET ZEROPAGE @$0000_0000
            LDA #$0001
            TASP                 ;SET STACKPAGE @$0001_0000
            LDWi $0000           ;  LDW #$0000 - SET BLACK SCREEN ACCORDING TO COLOR LUT
            LDBaw COLTABLE       ;  LDB COLTABLE,w
            STBa SCRCOL          ;  STB SCRCOL
            JSR CLRSCR
            LDWi $0005           ;  LDW #$0005 - SET PIXEL COLOR GREEN ACCORDING TO COLOR LUT
            STBa PXLCOL          ;  STB PXLCOL
            LDA #$0140           ;X CENTER OF 640x480 SCREEN
            STA SCRLO
            LDA #$80F0           ;Y CENTER OF 640x480 SCREEN
            STA SCRHI
            LDY #$0000
            LDX #$0010           ;16 PIXELS WIDE AROUND THE ORIGIN
            STBiy SCRLO          ;  STB (SCRLO),Y
END         JMP END
CLRSCR      LDA #$0000        ;$8000_0000 START OF VIDEO MEMORY
            STA SCRLO         ;X VALUE
            LDA #$8000
            STA SCRHI         ;Y VALUE
            LDX #$01E0
            LDA SCRCOL
AB          LDY #$0280        ;$81DF_027F END OF VIDEO MEMORY
AA          STA (SCRLO),Y
            DEY
            BNE AA
            STA (SCRLO),Y     ;GET THAT LAST PIXEL!
            INC SCRHI
            DEX
            BNE AB
            RTS
ElEctric_EyE
Having some fun with the .b core (RADIUS is $0010):) :
            STA SCRLO
            STA SCRHI
            STBiy SCRLO          ;  STB (SCRLO),Y    PLOT
            LDA SCRHI            ;A ACCUMULATOR, Y COORDINATE
            SBCAopCzp YRADIUS     ;C ACCUMULATOR, Y MATH
            STCzp SCRHI
            STBiy SCRLO          ;PLOT
            ADCAopCzp YRADIUS
            STCzp SCRHI
            STBiy SCRLO          ;PLOT
            STA SCRHI            ;RE-CENTER
            LDDzp SCRLO          ;D ACCUMULATOR, X COORDINATE
            SBCDopEzp XRADIUS     ;E ACCUMULATOR, X MATH
            STEzp SCRLO
            STBiy SCRLO          ;PLOT
            ADCDopEzp XRADIUS
            STEzp SCRLO
            STBiy SCRLO          ;PLOT
ElEctric_EyE
Ugh, not so easy to convert 6502 programs to 65Org16!
I successfully converted Lee's Square routine made for the 6502.
But I have a headache from trying to convert his SquareRoot routine.
EDIT: Ohhh, I found a fast routine here I'll try to convert! It works in MK's assembler/debugger, but there is no remainder, so testing sqrt(13)=3.6 = 3. Not even rounded off. :|
Arlet
Post by Arlet »
If your goal is to draw circles, you should check out Bresenham's circle algorithm. It only uses simple operations as long as you draw full circles.
ElEctric_EyE
Yes I'm going for circles, but I need some code now! I can't afford weeks of figuring that stuff out. I never learned C.
I already have the Square routine, all I need is the SQRT and I'll have something I hope.
Maybe I will have to take some time converting Bresenham line algorithm to assembly. After these 2 algorithms, circle and line, the sky is the limit.
8BIT
Post by 8BIT »
Hey EE,
My SBC-3 cc65 library uses the Bresenham alorithm. So does my AVR 320x240 display. I posted a QuickBASIC conversion here:
viewtopic.php?f=1&t=2087&hilit=320x240&start=16
I can post a stand alone aseembly version if you want it... might take a day to put it together though.
ElEctric_EyE
8BIT wrote:
...I can post a stand alone assembly version if you want it... might take a day to put it together though.
I would be in your debt!
ElEctric_EyE
I just now realized (even after I was celebrating! :lol: ) I had to reset the origin after plotting each and every pixel! WOOOO!
EDIT: It's still not 100% because I was expecting a 1/2 circle on the right side only, but I may learn from the mistake!
