6502 Playground
6502 Playground
I've been toying with an idea for a while. Well, more than toying - I am actually prototyping this thing I am about to describe...
A WDC 65C02 has every pin (other than 3.3V and ground) connected to a Xilinx XC3S200AN or 700AN. A 128KB RAM is connected to the same FPGA. Also, a crystal. A bunch (64?) of pins from the FPGA are connected to expansion sockets (perhaps wing-style). The board is programmed with a 6-pin JTAG cable.
The 65C02 is completely sandboxed and controlled by the FPGA, presenting the following usage scenarios:
- A basic computer. BRAMS in the FPGA are mapped as a few K of ROM for monitor etc. Serial communication via 3.3V pins or a wing with RS232.
- A more sophisticated device with memory management in 8K chunks(or pretty much any size chunk)
- A clone of Apple, Commodore, whatever. The FPGA provides the missing circuitry; expansion boards provide SD storage, video output, keyboard etc.
- A 6502 core verification device. Run 65C02 in parallel with an FPGA core, sound alarms on state mismatches.
- A KimKlone-style 6502 augmentation. Since the FPGA oversees memory access, we can override any instruction, illegal or legal.
My goal is to keep the board simple and small. It should function as a self-contained SBC, and boot from the FPGA in the minimal configuration. For more advanced systems, the expansion boards can take care of what's necessary.
The idea was prompted by the address decoding discussions on this board. It seems that having programmable logic makes sense, and having a small FPGA makes it possible to build all kinds of peripherals very easily. The price difference between a handful of logic chips, a CPLD and a small FPGA is pretty small these days.
If there is enough interest, I could make few extra boards. I have a bunch of 200ANs and 700ANs itching to become something...
Feedback appreciated.
Re: 6502 Playground
Nice idea (distantly related to the propeddle) - how many pins on your FPGAs, and if BGA do you have a plan for soldering?
Re: 6502 Playground
Sounds cool. I would be interested in having a board.
Re: 6502 Playground
I've been working on the BGA issue for a while. For this project I am targeting XC3S200AN in a BGA 256-pin 1mm package. According to my tests and calculations, a 2-layer board escaping the outer 2-3 rows is sufficient. The left quadrant that connects to the 6502 has 36 pins brought out, requiring a few to come out the bottom. The RAM is the right quadrant; top and bottom quadrants connect to the expansion bus. 24 pins on top and 24 on the bottom is easy; 32 is certainly doable.
I am targeting about 3 square inches of PCB, 1x3 horizontally with expansion along the top and bottom edge, to fit a breadboard or wing adapters depending on how the expansion headers are populated.
ANs require only two power supplies (1.2V and 3.3V), and contain a flash, making them self-contained and requiring fewer support hardware.
2 layers is generally not acceptable for FPGA work, but in this case it's more than enough as we are working with a few megaherz. Also, since most of the bottom layer is used only for power and only 2 supplies are present, I can use massive conductors and decouple sufficiently well for the frequencies expected.
Philosophically, I need this board to be simple and 80's. Every FPGA board with a CPU I've seed does it backwards - the CPU is used to feed the FPGA, configure it, and even clock it. Here the board is hosted by the FPGA, configured via JTAG with no possibility of stupid problems. Having worked with PICs and AVRs enough, I can't imagine relying on these things to configure my board. It's bad enough to deal with USB flakiness on the computer end - the last thing I want to do is go looking for the AVR Dragon or some other debricking equipment to 'set fuses' on the chip responsible for communication and configuration of the board.
Re: 6502 Playground
I like the sound of this!
Re: 6502 Playground
Are you including the 1.2V and 3.3V regulators on the board ?
Re: 6502 Playground
Looks like both 128Kbyte and 512Kbyte SRAMs have 32 pins - any particular reason to go for the lower capacity?
Re: 6502 Playground
Re: 6502 Playground
OK, that's what I was hoping to get in terms of feedback...
I think I will put a PLCC socket in (it's about a dollar for smd versions) and connect all the pins, allowing for either 65c02 or 816 to be inserted (or nothing for a general-purpose FPGA with SRAM board. On another note, it's almost impossible to find an FPGA board with an SRAM - they all put in DRAMS which require awful controllers and ridiculous worst-case latencies when a refresh cycle overlaps an out-of-order access. OK for massive RISC chips with prefetch units, bad if you are trying to be cycle aware ).