ElEctric_EyE
This is what I was after, had the loop check (bne) too early. The following is correct together with these 1st 2 subroutines:
START:	    LDA #$0000
            LDA #$0001
            STBzp SCRCOL          ;  STB SCRCOL
            JSR CLRSCR
            STBzp PXLCOL         ; B ACCUMULATOR, PIXELCOLOR
            LDA #$0000
            STA Numberh
            CLC
AC          LDA #$0140           ; X CENTER OF 640x480 SCREEN
            STA SCRLO
            LDA #$80F0           ; Y CENTER OF 640x480 SCREEN
            STA SCRHI            ; START @ORIGIN
            STWzp Number         ; This 'Number' is actually X
            JSR Square           ; Now square it!
            LDA #$E100           ; Radius=$F0, R^2=$E100
            SBC Sqr              ; Sqr=Number^2
            STA Numberl          ; This Numberl IS (R^2-X^2)
            JSR SqRoot           ; THIS ROUTINE WILL RETURN Root=SQRT(Numberl)
            TWY
            SBCAopCzp Root       ;C ACCUMULATOR, Y MATH
            STCzp SCRHI
            STBiy SCRLO          ;PLOT 1st Quadrant
            ADCAopCzp Root
            STCzp SCRHI
            STBiy SCRLO          ;PLOT 2nd Quadrant
            INW
            CPWi $00EF           ; CPW #$00EF
            BNE AC
END         JMP END
EDIT: Tightened up the assembly code, same result except for the center pixel.
dclxvi
Post by dclxvi »
ElEctric_EyE wrote:
I was thinking Mandlebrot that Bruce had made for the 65816 and adapt it to 65Org16 (I thought he had originally made it for the 65Org16, guess I was wrong).
It was written to be easily ported to the 65org16, though. Except the for IIgs-specific code, like the ReadAsciiTime toolbox call, there are no 65C02 or later opcodes, like PHX, nor 65C02 or later addressing modes, like (stack,S),Y. So all that should be necessary is to discard the IIgs code and add your own OUTPUT, PLOT, etc. routines. I haven't tried actually porting it to the 65org16, but that's the intent.
and there's Samuel Falvo's blitter article at http://6502org.wikidot.com/blitter-theory-part-1 (although it looks like a few equations need fixing in order to show up at all. I'll contact him.)
Garth! It's a wiki, fer cryin' out loud. You can make fixes yourself as you spot them. There's online reference material and everything. For info on \left and \right in LaTeX (used for the equations), see section 6 (p.13) here:
ftp://ftp.ams.org/pub/tex/doc/amsmath/s ... -guide.pdf
8BIT
Post by 8BIT »
ElEctric_EyE wrote:
Here ya go!
; Draw a circle using Bresenham's circle algorithm
; 65C02 code written by Daryl Rictor
; ZP variables
; ZP base address of data area
ZPBase = $00
XC	=	$00 + ZPBase		; Center Point
YC	=	$02 + ZPBase		;
R	=	$04 + ZPBase		; radius (1 byte)
XP	=	$06 + ZPBase		; plot point
YP	=	$08 + ZPBase		;
X1	=	$0a + ZPBase		; x,y intermediate
Y1	=	$0c + ZPBase		;
FF	=	$0e + ZPBase		; difference
FX	=	$10 + ZPBase		; diff x
FY	=	$12 + ZPBase		; diff y
; SETPIXELCLIP: Test pixel @ XP,YP and plot if on screen
SETPIXELCLIP
; insert user code here
	rts
; CIRCLE: Draw a circle around the center XC/YC with radius in R.
; Must set an error code: NO
CIRCLE
	lda	R		; get Radius
	bne	_C1
	lda	XC		; if R=0, plot center point and exit
	sta	XP		; move center point to plot point var
	lda	XC+1
	sta	XP+1
	lda	YC
	sta	YP
	lda	YC+1
	sta	YP+1
	jmp	SETPIXELCLIP	; Plot as a point and exit
;  int y = radius;
_C1	lda	R		; 8 bit radius - can be expanded to 16 bit
	sta	Y1
	stz	Y1+1
;  int x = 0;
	stz	X1
	stz	X1+1
; int f = 1 - radius;		; if using 16 bit radius, this code section
	sec			; will need modifications
	lda	#$01
	sbc	R
	sta	FF
	stz	FF+1
	bcs   	_C2
	dec	FF+1
; int ddF_x = 1;
_C2 	lda	#$01
	sta	FX
	stz	FX+1
; int ddF_y = -2 * radius;	; if using 16 bit radius, this code section
	stz	FY+1		; will need modifications also
	lda	R
	asl			; *2
	sta	FY
	rol	FY+1
	lda   	FY
	EOR	#$FF
      	sta	FY
	lda	FY+1
	EOR	#$FF
	sta	FY+1
	inc	FY
	bne	_C3
	inc	FY+1
;  tgi_setpixel(xC, yC + y);
_C3	lda	XC
	sta	XP
	lda	XC+1
	sta	XP+1
	clc
	lda	YC
	adc	Y1
	sta	YP
	lda	YC+1
	adc	Y1+1
	sta	YP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC, yC - y);
	sec
	lda	YC
	sbc	Y1
	sta	YP
	lda	YC+1
	sbc	Y1+1
	sta	YP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC + y, yC);
	clc
	lda	XC
	adc	Y1
	sta	XP
	lda	XC+1
	adc	Y1+1
	sta	XP+1
	lda	YC
	sta	YP
	lda	YC+1
	sta	YP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC - y, yC);
	sec
	lda	XC
	sbc	Y1
	sta	XP
	lda	XC+1
	sbc	Y1+1
	sta	XP+1
	jsr	SETPIXELCLIP
_CLOOP
;  while (x < y) {		; calculate next plot step
	sec
	lda	X1
	sbc	Y1
	lda	X1+1
	sbc	Y1+1
	bcc	_C4	; x<y
	rts
_C4	lda	FF+1
	bmi	_C6
	lda	Y1
	bne	_C5
	dec	Y1+1
_C5	dec	Y1
	clc
	lda	FY
	adc	#$02
	sta	FY
	tax
	lda	FY+1
	adc	#$00
	sta	FY+1
	tay
	clc
	txa
	adc	FF
	sta	FF
	tya
	ADC	FF+1
	sta	FF+1
_C6	inc	X1
	bne	_C7
	inc	X1+1
_C7	clc
	lda	FX
	adc	#$02
	sta	FX
	tax
	lda	FX+1
	adc	#$00
	sta	FX+1
	tay
	clc
	txa
	adc	FF
	sta	FF
	tya
	ADC	FF+1
	sta	FF+1		; computations done - now plot 8 Octants
;  tgi_setpixel(xC + x, yC + y);
	clc
	lda	XC
	adc	X1
	sta	XP
	pha
	lda	XC+1
	adc	X1+1
	sta	XP+1
	pha
	clc
	lda	YC
	adc	Y1
	sta	YP
	lda	YC+1
	adc	Y1+1
	sta	YP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC - x, yC + y);
	sec
	lda	XC
	sbc	X1
	sta	XP
	lda	XC+1
	sbc	X1+1
	sta	XP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC - x, yC - y);
	sec
	lda	YC
	sbc	Y1
	sta	YP
	lda	YC+1
	sbc	Y1+1
	sta	YP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC + x, yC - y);
	pla
	sta	XP+1
	pla
	sta	XP
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC + y, yC + x);
	clc
	lda	XC
	adc	Y1
	sta	XP
	pha
	lda	XC+1
	adc	Y1+1
	sta	XP+1
	pha
	clc
	lda	YC
	adc	X1
	sta	YP
	lda	YC+1
	adc	X1+1
	sta	YP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC - y, yC + x);
	sec
	lda	XC
	sbc	Y1
	sta	XP
	lda	XC+1
	sbc	Y1+1
	sta	XP+1
	jsr	SETPIXELCLIP
;  tgi_setpixel(xC - y, yC - x);
	sec
	lda	YC
	sbc	X1
	sta	YP
	lda	YC+1
	sbc	X1+1
	sta	YP+1
	jsr	SETPIXELCLIP
	pla
	sta	XP+1
	pla
	sta	XP
	jsr	SETPIXELCLIP
	jmp	_CLOOP
circle.asm
(3.93 KiB) Downloaded 170 times
ElEctric_EyE
Awesome work, and thanks!
I'll add it to 65Org16 routines after I convert it and test it.
8BIT
Post by 8BIT »
Thanks... happy to help!
Arlet
Post by Arlet »
By the way, another technique to draw a circle is to draw a polygon instead using straight line segments from one point to the next. The location of the points are x=r*cos(phi) and y=r*sin(phi), but you can replace the sin() by a lookup table. This method is simple, reasonably fast (if you use the table), and can be easily modified to draw partial circles.
ElEctric_EyE
I reckon tables would be much faster, but looking at Daryl's take on the Bresenham algorithm I don't see any loops. That has got to be fast too, probably faster than what I'm doing now.
Is there another advantage besides speed for your idea?