(BigEd)Looks like both 128Kbyte and 512Kbyte SRAMs have 32 pins - any particular reason to go for the lower capacity?
128KB has to do with my inventory, as does the choice of the 200AN FPGAs. I also have a bunch of 700ANs in 484 BGA form, which provides even more fpga stuff and is perhaps easier to interface as more pins are available in the outer rows - all data pins can be escaped on to top surface (with 200AN I have to bring a few vias out of the left quadrant to keep it neat). I oven-bake them with 100% success rate so far. 0.5mm QFPs are also at 100% in my previous boards. It will be interesting to bake 3 chips of different kinds at once - I've only done BGAs one at a time so far.
The only problem with BGAs is to keep them in position while baking. Carrying the board around and the vibration from the oven door closing can knock the BGAs off the pads. I am working on a positioning template that holds the FPGA in its location, a metal brace that fits into 3 or 4 holes at diagonal corners, holding the FPGA to better than 0.25mm accuracy. Possibly a fairly massive one that spreads the heat evenly around the top of the FPGA. I have some experiments to run with a batch of boards that should arrive this week.
(arlet)--Are you including the 1.2V and 3.3V regulators on the board ?--
Originally I kept the regs on a separate board to make the board more oven-friendly. I will leave footprints for two 1117s are on the back side of the board as it should be more convenient. I can hand-solder them in separately along with the decoupling caps on the bottom. It works out nicely as all the power distribution is on the solder-side anyway
I've been trying to use gEDA after being fed up with Eagle, but it stinks too. Why are all PCB layout programs such crap? It can't be that hard to do it right. In particular, why are footprints treated any differently from a board layout? Why can't I have a library of little board chunks that's easy to incorporate into a larger board? Every package I've tried is really stupid about keeping libraries of symbols or footprints. gEDA at least stores everything as text, so you have some ability to generate or mess with footprints... But it's impossible to move tracks once they are down, so moving a chip a little is a monumental task. Maybe it's back to Eagle, as much as I like opensourced stuff.
Perhaps it's time to make a PCB system in Squeak/Pharo smalltalk. If only I had more time...
Re: 6502 Playground
Re: 6502 Playground
Arlet wrote:
I've done plenty of boards with the reflow oven that have double sided SMD...
- GARTHWILSON
- Forum Moderator
Re: 6502 Playground
I've been thinking I should look into the gEDA you mention. What's wrong with my old CAD? Very little actually. Drawing arcs can only be done on 45° increments. Having the thru-hole and SMT legends separate such that only the thru-hole ones actually get printed on the board adds a little work. The number of trace widths and pad widths and pad lengths are slightly limiting so I have to plan things carefully at the start of a project, and I can't put SMT parts at random angles (39° for example), but it's no biggie. It is a bit time-consuming to do the 274D-to-274X conversion on a complex layer that's partly ground plane and partly other things for example, but that's only at the end of the project, and if I did it often enough to justify the learning curve of another CAD package, I'd also be faster at the conversion. Instead of using the supplied footprints for various components, I have made all my own which are tweaked for higher density, and I do not look forward to re-making hundreds of components in a new CAD. Moving chips and tracks as you mention is super easy though. I do use gerbv from gEDA to view what I've done in my gerber edits to make sure I got what I wanted before it goes to the board house. Edit, 12/1/16: I see there's a free 3D online gerber viewer at http://mayhewlabs.com/3dpcb .
Re: 6502 Playground
(I had an idea for a cunning plan, but I want to present it as a hack on the board you want to make rather than an attempted diversion of your project: use the empty CPU socket to bring out an extra 8 or 24 data bus bits, to allow for a 16 or 32 bit CPU in the FPGA. The extra 1 or 3 SRAMs would have been piggybacked somehow onto the existing RAM, to reuse the address and control pins. Unfortunately that's a different proposition if it's surface mount RAM, which on reflection it probably is.)
- GARTHWILSON
- Forum Moderator
Re: 6502 Playground
Re: 6502 Playground
(I had an idea for a cunning plan, but I want to present it as a hack on the board...
Perhaps I should make a wire-wrappable module for the Xilinx FPGAs, even if it brings out 100 pins or so... That would make it possible for everyone to mess around with the FPGAs using the glorious wire-wrapping technology from the last century.
